Question about Whirlwind FH-778 Air Conditioner
My haier window air conditioner
Why my air conditiner don't stop when reach the temperature I put on the thermostat
I have a haier unit and last night the led went crazy it has totally stop working now and the LED just shows E1 I have tried unplugging it and resetting the button on the plug and nothing has helped this unit is less than a year old. Please help if you can....
Posted on May 28, 2008
Haier service manual
This is what you error code means.
E1 = Room temperature sensor fault
Haier Air Conditioner Fault Codes
AC Repair Tamarac
Aug 25, 2014 | Haier Esax3186 Energy Star 17,000 Btu...
Series 48000 with heat pump we don't want this to run all the time will the heat shut off when it reaches a certain temp also if the power goes out does it come back on automatic we want to heat our place...
Not sure about your particular make and model, but air conditioners are designed to work with a thermostat to control the functions. A properly functioning thermostat will stop the compressor when the set space temperature is satisfied. When the space temperature falls below (heating) the set temperature, the thermostat should turn it back on. In the event of power failure, an electronic thermostat probably will not operate at the previous set temperature when power is restored, but maybe at a higher temperature (but will work).
Dec 05, 2013 | Coleman Mach 15 Air Conditioner
Do I have to put the window air conditiner on a slant for the water to drain I did put the drain plug in.
Yes , But I think it best to leave the drain plug out and if at all possible install a hose .. hope this helps let me know jon
Aug 01, 2011 | LG Electronic Window Air Conditioner
We just purchased a Haier Commercial Cool 12000 BTU portable air conditioner and the window exhaust slider is too short for our can we correctly add on to the slider? We are short about 10...
At one time, Haier had an optional window kit for taller or wider windows. Contact their Product Support 1-877-337-363, to see if it's still available.
Jul 09, 2011 | Heating & Cooling
Compressorruns fora short time
the thermostat controlling your unit likely has a window type of programming for digital or mechanical adjustment for older style thermostat that sets a minimum off temp and a maximum on temp, there may be an adjustment to set the range it operates at, otherwise you may have a defective thermostat controller unit and it needs replacing also insure that the temperature sensing element is clean and free of dust build-up and your filter is clean
Apr 28, 2010 | Dometic Rooftop RV Air Conditioner
Haier room air conditioner doesn't cool maximally at "Hi AC"
You should have at least 5,500 BTU's for that size room. Clean the filter. Turn it on and let it work for a few hours.
Aug 02, 2009 | Haier hwr10xc6 Air Conditioner
Haier window airconditioner cooling is not effective
there is a temperature sensor bulb in front of the evaporator. check if it is too near to the coil. move iit away about an inch.
Apr 30, 2009 | Haier HWR12XCB Air conditioner
Room temperature goes too low
When room temperature drops lower than the set temperature on the thermostat, it usually means that the thermostat is improperly calibrated or installed where it doesn't sense a proper sampling of room air.
Jan 18, 2006 | Haier Energy Star ESA3183 Air Conditioner
Heating & Cooling Logo
132 people viewed this question
Top Whirlwind Heating & Cooling Experts
Dennis Boxerman
Bill Long
Dan Webster
Dan Webster
Are you a Whirlwind Heating and Cooling Expert? Answer questions, earn points and help others
