Question about Nintendo Wii Console
Wii remote new wii remote wont work how do you program it?
  • 31 Answers
Wii Remote problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Posted on Mar 05, 2009
  • 3,940 Answers
Once the batteries are installed, but before you put the cover on the remote, flip the little door open on the front of the Wii console, press the red button on the Wii console, then the red button on the back of the remote next to the batteries. Install the battery cover, the remote should be synced.
Posted on May 18, 2008
2 Suggested Answers
SOURCE: wii remote wont work after installing wii fit
From Nintendo:
  1. Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
  2. Turnthe power of the Wii console ON. When you see the Health and Safetyscreen, open the small flap on the front of the Wii console to find ared button labeled "SYNC." Press and hold the SYNC Button down for 15seconds. This will clear all the syncs on the Wii, allowing you to geta clean start to begin the process described below.
  3. After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
    1. Withthe first Wii Remote you wish to sync, remove the battery cover on theback of the Wii Remote to find a small red button just below thebatteries.
    2. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
    3. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
    4. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
    5. This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
Posted on Jan 03, 2009
If the wii remotes aren't working, responding, or charging, can the remotes be reset or do I need new batteries?
First you will meed 2 try new batteries then you will need to press the 'Red' button
located on the Wii console to 'Re-tune' in the Controllers
How to Sync the Wii Remote Standard Mode Wii and Wii mini Nintendo...
May 11, 2014 | Video Game Consoles & Games
Bought a new will remote but it won't work.
Go into the Wii channel and go to settings then look for calibrated remote. Make sure the new wiimote is on. Set the Wii controller on a flat surface and press callibrate. The wiimote will be ready to use .have fun.
Hope this helps.
Apr 29, 2014 | Nintendo Wii Video Game Consoles & Games
My wii remote keeps flashin but wont trun on
You have to sync the Wii remote to the console.
To sync the Wii remote, turn on your Wii. Then open the back of the remote and press the "SYNC" button. Then open the SD Card Slot cover on the front of your Wii and press the "SYNC" button. Your remote should be turned on if you do this.
If this problem still occurs even when the Wii remote is synced, your Wii remote might not be working properly. Return it for a new one.
Feb 21, 2010 | Nintendo Wii Remote Controller
My ******* wii remote wont work. It's synced and everything. I can enter the wii menu, but the hands wont show up on the screen. I am 4 ft. away from the sensor. I have no other infrared things and the...
youo may have a defective Wii remote, and you should take it somewhere like GameStop and have it looked at, or you should take it back to the store and exchange it for a new one.
Nov 14, 2009 | Nintendo Wii Remote Controller
My handsets wont sincronise with the system, I have fitted new batteries
Follow this procedure:
1. Turn the Wii console on and wait until the "Health & Safety" screen appears (don't press A).
2. Open the SD Card slot cover on the front of the Wii console, just below the disc drive, and press and hold the red SYNC button for 15 seconds. This will clear all synced Wii Remotes from the console.
3. Resync the Wii Remote by removing the battery cover and pressing the red "SYNC" button. Do this for all Wii Remotes you wish to use, and test for proper response.
4. If the steps above do not work, remove the batteries of the Wii Remote and leave them out for at least 2 or 3 minutes. Reinsert the batteries and sync the Wii Remote again. Test for proper response.
If after removing the batteries for several minutes, and resyncing the Wii Remote, your still unable to get the Wii Remotes to work, try syncing another Wii Remote if available.
* If another Wii Remote works, then your previous Wii Remote will need to be repaired.
* If multiple Wii Remotes do not work, or you only have one Wii Remote, a repair of the Wii console is necessary.
Oct 20, 2009 | Nintendo Wii Console
My wii remot can turn on and i can push a and b but the wii remote wont work when i play baceball or boling. for exampol my avatar wont swing the bat when i play baceball.
Make sure the batteries are not worn down. If the sensor bar is in really bright light it will not work. Close the curtains so there is not lots of sunlight. Unplug the sensor bar and plug it back in again. You could try to re synch the remote, open up the wii remote battery pack and press the red button at the top once. Then quickly press the red button on the inside of the SD Card flap on the wii. If this problem persists try to get a new remote, or better contact customer services if these solutions don't work. Info is in the Wii manual.
Apr 15, 2009 | Nintendo Wii Console
2nd Wii remote not working
sounds like you have a defective wii-mote to me...time to find out how that warranty / exchange program is
Feb 15, 2009 | Nintendo Wii Console
Wii remotes wont hook up
did you try syncing them up by pushing the red button on the wii and the remote
Jan 03, 2009 | Nintendo Wii Console
My wii remote wont go on even i got new batteries
You have to press the sync button in both the remote and the back of the wii.
Aug 13, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
116 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
