Question about RCA OPAL M4001 MP3 Player
O battery power and is hooked up to computer
I plugged in my mp3 player like normal and my battery was drained and i cant get the battery charged through my computer help
  • 8,596 Answers
Could be electrical/interior - need to be replaced; but try this first: disconnect the player from the computer, turn it off Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 23, 2008
Wont turn on unless plugged into computer
Hi it very much sounds like the on board batttery is not charged up, (not charging) hence when you plug into the PC it gets it supply from the USB 5Volts and plays as normal
Apr 15, 2010 | SanDisk Sansa Clip MP3 Player
When i plug my mp3 into the computer it won't even charge
Re-seat the battery. You can pull the battery and re-seat it in place.
Have you tried all the normal stuff? Hook up the player on the rear of the computer these ports on the rear are more suited for power requirements of charging devices. Next do you have the right USB cable for the player, many may fit but they are not all alike. Have you tried to reseat the battery?
  • Then try all this.
Reset the device.
  • 1. Press and hold the Power/Menu button for approximately 20 seconds.
  • 2. Release the Power/Menu button.
  • 3. Press the Power/Menu button again to turn on the player.
Then you can do what is called a power cycle.
  • Remove the battery.
  • 1. Connect the device to the PC.
  • 2. Leave the device connected for about 2 minutes.
Turn on the device
  • 1. Disconnect the player from the PC. and Quickly
  • 2. Insert a fresh AAA battery into the player.
  • 3. Turn on the player.
Feb 07, 2010 | SanDisk Sansa m240 MP3 Player
Trying to charge a sansa sandisk ain't working.
Reset the device.
Turn on the device
Feb 05, 2010 | SanDisk Sansa m250 MP3 Player
How do i charge my nextar mp3 player
yea u can recharge your mp3 player all you do is use the cord that u use to transport music to the mp3 hook it up to the computer put your mp3 player on it then just leave it alone && it will be get charged
[smart]
-adriana tashay
Dec 26, 2009 | Nextar MA7151B MP3 Player
Charging mp3 player
If your MP3 has an inbuilt Li-Ion battery (e.g. no compartment for a standard/Ni-MH AAA battery), then connecting the player to your computer will normally charge it - this is the case for the PD-6070 'stick' player. Your player will also indicate that it is being charged (or not charged!) via the battery level/power indicator which is located on the top RHS.
Hope it helps!
Dec 19, 2009 | MyMusix PD-6070 MP3 Player
I unplugged my sansa clip while it was writing is there anything i can do to fix it holding the power switch to reset it does not do anything and when plugged into the computer it is not recognized by the...
How to reset the Sandisk Sansa Clip MP3 Player:
Hold down the Power/Resetbutton for about 15 seconds to perform a normal reset.
Otherwise, drain the battery completely by forcing it on until the rechargeable battery is completely drained: this will reset the unit completely.
Dec 19, 2009 | SanDisk Sansa Clip MP3 Player
Mp3 player won't cut on
when you plug a charger to your mp3 it plays, because you power from a charger, part of current goes to aset and make it play and also charge your battery.
when you unplug it from charger than battery does not manage to provide power to set.
get a meter and set at amps dc. and check your battery current out side.
i suspect that your battery is not holding charge.
Mar 28, 2009 | Samsung YP-K3 MP3 Player
Computer Freezes
Make sure you have installed Philips Device Manager from the product CD.
With the player powered off:
Press and hold VOL+ whilst connecting to the PC.
PC will show drive as Recovery Device (or similar) and device manager will start and show "Your device has an error...."
Click repair and follow the on-screen prompts.
When prompted, disconnect the player and power on.
Player will show "Loading" and then shut down.
Power on again.
Player will show "Updating" and then shut down again.
Player can now be powered up as normal.
Restart
Feb 24, 2008 | Philips GOGEAR SA6045 MP3 Player
Will not charge
i cant get music to go to my mp3, its hooked up to the scomputer, and i dont know how to transfer music
Jan 15, 2008 | Insignia NS-DA2G MP3 Player
Won't do anything after charge, Please help
USB is a 5 volt connection, generally fairly weak and weaker still on older pc's either get an ac power adaper or connect to a powered usb hub.
Aug 07, 2007 | SanDisk Sansa e260 MP3 Player
RCA OPAL M4001 MP3 Player Logo
22 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
