Question about LG VX9400 Cellular Phone
LG VX9400 I was to disable the missed call alert on the LG VX9400. I have changed the tones for calls, incoming texts and incoming picture messages but I cannot figure out how to change the tone for missed call. I do not care to hear an alert when I miss a call.
  • sarkadiusz Nov 12, 2008
    I just don't know how to turn on the tone for missed call, I don't remember how I turned off this function ...if sameone can help
  • Dhonbo
    Dhonbo Jun 17, 2012
    contact your sevice provider on how to disable miss call alert
Just turn the phone on vibrate.
Posted on Jun 08, 2008
How do I change the incoming text notification to alert more than once, I sometimes don't hear the phone and need it to alert more often until the message is cleared. Is this possible?
Hi.hope this helps.Go to the setting menu of your phone.go to TONE setting..message alert tone and choose desired option if you want it to ring several times..
Jun 21, 2011 | LG P500 Cell Phone
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
Settings
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
options:
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
How to change alert tone for incoming text messages
go to the tone, click on options or set as the go to alert tone then it should say text picture or something else.
Mar 31, 2010 | Samsung Gravity SGH-T459 Cell Phone
I don know how to change my messaging tone on my sidekick lx
to change txt message tone:
go to text message main screen then press the top left button.scroll down to settings and click. then scroll down and ull see "new message alert" and there u go.
to the same for picture messaging.
ring tone:
go to phone
click the top left button
scroll down to settings, then general
scroll down the incoming call. and clik on that and u will have options
May 17, 2009 | Sharp Sidekick LX Smartphone
Ring Tones for test messages
You can change the text message alert tones but you have to do it by accessing the phone's file system via a data cable connected to your computer. Goto lg-vu.com and search for text alerts and you'll find detailed instructions on how to do it.
Apr 21, 2009 | LG Vu CU920 Cellular Phone
Blackberry Pearl 8110 message alert
You can change it if you go to profiles -> advanced and then choos your active profile. Ther you can choose the level 1 alert messages and change the ringtone or message tone for them.
best regards
Mar 15, 2009 | RIM Blackberry 8110 Cellular Phone
On normal nor silent profile no alert coming for incoming calls only
Try restoring the factory settings of your phone!
Go to : SETTINGS then FACTORY SETTINGS.. security code: just type 12345.
If still there is no tone alert, then im sure there is a problem with your phone's buzzer, or it might need to clean the contact of the buzzer insice the board. Just try this....
Kindly rate this up! thank you
Oct 15, 2008 | Samsung U900 Soul Cellular Phone
I would like to change text message ring tone but can only find how to change ringtone and not for text messages
I found the answer!! Go to Menu>Settings>Profiles, then go to Options>Edit. Push the right side of the square (that you use to navigate the menus) so that you're working with New Messages, not Incoming Call. Go down to Message Alert Tone, then go to Options>Change>Use Effect Tone. If you were trying to use an .mmf that you downloaded, or any of the preloaded ones that can be used as incoming call ringtones, you'd go to Use My Alert Tone here. There are 4 tones under Use Effect Tone, and you can play them and choose one, just like you do to play and choose your ringtone.
Jul 23, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Voicemail alert tones
I think that there is just a generic message alert tone setting applies for both vm and text. If your voicemail alert tone and message alert tones are the same, this is probably the case. I have searched the menu on my phone and haven't found any setting to change vm tone specifically.
Feb 14, 2008 | LG Shine KE970 Cellular Phone
Text Message alert???
In order to use tones other than the presets for text messages, you have to put new .WAV files on your phone. Any 8bit .WAV file will work; just connect with ActiveSync and navigate to your /Windows directory on your phone, and place the files there. You will then be able to use them as text message alert tones.
Aug 29, 2007 | Audiovox PPC 6700
LG VX9400 Cellular Phone Logo
161 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
