Question about Samsung Cell Phones
Samsung d910i only displays "limited service"
My refrigerator display shows "Of" how do I get it to normal when I reset the temp for the fridge or freezer the display goes back to "Of"
I just had the same problem with my Samsung. OF means it is in demo mode. On my fridge I had to press "Energy Service" key and "Power Freeze" key simultaneously for at least 3 seconds to bring the fridge out of demo mode. Hope this helps.....
Jan 28, 2013 | Samsung Refrigerators
Tip
TROUBLE SHOOTING AND SERVICE ADJUSTMENT
Troubleshooting Guide
Self-check function
When phenomena like "the power fails from time to time" or "the video/audio fails from time to time" can not be confirmed at the time of servicing, the self-check function can be used to confirm the occurrence and to limit the scope for the defective circuits.Also, when "the power fails from time to time", display on the screen can be used to confirm the occurrence and to limit the scope for the defective circuits. Any programmed channels, channels caption data and some other user defined settings will be erased and return to factory setting.
How to access
Access
Produce TV reception screen and, while pressing [VOLUME-] button on the main unit, press [SLEEP] button on the remote controller unit simultaneously.
Exit
When one of the buttons for channel selection etc. is pressed, the display returns to the normal screen.
For more check the link below
Electronics Equipment Repair Center
Ajin Gopakumar Google
on Feb 16, 2015 | Panasonic TC-19LX50 19" 1280 x 768 800:1...
My Samsung syncmaster 940BW monitor wont display anything except "check your cable...", done it but nothing happens...can you provide me a contact number from one of the service center here in...
I researched you question and found all the service centers available for repairs by samsung. Either click the link or copy the link into your address bar on your web browser. Here is the link:
http://www.samsung.com/ph/support/location/supportServiceLocation.do?page=SERVICE.LOCATION
I hope this helps you out please give me a Yes that I did help you. Thank you.
Apr 08, 2011 | Samsung Computers & Internet
My Samsung SGH-t659 displays "Phone Freeze SIM
I have experienced this issue and I would take the phone to a service provider location As Soon As Possible to have the issue corrected.
Nov 12, 2010 | Samsung Star GT-S5233 Cell Phone
Samsung sgh-e590 limited service
HI i have same problem with my samsung.
Sep 27, 2009 | Samsung E590 Unlocked GSM Phone
All airtel sim shows limited service on sgh-e250 b
my problem is i can't call and reseving calles to my sgh-e250 and showing limited service on display
Nov 09, 2008 | Lands Phones
'Limited Service' displays on Samsung SGH-D900 phone on Orange network and I can't use it except for SOS calls.
GUEST - you internal antenna might need to be service or replaced.
well you may not have it on the correct band so you should check that one.....or hard reset it *2767*3855#
Apr 03, 2008 | Samsung SGH-D900 Cellular Phone
D900 limited service?ne solutions
I had the same problem so I went into Menu-Settings-Network Services-Band Selection. It should then give you the option to select two different types of GSM Bands or Quad Band. I found that Quad Band works for me, but the GSM 850/1900 worked as well. Hope this helps!
Mar 14, 2008 | Samsung SGH-D900 Cellular Phone
Cell Phones Logo
553 people viewed this question
Top Samsung Cell Phones Experts
Fotis Papastamatiou
Bill Long
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
