Dell Dimension 5000
Replaced existing hard drive (SATA) with new Hitachi 400 SATA but system won't boot - Error msg - Drive not found I got a WD 400GB drive to replace my failed Maxtor drive in my Dell Dimension 5000. I have connected the new drive but I get the error message that:
Error auto-sensing secondary hard disk drive0
Strike f1 key to continue, f2 to run the setup utility.
In setup, the WD drive is detected, but the capacity is not known. When I try to install Windows XP using the Dell Reinstallation CD, it ends up with a 0x0000007F error (which I think is because it can't read the hard drive).
Any thoughts?
  • twist3d May 19, 2008
    Thanks for helping.... you'll have to forgive me. Can you explain what you by the ntfs system? And what does using the long format system not the quick format mean?
    Also, I'm not quite sure how to install the bios update... I've downloaded a file from Dell via FTP but it's a .exe file - not sure that will run without an OS.
  • Anonymous Mar 27, 2014
    my laptop says secondary hard drive module could not be found. so, might be the problem here. please help.
    Scholar:
  • 119 Answers
You problem is most likely that your bios is out of date. download the latest bios updates for your motherboard and then when you install windows format you HDD with the ntfs system (using the long formatt system not the quick format). Then you should install the bios update. then your mboard shoud no longer have the problem of recognising your large capacity HDD. thanks
Posted on May 19, 2008
How can i fix error code 2000-01 42 Validation 51532 Msg: Hard Drive 0 - S/N WD-WXM1A61M4533
Dustin Larmore,
The error means that the hard drive is defective or broken You will need to have it replaced.
The Inspiron N4110 / N4120 / 14R system uses Serial-ATA II(SATA II) hard drives.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 01, 2014 | Dell factory recertified inspiron...
SATA Primary hard disk drive failure
Sounds like your hard drive has failed and will need to be replaced. You will need to make sure you have all the recovery cd/dvds Dell sent with the system; or you created when you got the system. The new hard drive will be completely blank, so you will have to install the OS, drivers, and other software from these CD/DVDs.
Hope this helps
Apr 25, 2012 | Dell Dimension XPS 400 PC Desktop
Replaced 80gb with 500gb sata wd green also have 500gb sata as second drive bios level 10 sees both in setup but nothing is available in boot including well used cd drive- system dell dimension 4700- any...
Did you remember to set one drive as a master and the other as a slave driver?
To do so. Removed the drive and look on either the front or back and it'll give you the jumper set up.
Master is the primary boot drive and the slave will the be media, documents drive
Aug 22, 2011 | Dell Dimension 4700 PC Desktop
I'm trying to install WD Caviar Green 1TB in my Dell Dimension 4600. It appears as though the exhisting hard drive used a SATA connection w/molex power connection. I have tried downloading the WC...
I BELIEVE THAT WD PROVIDES A CD WITH "WD DATA LIFEGUARD UTILITIES." IF YOU USE THAT DISK AND SELECT "DRIVE TO DRIVE COPY" SELECTION. THIS SHOULD CREATE A CLONE OF YOUR ORIGIONAL DISK. SELECT THE NEW DRIVE TO BOOT FROM EITHER IN BIOS SETTINGS OR FROM THE BOOT SELECT "F12" OPTION.
THE PC SHOULD BOOT FROM THE NEW DRIVE IF SELECTED
ED P
Aug 09, 2010 | Dell Dimension 4600 PC Desktop
I installed a new WD hard drive and now upon boot
I would recommend you to change the CPU fan as it may nt be working fine and that should resolve the problem.
Mar 23, 2010 | Dell Dimension C521 PC Desktop
Hello, I have a Dell XPS 400 system that has a bad hard drive. So I went out and bought a new SATA drive, and it's not detecting it upon boot. When I go to the boot menu on F12, it says something about...
Was the original drive also a SATA? If not, then you would need to enter the bios setup and enable the onboard SATA channels. If the bios had gotten defaulted, as from a dead CMOS battery etc. it could have also caused your original SATA drive to be inaccessible.
Nov 24, 2009 | Dell Dimension XPS 400 PC Desktop
Dell Dimension 5000
please reset the bios..on dell logo..press f2..press num lock, caps lock ,scroll lock so that all three are on. press alt e
press alt f
select the option that says
save changes and exit
your hdd should get detected.
please post back if it does not work so that i can check out fir further options
May 04, 2008 | Hitachi ( 0A30229-20pk) 400 GB Hard Drive
Dell Dimension 3000 reformat trouble
please re partition the hard disk and install the operating system. if the same error continues then change the ram and try
Jan 28, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 5000 - Installing extra Hitachi 500GB SATA Hard Drive
you need to turn it on in the Bios so the computer sees the drive, then format it.
Jan 20, 2008 | Hitachi ( 0A30229-20pk) 400 GB Hard Drive
Computers & Internet Logo
951 people viewed this question
David Payne
David Payne
