Epson Aculaser C1100 Printer
Problem for Epson Aculaser C1100 Printer
White lines when printing
By Maruba on May 18, 2008
When I print, no matter what colours, I'm getting a white line down the right hand side of the page. I've tried cleaning the printer but the problem is just getting worse. Someone tells me this can be a common problem with the Aculaser C1100 printer. Is that the case and anyone know how to fix it? I don't think it's due to age as I've only had the printer around 18 months and it's not been overly used. Thanks!
Same Problem
Jun 18, 2008
-   I'm having the same problem, white line on the right of the printed page. I tried to clean the PCU (it's almost new) but without success on solving the problem. Can anyone explain me how to clean the laser glass? I don't know how to do this. Thanks.
-   shoko
Jun 12, 2008
-   The printing is fading on the right side of page. -   Petethepole
Best Solution
posted on Jun 29, 2008
Very Helpful)
Inky
Rank: Wiz  Epson Expert
Rating: 85%, 950 votes
Open the front door
On the right side you will notice a handle that you can pull OUTWARDS
On the Outside Right half way down towards the back you will see a removable plastic plate - remove it
Behind plastic plate is a handle, pull it in and out several times. This will wipe any toner off the laser glass
Chances are the white band will now have gone.
If you need further help, please let me know so I can help you fix the machine.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on May 23, 2008
Somewhat Helpful)
labatt
Rank: Master
Rating: 91%, 26 votes
white lines means no ink was put on paper. O.k lets go step by step with elimination
1. If the line is stationary then,
---is your PCU o.k and without any discolouration, especially on the side corresponding to the white line
---Is some object (clips,staples paper) blocking the laser beem passage to the PCU.
have u tried cleaning the Laser shield glass.
If u have been cleaning the PCU alot. give it a rest it is not the problem.
check you teflon paper, any marks or scratches corresponding to the said point.
confirm whether the lines are stationary or migratory
labatt
Was this helpful?
Yes
No
Popular Solutions for Epson Aculaser C1100 Printer
Questions and Unsolved Problems for Epson Aculaser C1100 Printer
Do you recommend Epson Aculaser C1100 Printer?
Answer
Answer
Printing several pages in black results in 'ghost' print - tried cleaning printer head with blue... (More)
Answer
Toner cartridge will not clip/fasten in
Answer
C1100 getting MP tray and cover E paper jam message from epson status Monitor (as well as low toner... (More)
Answer
vertical lines in photo copy and scanned documents anytime you put documents through the top portion... (More)
Answer
toner build-up on fuser unit why? what to do? I get build up of toner in lines on the fuser transfer... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
in , CA
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
