Question about Canon PIXMA MX310 All-In-One Printer
Paper Out message
I received the printer as part of an Apple promo for buying a desktop. I plugged in everything, loaded the drivers and the paper in the proper tray. But when I try to print I get a message to load paper and press ok. I've tried to reload, but still get the same message.
  • King Bombo May 24, 2008
    You are absolutely right! I did not read the manual and I was using an HP before. There seemed to be so many different paper loading possibilities and I never considered there would be one in the back. Thanks!!!
  • Anonymous Jul 20, 2008
    omg the same thing is happening to me and its getting me so mad because i havent even used it yet
Make sure that you are loading it in the back and not the front, I didn't figure this out until I looked at the manual. If you're used to HPs then you want to load in the front, but actually if you look behind the scan door, there is a black panel that you can open, and that's where you feed the paper. That thing in the front is actually where the paper comes out of. Go figure.
Posted on May 23, 2008
When attempting to print from the internet, the printer does not print and the message in Status says 'letter not loaded in any tray, however the paper is loaded in the tray. I have lifted it out and...
I would guess you are loading A4 paper in the printer.
It is likely the Page Setup within the web browser you are using is set to "Letter" size paper, hence there is a miss-match between the size of paper in the printer and the size of paper selected in your web browser.
The method of changing the paper size in your web browser will vary from operating system to operating system and web browser to web browser.
Try looking under the "File Menu" look for "Page Setup" ensure this is set to A4.
You may also need to check the default paper size selected within the printer driver, again ensure this is set to A4 (if this is the paper size you are using)
Apr 02, 2011 | Lexmark Office Equipment & Supplies
Printer is loaded with paper but get message
Although you really haven't given me enough information, I will posit and response for you.
A "Load Paper Error can be caused by the application telling you to change the "TYPE or SIZE" of paper that is in your paper tray.
For example, The application thinks you want the page printed on "Letterhead" paper, but it know that you have plain bond paper installed.
So you are sent a change paper type message.
The fix is to hit go and skip around that error.
The actual fix is to make sure that your printer driver, application and the printer are all set to the same size paper and type paper.
Don
Nov 05, 2009 | HP Hewlett Packard LaserJet P1005 Printer
Dell 926 All-In-One InkJet Printer
printer wont print anything. computer says no print documents pending even though ive clicked print a few times and on different programs and internet pages as well. printer will print only if i copy something press print test page from the printer itself but it doesnt print anything from the computer
Oct 15, 2008 | Dell 926 All-In-One InkJet Printer
Paper loading message says load paper even tho there's paper there
It sounds like the loader assembly motor has failed/is failiing in the printer. Considering the printer can be bought for $50 and the motor costs $25 and $45 labor to replace, you're better off just replacing it.
Oct 15, 2008 | Samsung ML 2010 Laser Printer
My printerisnotworking
check if all the plugs are plugged-in corectly if nothing happened you should install the printer driver
Sep 20, 2008 | Computers & Internet
'Load plain paper' message
Make sure that you have set the same paper type on both the printer driver and on the printer itself, using the on-printer menu. When I get this message, I usually had forgotten to change the paper type on the printer.
Jul 30, 2008 | Dell 3000cn Laser Printer
Mp830 shows paper output slot jam
I cannot receive faxes or print anything.
The message says that "there is no paper in the machine". There us plenty of paper in the machine and I push "OK" and get the same message
Jun 24, 2008 | Canon PIXMA MP830 All-In-One InkJet...
HP Officejet T45
reset the settings to default and try again. it sounds like it thinks there is an envelope or similar paper of that size loaded.
just rest everything to factory specs. you can download the software which includes the manual and help from hp directly.
go to hp.com,
search for the product,
follow the prompts
Feb 15, 2008 | HP OfficeJet t45 All-In-One InkJet Printer
I can neither send or receive faxes
hi 003 - Recording paper jammed when feeding from the 3rd cassette. Remove the jammed paper. (1) Open the Printer Cover. (2) Remove the jammed paper. (3) Slide out the Paper Cassette. (4) Remove the jammed or wrinkled paper and reload the recording paper into the paper cassette. Caution: Make sure that the paper is set under the clips of the Paper Cassette. You can load about 500 sheets with standard weight paper (20 lb. or 75 g/m2). good luck
Feb 23, 2006 | Panasonic Panafax UF-885 Plain Paper Laser...
Canon PIXMA MX310 All-In-One Printer Logo
307 people viewed this question
old marine
old marine
