Question about HP LaserJet 2100 Printer
HP 2100 Grabs TOO MUCH PAPER
Hi
I have an HP 2100 Laserjet. In that past few months it has started to intermitently pull through more than one piece of paper at a time. Sometimes two, not every time. Sometimes more. I even had some cardstock that I was printing on from the extra feed in the front on a straight through path to the back and it took 5 pages all at once. When I print checks I have to do it one at a time because when least expected it pulls more than one through at a time. What can I do to fix this???
Please help.
    Scholar:
  • 87 Answers
If all of the above doesn't work, which it probably won't, it sounds like you need to change the separation pad in the paper cassette and the manual feed tray. The separation pad in the tray is relatively easy to change. The multi purpose tray separation pad replacement will require removal of some covers to get to... Any good service center should charge you around $65 for the service and $20 for the parts....and while they have the machine apart they can check the other volatile parts in the machine to let you know where you stand with those.....Hope this helps
Inkworks
Posted on May 22, 2008
How do i take the ink cartrage out? Its stuck and just wont come out
Posted on Jan 28, 2010
    President:
  • 2,712 Answers
1. Clean the printer pick-up roller with a dry, lint-free cloth.
2. Add only moderate amounts of paper to the paper tray, and avoid mixing paper types in the paper tray. Do not force a tray to shut. Remove some of the paper until the tray will shut easily.
CAUTION: Do not overfill the paper tray when adding paper. Filling paper trays until the top of the paper stack fits loosely under the paper tray guides that are in either the front or the rear of the printer paper tray.
3. Try another **** of paper or change the paper type.
4. Make sure all paper adjustments have been set correctly.
5. Make sure the paper is within the paper specifications for the product.
6. When adding paper to an existing stack in the Paper-Input Bin, always remove and realign all paper to avoid multiple paper feeds, paper jams, or both.
7. Fan the paper before adding the paper to the Paper-Input Bin. Also, gently fold the stack of paper in half (in a U-shape) to break the pages free from each other.
8. Try printing on the other side of the paper.
9. The paper may have been stored improperly or is in an environment that is too dry or too humid. To combat a dry environment, place a humidifier in the area of the printer. For a humid environment, place a de-humidifier in the area of the printer.
10. If none of the above steps work, the printer may need to be serviced. Contact HP for service and support options.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 18, 2008
Hp 2420 leaves vertical line across the page. we changed the fuser 7 months ago
It sounds like you may need to change it again. These printers use a Teflon coated heat roller in the fuser. If you print envelopes that will scar the heat rolller, this can also happen if there is a piece of paper jammed in the fuser assembly and it scraped the fuser roller. Open the back of the printer and look at the roller in the fuser. I would bet that you see the roller is damaged. Here is a link to a post about the Laserjet 2100 printer with the same issue. It has pictures of the roller and what to look for, the fuser is different but the principle is the same.
http://www.ccl-la.com/blog/index.php/how-to-fix-hp-laserjet-2100-vertical-lines-on-print/
I hope this helps, if so please rate my solution.
BuddyMc
Sep 20, 2011 | HP LaserJet 2420dn Printer
My HP 8500 printer worked perfect for 6 months, but now grabs about 10 pages of paper every time it prints and is always jamming up.
Hi there
You should allways gave the paper a good shake before putting in the printer and the paper should keep in a worm place or it will do just that pull in lots at the same time.
All the best Pineworks
Mar 15, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Rollers on HP laserjet 2100 need replacing
You are right, they do need replacing (pick up roller and separation pad)
Mar 11, 2009 | HP LaserJet 2100 Printer
HP laserJet 2100 prints blank from manual tray
I bet you have a bad USB wire.Change the wire and I suggest reinstalling the drivers.
Oct 31, 2008 | HP LaserJet 2100 Printer
Print problem
How old is your toner cart?
Have you given the toner a little shake lately?
Is there paper wrapped around the fuser causing only a partial printout?
Jun 26, 2008 | HP LaserJet 2100 Printer
No problem.
I added it as a comment to the chat session. You should get an email stating as such, or else, just log into Fixya, go to your chat sessions, and you can open up our session. you will find the list there.
Thanks for the HELPFUL rating, BTW..
May 18, 2008 | HP LaserJet 2100 Printer
Paper jam
If you have pulled out paper that was stuck before you may have flipped a sensor flag out of position. I have found in the past small pieces of paper left under the plate at the very bottom of the toner catridges where the paper comes in.
Jan 04, 2008 | HP Color Laserjet 3550 Printer
HP LaserJet 2100 Printer Logo
1,130 people viewed this question
Ben Johnson
