Question about ASUS P5K Deluxe/WiFi-AP, iP35, S 775, PCI-E , DDR2 1066/667/800, SATA II, SATA RAID, ATX Motherboard
Setup powering down after 5 minutes of being on.
I've got a P5K "Premium" Motherboard (with WiFi). I've hooked everything up and I can get to the Bios. But after about 5 minutes (give or take), the whole system shuts down. Everything appears to be functioning as it should. However, appearances can be deceiving. Just needing some starting points with what to check in the bios, or hardware, that I might have missed and can be done in less than 5 minutes.
If I've missed anything I'll add it on request. Thanks again for any help that can be provided.
    President:
  • 2,351 Answers
Enter you're bios & head to CPU section. There should be a section to check CPU & motherboard tempture. Sit back & watch the temp settings. (Check for over-heating which can & will shut down the system). It's best to do this with the case closed. Normal operation.
Did you add thermal grease between heat-sink & CPU. Same can happen if memory over-heats.
Posted on May 19, 2008
P5k-e front pannel audio not working
Make sure you check that the front audio cable is connected properly on your motherboard. You can see how it's supposed to be hooked up and where it is located on page 2-32 in either of the manuals I have linked up for you below. And if you haven't already make sure you have the correct audio driver installed.
Drivers & Downloads for ASUS P5K-E/WIFI-AP:
http://www.asus.com/Motherboards/Intel_Socket_775/P5KEWIFIAP/#download
Manual #1:
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5K-E/e3216_p5k-e.zip
Manual#2:
http://dlcdnet.asus.com/pub/ASUS/mb/socket775/P5K-E/e3501_p5k-e_wifi-ap.zip
Jun 14, 2012 | ASUSTeK COMPUTER Asus P5k-e/wifi-ap Lga775...
INTRUDED....SYSTEM HAULTED
there should be a little push button located somewhere on the case where the access panel meets the case itself, if pc is started with access panel off you will get that message, there are two ways of disabling that feature,... locate the little push button and there should be a wiring harness coming off of it going to the motherboard, just disconnect from the motherboard, or if you dont want loose wires in your system you can go into bios and disable it from there, should be under security or something similar to that, hope this helps
Jan 29, 2010 | ASUS P5K Deluxe/WiFi-AP, iP35, S 775,...
Can i get the latest motherboard model acer travel mate 5520g in india
better go for Asus P5K premium WiFi AP, cost effective, rock stady, value for money. All what one needs in and individual PC. Go ahead.
Jul 02, 2009 | Computers & Internet
Asus P5K-e Wifi/AP audio to drive surround speakers
Since the left and right speakers sound pretty good, there is no problem with the driver software, the problem is in the sound system itself. be sure to have your sound system be check by a professional technician
May 19, 2009 | ASUS Computers & Internet
I hook everything up and turn it on but i get nothing
if you just built a new pc, and hooked up your power button and reset button and mixed up the possitive and negitive wires you may have fried your motherboard. If you hold the power button for five seconds and your pc does not power down, it's fried.
Apr 11, 2009 | ASUS P5WD2-E PREMIUM GREEN INTEL 975X...
ASUS P5N32-SLI Premium/WiFi-AP
they dont sell them u need clal asus .com ask f they have one 5 10 bucks ok or else just dont use it alsoways install i o shild 1st then mobo
Oct 13, 2008 | ASUS AI Lifestyle P5N32-SLI...
Raid sys on p5k/epu
You are correct. The Asus P5K does support SATA RAID configuration. Page 4-14 in the user manual.
Congifuration [Enhanced]. Only real option is IDE. That does not mean the SATA drives will run like an IDE. The SATA's will function faster. In order to get RAID function you would need to have bought the Asus P5K Deluxe. http://support.asus.com/download/download.aspx?modelname=P5K%20Deluxe/WiFi-AP&SLanguage=en-us
Mike
Jun 06, 2008 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
Powering up
You need to remove the cap from 8-pin EATX12V connector and connect 8-pin EPC +12V power plug from your P/S, otherwise it will not work. Your power supply should support 8-pin EATX12V. If you P/S comes with 4-pin connector only you just use your 4-pin open spot and leave the cap on.
May 22, 2008 | ASUS P5K Deluxe/WiFi-AP, iP35, S 775,...
ASUS P5K Deluxe/WiFi-AP, iP35, S 775, PCI-E , DDR2 1066/667/800, SATA II, SATA RAID, ATX Motherboard Logo
76 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
