Related Tags:
This problem should be removed because:
Problem with GE WJSR2070B Top Load Washer
Spin cycle problem
Washer works fine except for spin cycle
Suggested Solution (3)
It sounds like the bearings are going bad. Try spinning the drum with your hand while it is empty. It should spin nice and smooth. If the rotation feels a little rough and noisy, you might have a problem. You can double check by taking the drive belt off and try shaking the pulley. If there is "play" when shaking the pulley, the bearings are most likely toast. The inner stainless drum rides on two bearings which sit in the rear of the outer plastic drum. The whole plastic drum and bearings come as one piece and go for $150. It would cost about the price of a new maching to have someone come out and repair it for you. It sounds like kenmore has had a bearing problem which is pretty rediculous considering how much these things cost. Sears said, "those tend to go in a few years", which is criminal especially since the warrenty is usually conveniently exopired by the time this problem happens. If you are handy, have a spare day, and can remember how to put a washing machine back together, go for it. I did it and it was not a fun time. There is a lot of sharp metal edges in the machine so wear gloves. good luck
Source: Loud Noise - Spin Cycle
gnarly, do you have the updated motor, harness and start cap? If it goes into spin and does this chunk a chunka chunka bit. Take a meter to the white and white/red wire going to the motor. If you have a steady 120V, replace the motor with the new kit. What the motor is doing is jogging between high to low speed. Catriver..post back.
Source: GE Washer Spin Cycle Problem
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
washer won't spin
the washer works fine except for spinning the water out of the clothes
Washer won't spin
Stackable GE w/d- the washer will start with the wash cycle then pause with a humming noise (when it's suppose to be spinning) and then...
Kenmore stackable washer/dryer 417.97802792...
washer will go through all of the cycles except spin. And it does not drain. Worked fine up until this point. It runs normal until it gets...
Spin cycle stopped on 10 yr old Amana washer
My 10 year old amana washing machine goes though all cycles fine, except the spin cycle does not work. What could be the problem?
I have an Estae(whirlpool) washer
I have an Estae(whirlpool) washer that i have had for 9 yrs. It works fine until it get to the spin cycle. Then it stops and the water stays...
Tips for Helping red4re With Their Issue
- Give detailed step-by-step instructions
- A picture or video is helpful
- Use plain language not industry jargon
- Check spelling & punctuation
Add Your Solution
GE WJSR1070A1WW will not drain water
Washer water remains in tub. Will not proceed to drain or spin.
How di i remove the agitator from a GE washing...
Can get the cap off from top, but than have four little knobs seemingly plastic, but no screws
I have a GE WJSR2070B washer. The pump will drain...
I have a GE WJSR2070B washer. The pump will drain the water but the drum will not spin out the water. I can hear the...
Related Topics
Fix-O-Meter
59
59 people viewed this problem
- 0 people are following this problem. Be the first!
Top GE Washing Machine Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
