Question about Toshiba Satellite 2400-S251 Notebook
RTC battery "bad check sum (CMOS) message
I bought a new Toshiba laptop and left my old Satellite 1415-S173 unplugged for four months. I have files and folders to research from it and turning it one (with cord) brings up the message to check the system then press the F1 Key. I don't know what to do on the "system setup" page.
  • 67 Answers
Your cios have properly lost the info.
just setup the date.. that should be enough ..
Or write to me and I will guide you.
Posted on May 19, 2008
2 Suggested Answers
  • 107 Answers
SOURCE: RTC battery "bad check sum (CMOS) message
flashing your bios might solve your problem
Posted on Feb 17, 2009
I have a Toshiba Satellite 1415-S173 with a bios password I don't know (original owner is deceased). How can I bypass or remove?
Remove the CMOS battery from the motherboard. Turn it over, open it up, and look for a little watch battery.
Oct 31, 2009 | Toshiba Satellite 1415-S173 Notebook
Turn on computer and message reads ****bad check sum (CMOS) ****
That means that after computer had been off for a long time the CMOS battery has drained, and CMOS (BIOS) settings had been reset to default.
Usually the computer will work fine after pressing F1, but you may get wrong date and time.
Try charging battery completely, often the problem disappears, if it does not , then the choice is between pressing F1 each time you start the laptop, or disassembling the laptop and replacing CMOS internal coin battery, located on the lower side of the motherboard.
May 17, 2009 | Toshiba Satellite 1805-S204 Notebook
Toshiba Satellite 1415-S173 not powering up
Take out battery then try it.. if that dont work and it dont turn on then you might have to go inside..
Apr 22, 2009 | Toshiba Satellite 1415-S173 Notebook
Toshiba 1410-S173 battery charging light blinks amber
did you buy the battery brand new or used?
brand new, deffectibe motherboard, bad charger or bad dc socket.
used, change it.
Mar 03, 2009 | Toshiba Satellite 1415-S173 Notebook
Feb 17, 2009 | Toshiba Tecra 9000 Notebook
Cannot enter bios setup
pres del or f1 f2 f4 f 12 but not press esc.then check if u still get rpoblems then u have to reset you bios settings .u have to remove your cmos cell for 15 minutes it is in back side of laptop.
Jan 24, 2009 | Toshiba Satellite 1415-S173 Notebook
Not boot from factory CD -where is CMOS battery?
Appreciate the direct "Ask Me".
Based on your post/description:
  • Toshiba Satellite 1415-S173;
  • new HDD;
  • would install WinXP.
Your concerns are:
  • media/cable fault;
  • CMOS battery;
  • laptop battery.
  • will not complete format;
  • will not install OS (WinXP).
Proposed course of action and other ideas:
  1. double check the new HDD, verify that the pins are not bent and are seated correctly. If all else fails, return the new HDD and have it replaced;
  2. try partitioning/formatting the new HDD in another PC using a 2.5 IDE to USB external adapter;
  3. clean the lens of the DVD/CD ROM drive;
  4. remove the dead laptop battery and use only the AC power when installing;
  5. most current laptops do not use a CMOS battery;
  6. if you want to revert CMOS/BIOS settings to default, it could be done by pressing on ESC or F1 or as indicated in the display (depends on the version) and set all possible settings to default. Verify that it is set to boot from the CD drive.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 02, 2008 | Toshiba Satellite 1415-S173 Notebook
Toshiba cmos battery disconnect
on a Satellite 1415-S115 You will have to open up the clam shell and remove all of the B25 and F6 screws from the bottom, as well as the B16 and B6 screws under the keyboard. To remove the keyboard, pry up the trim piece that holds the power button with a sharp nife a stanley blade is always usefull remove the three screws. mind the wireless wire leads there a pain.
The CMOS battery will be under the right side of the hand rest, next to the mouse. It has two leads and the battery is in a blue bag.
simply replace the battery and reassemble your laptop.
Dec 07, 2007 | Toshiba Satellite 1415-S173 Notebook
Toshiba Satellite 2400-S251 Notebook Logo
542 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
