Question about Philips 9P5034C 50" Rear Projection Television
Philips 9p5034c101 rear projection.chassis#ptv 835
Hello im joseph i just have 1 question about the convergence board out of this tv its a gr9d,willa gr8d work in this tv?also when it started up the screen would be half the size until it warms up,then its bowed in the bottem left hand corner ,is this all caused from the convergence board or something else. thanks for your help ,joseph
  • Philips Master
  • 8,617 Answers
Just replace the two STK392-110 Convergence ICs and that will correct the convergence. The small pic if its centerd in the center of the screen is usually caused by the opto-couplers being bad
Posted on May 18, 2008
The problem with my Phillips 9p6034 9102 with chasis number ptv 835 is that when you look at the screen straight on you can see the red green and blue lamps. When you stand up and look down at the screen...
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
Mar 30, 2010 | Philips Magnavox 9P6034C 60" Rear...
Philips 43p8341/37, ptv 914 chassis, led code blinks
Let's check and see if we can find the correct board with the problem. A good place to start is to disconnect the jumper jack 1516 [TV unplugged first]. Now plug in the TV, and power the TV on. If the tubes light up and shut down...then the small signal module is at fault. {this contains convergence ICs} Or it could possibly be the ssb [small signal board] is bad. Leave the set unplugged for a few days and plug in and power up this TV..It may work for a few seconds and go down again. These are two good places to start before you pull the boards out...and they are not easy!
Jan 23, 2010 | Televison & Video
60 inch tv philips projection sonnd in and out
Audio amps in a Philips PTV is one of the easiest sets to repair. To my knowledge all the individual parts are still available so I see no need to replace the entire amp. know what problem you have first, then we'll try and determine what you may or may not need? They had a board which is called the SSB ( small signal board ) that used to go bad creating similar symptoms like that. That board is the size of a 3x5 photo and stands up on the left side of the chassis, anyway let me know?
Feb 14, 2009 | Philips Magnavox 9P6034C 60" Rear...
Samsung 42" rear projection HD tv issue
1 they are either rebuilt or a defective returned to stock accidentaly
2 yes securly attaching it helps the heatsinks keep even cooler. no you don't need heatsink grease.
3 if the tolernace is very far out of wack then it woun't take long befor they blow. once you have instaled the new board turn on the set enter mute,1,8,3 then perfect focus on the remote let it do it's thing then shut off the tv and resart the tv and press perfect focus again.
Mar 05, 2008 | Samsung HCM4215W 42" Rear Projection...
Phillips model # 9P5034C101 Projection TV picture tube
I have a Philips 50 inch rear projection when I power up I have no sound or picture is it done or fixable?
Feb 13, 2008 | Televison & Video
Buttons won't work
You will probably need the service manual for both chassis to straighten that out. I am posting a link where you can purchase one manual that covers the entire series for magnavox PTV 836-PTV 835 it has 2,440 pages. It cost 19.99 and they will email it to you and provide you with free unlimited support that goes with the manual purchase. here is the link if interested in getting the service manual.
Jan 23, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips Proj TV 9P5034c101
call tech..converge eprom has to be changed from old to new board.
Nov 16, 2007 | Sony KP-53V75 53" Rear Projection...
Philips 9P5034C 50" Rear Projection Television Logo
166 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
