Internect connection My computer crashed and i called in and i reinstalled the software on my computer. Now when i try to setup a connection to the internet, it says it cant find one. How do i fix this?
  • Anonymous Jan 05, 2009
    where can you find the ethernet driver for the toshiba satellite p105-6187? wireless is working. ethernet is not
  • 22 Answers
Hi
Check in the computer management / device manager window and see if there are proper drivers installed for the network / wireless card. If you are running windows XP take note if there is a red x or a yelloe questionmark. If there is a red x then the hardware is disabled. Right Click on it and left click on enable. If there id a yellow questionmark then Right Click and then left click on update driver. If you are running windows Vista then you will see a black linr under the device. You can try the same steps. I hope this helps.
/Shawn
Posted on May 19, 2008
What do i do when i go in settings and press enable WMA playback to get the internect connection
you need to go into network connections in system settings to setup the wireless connection from the psp to the wireless router you have
Mar 19, 2011 | Sony PlayStation Portable (PSP) Console
Tip
How to repair hard drive
<span>Instructions</span> Things You'll Need: <ul> <li> <span>Operating software installation or build CD</span> </li> <li> <span>Boot-up disc</span> </li> <li> <span>System restore CD</span> </li> <li> <span>Backup tape</span> </li></ul> <ol> <li> Look for tell-tale signs that your computer is about to crash or fail. Extreme slowness, repeated blue screen and noise or clicking are sometimes signs that your computer hard drive is about to crash. When you hear the sound of clicking, scraping or grinding, immediately turn off or shut down your computer. Doing so will prevent any loss of data.<br /> </li> <li> Power down and then power up. Sometimes, hard drive crashes can be easily recovered by doing a power shutdown of the computer. Then, after waiting for a couple of minutes, power it back up again. The initial hard drive crash may not be too serious, but if it happens often, start performing a full system backup, if you haven't been doing so, to be able to recover your data should the inevitable happen.<br /> </li> <li> <span> <a><img src="repair-hard-drive-crashes-1.3-120X120.jpg" /></a> jQuery(document).ready(function(){ jQuery('#jsArticleStep3 span.image a:first').attr('href','http://i.ehow.com/images/a04/8f/3a/repair-hard-drive-crashes-1.3-800X800.jpg'); }); PC cable or component connection </span> Ensure that your hard drive and other internal components are seated properly. If Steps 1 and 2 do not work, you may need to open your computer's CPU to check on some of the drive connections. Sometimes connections get dislodged, especially if you move your computer box often. The symptom will manifest as if the hard drive has crashed, giving you a "disk error" when you try to boot up your computer. First, turn off your computer and unplug it. Then remove the case of your computer box. Press on each connector to connect it properly. Put the cover back again, plug the computer and power it back up.<br /> </li> <li> <span> <a><img src="repair-hard-drive-crashes-1.4-120X120.jpg" /></a> jQuery(document).ready(function(){ jQuery('#jsArticleStep4 span.image a:first').attr('href','http://i.ehow.com/images/a04/8f/3a/repair-hard-drive-crashes-1.4-800X800.jpg'); }); Boot from CD drive with a boot disc </span> Insert your boot disc and try to boot up your computer using the disc. Once you are able to do so, you can reinstall your operating system. After installing your software, proceed to perform data recovery using your ghost CD or backup.<br /> </li> <li> Use an emergency repair disc to get your computer to work again. Then restore from the last known good configuration.<br /> </li> <li> Reinstall your operating system using the installation or system restore CD that came with your computer when you first purchased it. It will take you through a series of steps that include formatting your hard drive, which will then erase your data. Do this as a last resort.<br /> </li> <li> Recover your data by using a restore and recovery software or using your most recent backup after you have reinstalled the operating system in the previous step.<br /> </li> <li> Reinstall your applications that did not come with your computer when you bought it. Some examples would be Adobe Photoshop, anti-virus software and movie-making software.<br /> </li></ol> jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); <span>Tips & Warnings</span> <ul> <li> Call technical support if you are unsure of what to do. They can walk you through the important steps. You can also take your computer to a PC technician who, for a fee, will do a system restore and data recovery for you.</li> <li> Make it a habit, even if your computer is healthy, to do a complete backup so your important data will not be lost.</li> <li> Never attempt to open your computer without first powering it off to avoid being electrocuted.</li> <li> Do not open your hard drive case; the components are so sensitive that even a single speck of dust may erase your data.</li></ul>
on Dec 23, 2010 | Computers & Internet
CAN'T RECOGNIZE MY SONY DCR TRV720 HANDYCAM CAMCORDER ON WINDOWS XP 5.1 SVC PACK 2 BUILD (2600) TOSHIBA SATELITTE 5005-S504 LAPTOP. IEEE ILINK CABLE 1394. NEW CABLE 4PIN TO 4 PIN. SONY SITE SAYS, DONT...
There is a Sony tutorial page for downloading video to computer at THIS LINK
You will need to select Windows as the operating system, then your camera type, then select the type of connection.You are strongly recommended to use i.Link (which everyone else calls Firewire).
There is Sony software called Picture Motion Browser that you can download (you will need the number from your original CD).
If none of that helps, perhaps the driver for the Firewire (IEEE 1394) port on the computer needs to be reinstalled. You can view this driver (if it is installed) by opening the control panel\system\hardware\device manager and looking for IEEE 1394. It should say if there is a problem or if it is working. You can force it to reinstall at this point.
Jan 26, 2011 | Sony Handycam DCR-TRV720 Digital Camcorder
My computer crashed. Need to reload Norton 360
Download it from Norton website setup with your code. Thanks
Sep 29, 2009 | Symantec Norton 360 for PC (037648318846)
How do i access a
When you installed it the first time, you had to call a Microsoft telephone number to activate the software.
You do exactly the same thing.
Hope it helps.
Aug 23, 2009 | Computers & Internet
Does not allow me to connect to pc/printer
try this, download the software and save it on ur computer and run the software, it would extract the software and  follow the steps below,
START>>RUN
in the RUN window type %temp%,  u would find a folder starting with 7z...... open that, u would find a folder called SETUP open that  then u would fine a folder called UTIL then CCC the u would find a file called UTIL L4,  double click on it and wait until it complete the setup and try once after it completes, restart the computer.
reinstall the software, it should work.
Regards,  raj_p5983
Jan 18, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I need to reinstall my cam after crash but i do not have the disk
Normal 0 Did you install the software with the camera connected to the computer? Disconnect the camera from the USB port and reinstall the software. When the program asks you to connect the camera, do so, and it should work. Hope this is of some help. Bud
Below is info for setting up Audio & Video to chat on line after you install , either Skype or a messenger program.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video shoud work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Jan 12, 2009 | Logitech Webcam
Orbi cam is crashing my computer
Just uploaded the driver for you. Works with XP and Vista.
Checked with Symantec antivirus software and it's clean.
Just download, double click to extract to a folder of your choice and run the Setup icon.
http://rapidshare.com/files/163576519/Acer_Aspire_5100_WebCam_Driver_XP.exe
Nov 13, 2008 | Acer Aspire 5100 Notebook
Firefox 3 Crashed
Reinstall a custom mozilla setup that includes the quality feedback(ticked).
Jul 27, 2008 | Computers & Internet
Installing photo express
Knight, as i have understood when you reinstall windows XP, it can't load photo express. This is probably because you had installed Photo express in your the same drive you had installed your windows. When you reinstall windows that drive is completely formatted and thats why it can't load the software.
Make sure you install photo express in some other drive. You can also rip the setup on a dvd so that you could reinstall it when your window crashes. For window crash, you might like to use an antivirus software like Avast.
I hope that must solve your problem. You might also like to read Photo express manual for specific instructions if it doesnt work.
Nov 22, 2007 | Adobe Photoshop 7.0 for PC
Computers & Internet Logo
118 people viewed this question
David Payne
David Payne
