Code 39 i av a acer aspire 7720 my pioneer dvd-rw k17rs ata as stopped work and gives code 39. help
    Champion:
  • 207 Answers
.Turn on the PC. When the HP/Compaq logo screen appears, press the F1 key repeatedly until the BIOS Setup screen appears (on some models this key press may different, F2 or Del)
2.Use the Left and Right Arrow keys to select Main.
3.The hardware-identifying name should appear next to Secondary Master, Secondary Slave, or Primary Slave.
If the name for the drive exists, skip to Step 3. Otherwise, continue to the next step.
Step 2: Reseating cables
If a drive name does not appear for each drive and None is listed in the BIOS, use these steps to open the computer case and reseat the drive cables. Work on a hard flat surface over a non-carpeted floor.
1.Turn off the computer, unplug all cords from the PC, and then press the Power button on the front of the PC for five seconds.
2.Remove the side panel.
3.Remove both the IDE ribbon cable and the power cable from the back of the CD drive.
•If the drive name appears in the Primary IDE section or the hard drive name is now missing, the IDE cable is bad or the drive settings are wrong. Replace the IDE cable and connect it according to the drive jumper settings . That is, if the small rectangular connector (the jumper) on the drive is set to MS (Master), connect the master end of the IDE cable into the back of the drive. If the jumper is set to SL (Slave), use the slave connector on the cable. If the drive is set to CS (Cable Select), you can connect using either connector on the cable.
Step 3: Removing Drive in Device Manager
Remove the drive name from Device Manager:
4.Close the Properties window and select the CD drive name.
5.Click the Uninstall or Remove button (in Windows XP this is the square button with a red X).
6.Click Yes or OK to remove the CD listing. Do not restart the PC.
7.Close Device Manager.
8.If your PC has Windows XP, perform the next step to clear the registry filters without restarting the PC.
Clearing the registry filters in XP
Click Start, Run, and type the following into the Open field: regedit
Click OK. The registry editor appears.
In Windows XP, click File, Export, type a filename that is easy for you to remember, and click Save.
In Windows 2000, click Registry, Export Registry File, type a filename that's easy for you to remember, and click Save.
A copy of the registry has saved for back-up purposes.
Click the plus sign (+) next to the following items in the list:
•HKEY_LOCAL_MACHINE
•SYSTEM
•CurrentControlSet (or the current control set with lowest number if that is all that is listed)
•Control
•Class
Select 4D36E965-E325-11CE-BFC1-08002BE10318.
Select UpperFilter in the right window and press the Delete key.
Confirm the deletion by clicking Yes.
Select LowerFilters in the right window and press the Delete key.
Delete all other UpperFilter and LowerFilter values within the 4D36E965-E325-11CE-BFC1-08002BE10318 key.
even if this thing doesnt work
replace the drive
Posted on May 18, 2008
Pioneer DVR-K17RS ATA ACER CODE=39
Code 39 for cd/dvd drives is a common problem, you need to edit the registry to fix this error. See these instructions on how to fix code 39.
Mar 28, 2009 | Acer Aspire 5610-4648 Notebook
from your description, it's windows problem.
You can either reload your operating system or edit the windows registry.
To edit the windows registry follow this step from Microsoft:
http://support.microsoft.com/kb/314060
Oct 05, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
it's windows issue, you just need to edit windows registry.
Follow this step from microsoft:
Jul 01, 2008 | Acer Aspire 5610-4648 Notebook
Laptop acer 7720 code 39
1. Remove the Upperfilters and Lowerfilters values completely from the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}NOTE: If you are getting a code 39 message, it may be that additional third-party filter drivers were added to UpperFilters and LowerFilters values in addition to Adaptec filter drivers. In that case, you may try to remove the non-Adaptec filter drivers first, leaving the Easy Creator filters in place to see if the Code 39 goes away. If you still receive an error code 39, 32, or 31 message, remove the Upperfilters and Lowerfilters values completely in the preceding key.
2. Restart your computer.
May 19, 2008 | Computers & Internet
Hi How old is this laptop? If it is brand new, then you should be able to send it back to acer. Its the problem with drive or mainboard not with the drivers.
Thanks
Mar 16, 2008 | Acer Aspire 5610-4648 Notebook
Hi, the error code that you have is a known issue from Microsoft that needs a registry tweaks. Error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)". You can click on this link for your reference http://support.microsoft.com/kb/929461/en-us
To resolve this problem, remove the affected filter drivers. To do this, follow these steps:1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or confirmation, type your password, or click Continue.
2. Locate, and then click the following registry subkey:
Caution There can be many instances of the registry subkey that is mentioned in step 2. You must make sure that you are in the appropriate registry subkey before modifying the UpperFilters and the LowerFilters values. To verify that you are in the appropriate registry subkey, make sure that the Default data value is DVD/CD-ROM and the Class data value is CDROM.
3. In the right pane, right-click UpperFilters, and then click Delete.
4. Click Yes to confirm the removal of the UpperFilters registry entry.
5. In the right pane, right-click LowerFilters, and then click Delete.
6. Click Yes to confirm the removal of the LowerFilters registry entry.
7. Exit Registry Editor, and then restart the computer.
This will surely help you resolve your issue. Good Luck!!!
Thanks
Feb 22, 2008 | Acer Aspire 5630 Notebook
i believe it's software problem, you can reload the operating system using alt+f10 or you can try this
Feb 16, 2008 | Acer Aspire 5610-4648 Notebook
Try to remove the device from Device manager, and then reinstall or upgrade the driver. If the error continues to occur, it may be possible to edit the operating system Registry to resolve the issue.
Click the Start button, press run and type regedit.
  1. In the Registry Editor window, in the left pane, double-click the HKEY_LOCAL_MACHINE folder.
  2. In the HKEY_LOCAL_MACHINE folder, double-click the System folder.
  3. In the System folder, double-click the CurrentControlSet folder.
  4. In the CurrentControlSet folder, double-click the Control folder.
  5. In the Control folder, double-click the Class folder.
  6. In the Class folder, click to select the {4D36E965-E325-11CE-BFC1-08002BE10318} folder.
  7. In the right pane, click to select the UpperFilters registry value.
  8. Press Del / Delete to remove the registery entry.
  9. In the Confirm Value Delete dialog box, click the Yes button.
  10. In the right pane, click to select the LowerFilters registry value.
  11. Press Del / Delete to remove the registery entry.
  12. In the Confirm Value Delete dialog box, click the Yes button.
  13. close the regedit window.
  14. Restart the computer.
Feb 11, 2008 | Acer Aspire 5100 Notebook
If you can't restored the driver, you should reload the operating system using Alt+F10 or using disks (not from windows, boot from disks)
In your case, it's look like you can't access the dvd in windows, i hope you can access in dos mode.
Jan 20, 2008 | Acer Aspire 3680 Laptop
Dvd-rw dvr-k17rs ata with aspire 5610z
Hey Google AUTORUNGUI.dll Download It And Then Just Copy The .dll to Your Win System32 Folder Replace It.
SHOULD WORK...........................................
Comment If It Doesnt I Will Tell You Some More Solutions
And Leave Your PC Info With Operating System OtherWise Really Hard ....................................................................................
Jan 08, 2008 | Pioneer Slim 4x ATAPI (DVRK12RA)...
Computers & Internet Logo
125 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
