Question about Roper REX4634KQ Electric Dryer
Roper dryer I have a roper dryer that is less than 2 years old.It takes 2 to 3 cycles to dry a small load. The vent line has been cleared and cleaned along with the vent filter. I even went as far as to purchase a vent filter box that you use if you cannot vent to an outside wall. It is no any better. Any suggestions other that buying another dryer?
    Genius:
  • 1,028 Answers
If you are sure vent is ok ..did you try a load with vent disconnected??...there is a chance there is something blocking air flow in lint screen/blower housing ..remove the 2 screws under filter remove all back screws remove 4 screws holding blower housing in place ..you then can pull complete housing out back
Posted on May 19, 2008
Takes too long to dry clothes
You may have a clogged air vent, check that the air vent hose is not smashed, if it is not smashed, have your dryer vent cleaned professionally, all the way from where the dryer connects to the wall to where the vent leaves the home,
Recheck the dryer operation, dryer vents should be cleaned every other year for optimum performance
Feb 16, 2014 | General Electric GTDP490EDWS GE 7.0 Cu....
Takes several cycles to dry
It takes forever to dry a load of clothes. Drum
Have you checked your vent for blockage? Over time, lint build-up in the vent and in the back of the dryer makes your drying time longer and longer. Unplug the dryer, pull it out and disconnect the vent. Using a flashlight and a vacuum, clean out the back of the dryer that connects to the vent and the vent itself. If you have a long vent line, you'll need to find a away to clean it out to clear any blockage. I use a hand-held plumbers snake that rolls up and pulls out as much length as needed. Then spin it around in the vent to knock off lint attached inside the vent tube walls. It may be easier to do this from the outside, but you can do it from the inside too. Check your outside vent cap for blockage and make sure the vent flap outside is not stuck closed. Also make sure when you push the dryer back into place, that you don't squish the vent tube, if it is made of plastic or foil. After reconnecting the vent, turn on the dryer. The air flow may blow out the lint you have dislodged with the snake. Clean out as necessary at the outside vent. I have a long vent line on my dryer, so I have do this annually. This has helped shorten my dry time every time I do it. Of course, cleaning out the filter regularly, does help too. The more often you clean the filter, the less lint that will build up in the vent . Hope this helps. Douglas
Jul 17, 2010 | Maytag MED5600TQ Electric Dryer
Sensor dry takes a couple of times to dry clothes
My mother has one of these machines. Less than a year old. I think that is just the nature of these dryers. The vent goes right through the wall and is a 2 foot run. I know their are no restrictions of any sort and the lint filter cleaned after every load. I have found that if I put it on More dry it does fairly well.
Apr 17, 2010 | Roper REX4634KQ Electric Dryer
Dryer not drying in one cycle. takes multiple cycles do dry one medium size load. the machine is less than a year old and we clean the filter after every load. checked the vent hose and its clear with no...
HI, Check the following to address this issue further.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
Nov 23, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
My Dryer not that old, takes all day to dry a small load.
Check the following areas thoroughly to address this issue.
1. Venting
2. Thermostat
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Aug 31, 2009 | Whirlpool LER5636P Electric Dryer
Dryer gets hot but wont dry clothes
Do you know if the dryer vent is free of obstructions?Check outside where the dryer vents outside ,and see if the air is weak or flowing freely.If it is not clogged the air should be pretty strong from the vent outside.If it has blockage it will definitly take longer to dry your clothes.
May 17, 2009 | Roper RGX4634KQ Gas Dryer
Takes 3 hours to dry a small load, dryer is 3 1/2 yrs old
You need to clean vent hose and vent line in wall of house.
May 08, 2009 | Dryers
My dryer takes much longer to dry loads now
Hi!
You need to check the following things to sort out the issue you are facing with--
Improper sorting •Separate heavy items from lightweight items (generally, to dry a well-sorted washer load is a well-sorted dryer load).
Large loads of heavy fabrics •Large, heavy fabrics contain more moisture and take (like beach towels) longer to dry. Separate large, heavy fabrics into smaller loads to speed drying time.
Controls improperly set •Match control settings to the load you are drying.
Lint filter is full •Clean lint filter before every load.
Improper or obstructed ducting •Check installation instructions for proper ducting/venting.
•Make sure ducting is clean, free of kinks and unobstructed.
•Check to see if outside wall damper operates easily.
•Check the Installation Instructions to make sure the dryer venting is correct.
Blown fuses or tripped •Replace fuses or reset circuit breakers. Since most dryers circuit breaker use 2 fuses/breakers, make sure both are operating.
Overloading/combining loads •Do not put more than one washer load in the dryer at a time.
Underloading •If you are drying only one or two items, add a few items to ensure proper tumbling.
Thanks for using FixYa and do rate the solution as Fixya if found helpful.
Thanks
Rylee
Apr 03, 2009 | GE DVLR223 Dryers
Dryer heats with smaller loads
1. unplug your machine and rach as far in the exhaust part of the dryer to see if there is an obstrucxtion
2.Take out the lint filter and make sure there are no gaping holes in the screen
3. Check the exhaust house leaving the machine or blockage, this hose should not run more than ten feet for optimal drying time.
4. its your heating element
Jan 19, 2009 | GE DBXR463EBWW Electric Dryer
Roper REX4634KQ Electric Dryer Logo
106 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
