Question about Sony Playstation 3 (PS3) Console
PLAYSTATION3 60GB YELLOW LIGHT OF DEATH
INTRO : My dad bought a PS3 (60 GB) for me in may 07 from an authorised sony dealer. I opened the box and put my PS3 in my almirah (without the box). I first used it last month because I had my board exams.
THE PROBLEM: On turning the PS3 on, it starts, recognizez the blu ray disk (i hav smackdown vs raw 08) and says that it has to update its software (1.93). It completes downloading and then when it is about to update..... the YELLOW LIGHT OF DEATH comes on then turns RED and BLINKS THRICE.If I then turn it on it again.....IT STARTS NORMALLY but again goes off in a shorter duration of time. I got frustrated and did not try operating it for 3-4 days. Then when I tried.... It SUCCESSFULLY UPDATED the software and was about to install it.... when 30% installation was Complete..... IT WENT OFF AGAIN....(YELLOW LIGHT). When I again tried to operate it..... it STARTED but at 37% installation....IT WENT OFF AGAIN(SAME YELLOW LIGHT-3 TIMES RED BLINK).......... I AM CONFUSED.........PLEASE HELP ME.....
  • 5 more comments
  • Sidd661992 May 19, 2008
    I have NEVER PLAYED my PS3..... Never got the oppertunity to.... each time I tried it went out as i described above.
    I store my PS3 in an open room with an Air-Conditioner. So... Maybe it's not the ventillation problem but an internal fan problem...I'll visit my nearest Sony World...Is there anything else I should check/do before taking it there?
    Thanks a lot for the help......
    Regardz,
    Sid
  • Anonymous Nov 05, 2008
    I'd like to know if Sony will not fix their defected product then the consumers should get together and take them to court!!!!!!!!!!!!
  • frottobean Feb 16, 2009
    hey i have the same problem. i turn it on then within a few seconds it gose from grenn , red, yellow then blinking red. it overheated back in september or october and i havent touched it at all. should i try and buy a new hdd and put it in.
  • klmjnh Apr 11, 2009
    it happens to me too.since i live in india sony said they wont help me.even i have yellow light of death
  • Anonymous Apr 11, 2009
    how do you fix the HDD on a ps3?
  • Anonymous Apr 16, 2009
    omg there is no free support anywhere
  • 3 Answers
How long do you play your ps3 befor updateing the ps3 because the yellow light and the red blinking light comes up when its too hot it says it in the manul and it says to leave it alone for a few hours and then try again. if it still dosent work use your warrnty to fix it
Posted on May 19, 2008
    Filmmaker:
    Uploaded 5 video answers.
  • 42 Answers
The PS3 yellow light of death is generally caused by a hard drive error, which will need to be addressed before your console is able to work again like normal. Often the cause is a corrupted portion of space on your HDD that your PS3 is trying to use but simply can't.
Here are two methods you can use to try and fix the YLOD on your console:
Firstly, you will want to try and perform a default settings reset on your PS3. Here's how to do this:
  1. Place your PS3 in stand-by mode.
  2. Hold down the touch power button until you hear a series of beeps.
  3. Release it after you hear 3 long beeps, then 2 short beeps, then one more long beep.
  4. A screen will come up with instructions, follow them until you are presented with a list of 6 options. Select option number 2.
  5. Follow the on-screen instructions again.
If that does not work, then you will have to reformat your PS3's hard drive. Please note that this will wipe all the data, but it is the only way to recover a corrupted HDD. Here's how to do it, taken from an article I wrote:
  1. Remove your PS3's hard drive.
  2. Connect it to your PC.
  3. Goto 'Control Panel' -> 'Administrative Tools' -> 'ComputerManagement', then under 'Storage' click 'Disk Management' (if you areunable to find this then search your computer)
  4. Format the driveinto FAT32 if possible; if not you will have to format it into NTFS, oruse a third-part program to format your console into FAT32 for the bestresults.
  5. Remove the drive from your PC, reconnect it to your PS3.
  6. YourPS3 will boot up and prompt you to install the system software from aUSB thumb drive. You can get this software from the Sony website underthe useful links section of this website.
  7. Follow the instructions, and you will be back to gaming again with any luck.
Click the following link for more information about how to carry out a PS3 yellow light of death fix yourself.
Posted on Aug 18, 2010
The Yellow Light Of Death either indicates Overheating or HDD Failure.
In my case it was HDD Failure.
Posted on Oct 27, 2008
Maybe it can be a HDD problem
Posted on Oct 03, 2008
I got the same problem what i know i thatits summit to do with the HDD and not overheating , ive still got the problem.
Sidd, if it is overheating you are experiencing, where exactly do you have the PS3 stored? Ive heard of people having this issue when they have the PS3 sitting in a very tight fitting unit where basically the PS3 cannot get any air and quickly overheats.
I would suggest moving the PS3 into the middle of your floor temporarily with no obstructions to the fans, and see how long it stays running under those conditions. If it overheats and dies quickly in those conditions you may have a hardware issue, but if it stays running this time, its likely the storage setup you have the PS3 in.
I updated the firmware to my PS3, but inorder to do this it takes a lot of work, beets buying another ps3
  • ijijhkjk
kj
k'
k'
k'
k'
Posted on Sep 28, 2008
Concole will not work at all green light comes on then turns yellow then red nothing works any suggestions?
Hi. Your Playstation has the Yellow light of Death (YLOD). If under warranty I suggest you send back to SONY no matter how long it takes. Unfortunately this on has a 50% chance of getting repaired by a process known Re-balling. The repair place will heat up your motherboard until the processors inside the PS3 are re-balled or re-aligned. This is similar to the 3 Red Rings of Death From the X-Box. You can catch a video on you tube. Just type in PS3 YLOD or PS3 Yellow Lite of Death. Hope this helps.
Oct 06, 2011 | Sony Playstation 3 (PS3) Console
I got the yellow light of death how do i get my game out
here is a video of how to open and close the drive wither you can do that get someone to do if for you and get it fixed
Apr 12, 2011 | Sony PlayStation® 3 (60 GB) Console
My playstation 3 turned off and when i try to turn it back on it is flashing yellow once then quickly flashing red would there be any possible chance of getting a free repair
Maybe, I'm not sure if Sony has extended the warranty on the PS3 Yellow Light of Death. I would call Sony if I were you and ask. And before you wonder, you will get the same system you bought back. I had a repair done and was specific on getting my system back. Thanks.
P.S. Stand proud, you are one of few who still have the 60gig PS3!
Nov 01, 2010 | Sony PlayStation® 3 (60 GB) Console
The yellow light of death who can fix this problem?
2 days ago i got the yellow light of death when the 2.50 update came out rendering my ps3 to a 500 dollar paperweight.
I contacted sony about my problem and my console is under warrenty so it would be fixed for free so it didn't bother me to awful bad
the are sending me a box right now but i have fixed the yellow lights on my ps3 myself and it works now without a hitch
What i did is i took my 120 gb hard drive out of my ps3, Slaved it to my cpu tower and did a full format of that drive
then i took my hard drive and put it back in my ps3 and it ask me for the system software 2.50 disk so i downloaded the 2.50 update off of the ps3 website installed it and boom my ps3 work like new
this worked for me so far and have been playing my console for 6 hours now with out a hitch
maybe this will work for some of u aswell
Oct 07, 2010 | Sony PlayStation 3 40GB System
Yellow light wont turn on
Oct 03, 2010 | Sony Playstation 3 (PS3) Console
When i start da playstation it starts den turns of again with a yellow light flashing then a red light starts to flash
Sep 03, 2010 | Sony Playstation 3 (PS3) Console
Playing game for 30 minutes. Playstation suddenly switches to standby. When I put it back on switches to green light for seconds then yellow light and then back to red (standby). Disk brand new, now stuck...
Aug 14, 2010 | Sony Playstation 3 (PS3) Console
Turn it on and a yellow light comes on and the ps3 turns off
This error has been dubbed the "Yellow light of death", named after the Xbox 360 Red light of death. Over time and many thermal cycles a connection to one of the major chips on the PS3 motherboards can become weak, eventually it will stop conducting all together and then the YLOD will occur. The only solution to this error is a rework or reball to the problem chip.
GATpro
Jun 05, 2010 | Sony PlayStation® 3 (60 GB) Console
My ps3 beeps turns yellow then flashes red whats wrong with it
You have the yellow light of death, Its sorta like the red ring of death on the xbox. It means that your ps3 has gotten overheated you're prolly gonna have to send it into sony.
May 05, 2009 | Sony PlayStation® 3 (60 GB) Console
Yellow light on PS3, unable to be switched on. Have already replaced Hard Drive, problem still exists.
Its the yellow light of death (same as the circle of death for 360).
Unfortunately this means there was a hardware failure. You can only have it replaced by Sony. If it is still under warranty, send it in. If not, contact Sony and see what they can do.
Apr 16, 2009 | Sony PlayStation® 3 (60 GB) Console
Sony Playstation 3 (PS3) Console Logo
2,370 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
