Question about Baby Lock Esante
Baby Lock Encore ESn Manual
I'm unable to find a sewing manual for the subject. Do you have any suggestions?
Problem: Unable to change/select a straight stitch.
  • tmoore2 Jul 26, 2008
    I have a babylock encore. I cannot clear the previous stitch. I have pushed the clear button and turned the machine on and off. When I put in the number of the stitch I want and hit enter it says the two stitches cannot be combined.
  • sbsew Aug 31, 2008
    I also now have a similar problem-- the Encore 0, 1, and 2 buttons won't work for stitch selection. I can still do a straight stitch (01) by turning the machine off and on, then it defaults to the 01 position-- but that puts the needle in the far left. Is there a reset code for this machine?
5 Suggested Answers
SOURCE: Sewing machine straight stitch is not straight
Hey. It's full out possible that you have it on the right setting...but concider this - the switcher inside the sewing machine could be broken (ie. It's moving to different stitches - but not the one you have the outside set for)
It happened to me (pc o crap singer model)
Posted on Jan 24, 2008
mohammed387
  • 1952 Answers
SOURCE: i have the basically the same problem. i was
Check the easy stuff first:
Make sure the needle is inserted in the machine properly- a good rule of thumb is the flat side of the needle should go to the opposite side of the last thread guide. Also make sure the machine is threaded correctly.
the needle is in correctly with the flat side to the rear of the machine, make sure to thread the upper and lower portions of the machine correctly.
the needle is in the machine correctly- all the way up into the needle bar, make sure that it is threaded correctly, etc. If this all checks out ok, take the bobbin case out of the machine. There are two ears on either side of the bobbin case- turn the left one to the left and the right one to the right. Remove the silver ring, and inspect the piece of metal that the ring came off of (looks like a circle with the top cut off). You have to locate the hook which is the piece that looks like a half moon inside the big round metal piece. Locate the tip of it, turn the handwheel toward you until the needle is in the lowest position, at this point the tip of the hook should be flush with top of the left side of the cut off circle. If this is not so, your machine needs to be re-timed. If that is the case.
Posted on Aug 04, 2009
jyackle5
  • 8197 Answers
SOURCE: I am looking for a download for a manual for my
You can buy the manual here. Sorry can not find free one for you.
http://www.thefind.com/query.php?query=Serger+Babylock+BL3+418+manual
Good luck and please rate
Posted on Sep 16, 2009
Testimonial: "Thanks. I will go there and purchase one! You were very helpful."
SOURCE: My neighbor has a Kenmore 5180 machine that is
how do i insert the needle into the sewing machine
Posted on Oct 22, 2009
  • 152 Answers
SOURCE: when selecting the buttonhole option and starting
It sounds like the feed block in the machine is sticking. This happens when the machine has been sitting for a time or not had much use. The old grease hardens slightly or "gums up" and the mechanism doesn't return easily to it correct position. A trip to your service tech would be your best bet.
Posted on Nov 11, 2009
Testimonial: "Being used to an older non electronic machine, I was looking for more involved hassles in the newer version. Your advice was clear and logical.Thanks."
Baby lock quilt & craft model BL2300K. I received this from mother in law, no manual. Does any one know where the oil locations are so I can oil. Starting to make noise needs oil, thank you, robert
As a computerized machine, it is probable that there is very little (if any) oiling required. You can check with your local Baby Lock dealer's technician for oiling instructions and a manual for your machine. (Oiling incorrectly could permanently damage the machine.)
I was unable to locate a manual for your machine, but did find this web site:
Baby Lock Manuals
Dec 22, 2016 | Baby Lock Sewing Machines
I have a BABY LOCK PROLINE 6150 I am unable to find a instruction manual for it could u please help thank you
This does not seem to be available any more. As a last resort try emailing Babylock directly.
Nov 30, 2016 | Baby Lock Sewing Machines
I need owners instruction manual for baby lock companion 1550 sewing machine.pls help where can i download free manual.
You can check with a Baby Lock dealer an online sewing machine parts vendor, or even eBay. However, it may be difficult to find a manual for your machine due to its age and perhaps even less chance of success for finding a free manual.
Baby Lock Manuals
http://www.sewingpartsonline.com/babylock-sewing-machine-instruction-manuals.aspx
Babylock Sewing Machine Manuals Instruction and Repair Manuals
Babylock Sewing Machine Manual PDF and CD
Nov 27, 2016 | Baby Lock Sewing Machines
Only a few of the stitch selection buttons work on the machine. It is a babylock ESn Encore.
You will have to take the machine to an authorized BL dealer for service.
Mar 29, 2010 | Baby Lock Sewing Machines
I'm having trouble centering my frame to begin embroidering and am unable to find it in the manual.
See if there is a lever on the front of the plate where the hoop slips in. This should be up to open and once the hoop is in place, down to lock.
Download a free manua here - http://www.babylock.com/embroidery/ellure/
Mar 17, 2010 | Baby Lock Ellure
Baby Lock Eclipse threader looper
Do you know the looper threader broken can be repair by yourself? I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional repair guide written by an expert. Besides PfaFF sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
Sep 26, 2008 | PfaFF Hobby 4260
Sewing Machines Logo
302 people viewed this question
Top Baby Lock Sewing Machines Experts
Chris Wetmore
SewTechWayne
SewTechWayne
Douglas Plant
Douglas Plant
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
