Question about Universal Remote Control MX-500 LCD Remote Control
How to set codes on my px-rc1 remote
I lost my codes book
  • 12 more comments
  • Anonymous Jun 07, 2008
    px-rc1
  • Anonymous Jun 20, 2008
    need codes
  • Anonymous Jun 21, 2008
    code for sony?????????
  • Anonymous Jul 07, 2008
    GBKMB.
  • cula8erbaby Jul 18, 2008
    I need the code for a JVC tv.
  • diggittydogg Jul 31, 2008
    i lost my codes book
  • pappuyar Aug 11, 2008
    I have a Samsung Dyna Flat. I have a remote PX-RC1. I have lost the code book. Now plz tell me what is the code and how to set it?
  • Anonymous Aug 23, 2008
    how to program px-rc1 to an electrohome dvd? the tv part works, but the dvd, attached to tv doesn't
  • faxprofessor Sep 05, 2008
    JUujst looking for codees & instructions for my PX-RC1
  • Anonymous Sep 22, 2008
    just want to set up remote px-rc1
  • Du-ron Nov 06, 2008
    lost my code book
  • Anonymous Nov 22, 2008
    the px-rc1 in't working
  • familypride Dec 09, 2008
    i need the codes for the electrohome dvd for my PX RC1. I also bought mine at XS Cargo. Thanks for any help!
  • sankharva Dec 17, 2008
    According to the instruction of the booklet of PX-RC1, I did everything but it didn,t work at all for my VCR.
Hey finally I found myself how to set the code... I have a PX-RC1 kind a noname remote at XScargo anyway...
Press SET BUTTON and at the same time, the appliance you want to set( TV, VCR,Aux...etc). The LED shoould stay on.. then press on the SET BUTTON again ... the led will blink fast... then press ( in front of TV, of else).. the POWER BUTTON to see what happens, if nothing happens, then press the +CHANNEL BUTTON once, and press power again. Repeat this until it turn off. THen press the appliance button (VCR,TV,AUX, etc...), this will stop the LED to blink and your appliance will be set.. I guess if it doesn't work good, go further onto the code with the +CHANNEL BUTTON (better count it in case you go too far, for myself I went too far and tried to use the -BUTTON and didn't work)
GOOD LUCK GUYS,
Posted on Sep 11, 2008
  • 4 more comments
  • glennlewis Aug 28, 2010
    This worked for me I am checking out a Koss dvd system for a friend Thanks for the info
  • a171717a Feb 04, 2011
    Thanks buddy,it really worked for me.appreciate your help...thanks again...God bless..!!!
  • Leyzabelle Gabuat Jun 23, 2012
    Hi! This worked for me! I'm Leyz/leheart from the Philippines. I'm typing in CRKing Universal Remote Control PX-RC1 so that these keywords will show up if someone's looking for it too.
    Mcneileric is right!
    Real TV should be on! On the remote, press and hold the SET and DEVICE TYPE (in my case TV) at the same time. (Note: SET button is not any other button but the one with the word SET on it. You might have been searching on youtube and found that they are pressing other SET button but do press the SET button with the SET word). Then press SET again. Press the POWER button then + CHANNEL button then POWER button then +CHANNEL button then POWER button then +CHANNEL. (This process is so the remote could look for the code while you are pressing the +CHANNEL and the POWER is to set if the tv will turn off/respond to the remote). Do this repeatedly until the time that when you press the POWER button, the real TV turns off which means the real TV now responds. You will be shocked so DON'T press the +CHANNEL button anymore as this will instruct the device to look for another code. Instead, press the DEVICE TYPE button (TV for my case) to finish the set up.
    NOW YOU CAN USE the REMOTE! Press the POWER button and this will turn on the TV!
    Again...
    TV on
    Press and hold SET button (yes, the button with the word SET) and DEVICE type button (TV/VCR,etc) at the same time for about 3 seconds
    Press SET again
    Press Power to check if the TV turns off
    ^^If nothing happens, press +CHANNEL to search for code
    Press Power again to check if TV turns off^^
    If nothing happens, repeat the step between ^^ and ^^
    If the TV now turns off after pressing the POWER button, press the DEVICE type button to finish the setup.
    Mcneileric, THANK YOU!!!!
    Hi! This worked for me! I'm Leyz/leheart from the Philippines. I'm typing in CDRKing or CD-R King or CDR King Universal Remote Control PX-RC1 so that these keywords will show up if someone's looking for it too.
    Real TV should be on! On the remote, press and hold the SET and DEVICE TYPE (in my case TV) at the same time. (Note: SET button is not any other button but the one with the word SET on it. You might have been searching on youtube and found that they are pressing other SET buttons but do press the SET button with the SET word). Then press SET again. Press the POWER button then + CHANNEL button then POWER button then +CHANNEL button then POWER button then +CHANNEL. (This process is so the remote could look for the code while you are pressing the +CHANNEL and the POWER is to see if the tv will turn off/respond to the remote). Do this repeatedly until the time that when you press the POWER button, the real TV turns off which means the real TV now responds. You will be shocked so DON'T press the +CHANNEL button anymore as this will instruct the device to look for another code. Instead, press the DEVICE TYPE button (TV for my case) to finish the set up.
    Again...
    TV on
    Press SET again
  • palmer_kevin
    palmer_kevin Mar 14, 2013
    worked great thanks for the info..
  • Jody Barkhouse
    Jody Barkhouse Jun 26, 2014
    Worked great for me as well. Thank you mcneileric.
Listen to what mc neileric said to do if you do not have codes,,,,,,,just wanted to add that it might take some time to get appliance to work.....it took me over 20 minutes of +channel up then power button one channel at a time but finally solved remote issue.....thanks
Posted on May 29, 2009
I lost code book
Posted on Jan 13, 2009
I HAVE A PX-RC1 REMOTE AND I CAN NOT GET IT TO WORK WITH A MEMOREX MT 1136 DOES ANY ONE HAVE ANY IDEA HOW IT WILL WORK......MY EMAIL IS ...r_retford@msn.com
Posted on Nov 07, 2008
  • 4 Answers
Again...
TV on
Press SET again
Posted on Jun 23, 2012
5 Suggested Answers
SOURCE: universal remote -need code for px-rc1
i need code for my sony tv
Posted on Dec 06, 2009
  • 3 Answers
SOURCE: px-rc1 remote lost code book
I used the code 0030 to program a PX-RC1 remote for my Apex tv/dvd combo.
Posted on Jan 01, 2009
SOURCE: code for panasonic tv on PX-RC1 remote...
003/019/024/114/148/175
Posted on Feb 17, 2009
  • 252 Answers
The MX-500 has a learning mode that you can use. Press MAIN and ENT together for 3 seconds, then press the P-PRO button. Select the device then button you wish to program on your remote and then with both remotes facing each other (IR ports must be able to communicate) press the button on your other remote.
You can also download a copy of the book here...
http://www.universalremote.com/resources/pdfs/MX500manual.pdf
Posted on May 28, 2009
I have a universal remote control px-rc1 and need the codes for a RCA tv
i went online entered my universal remote model number and name found book of codes for my remote unit it had all codes for all types of TV brands
Nov 12, 2011 | RCA Televison & Video
How do i setup my remote for my tv . tv is GE & remote is px-rc1
when you buy a remote they give you some instructins and a list whit codes, follow these instructions or try on this site to ask ather instruction: https://www.2instructions.com/search.php?cmarque=PX-RC1&modele=PX-RC1
Feb 14, 2010 | Universal Remote Control MX-500 LCD Remote...
NEED HELP GETTING THE USER GUIDE FOR MY REMOTE/Model # PX-RC1?
For clarification, may I know the Brand of your remote.? There was several model to PX-RC1..
Thanks
Oct 03, 2009 | Televison & Video
Lost codes for PX-RC1 Remote for GE tv
Codes are:
051, 054, 061, 065, 068, 083, 100, 108, 113, 131, 141, 143, 145, 146, 176, 180 184, 187, 222, 235
Jan 26, 2009 | Televison & Video
Universal remote
Jan 13, 2009 | Universal Remote Control MX-500 LCD Remote...
Lost px-rc1 manual
press and hold "set" then "TV" (or whatever device) then press "set" again. Point the remote at the device and press repeadly the power button until the device turns on. Press "TV" again to complete the programming procedure.
Also here..
http://www.fixya.com/support/t351864-silly_remote
Dec 29, 2008 | RCA F32650 32" TV
Hi my name ghanshyam patel i buy one 8-in one remote px-rc1 in xs cargo. i lost cod list book . my tv brand name is sanyo. pl u help me find the code of this remote to my tv thanking u
http://tv.manualsonline.com/manuals.Go to this site and enter your info and download your manual giving all info on codes and how to program.RICHARDM69
Dec 07, 2008 | Philips Magnavox Learning Universal Remote
Universal Remote Control MX-500 LCD Remote Control Logo
11,612 people viewed this question
Top Universal Remote Control Televison & Video Experts
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
