Question about JVC RX-8020V Receiver
No subwoofer output-JVC RX-8020V
Yes, I already had the sub activated, & set the level at +6. Any more suggestions? I bought this as an entry level receiver for my son (finishing 1st yr. college) , & hoped it would serve him well for a while.
Thanks,
david
    Genius:
  • 1,066 Answers
This is a self-powered sub, correct?
Posted on May 23, 2008
Jvc RX 8020 receiver won't play when in DSP or Surround modes no sound at all, can only get sound in analog direct. Owned for 6 yrs. first problem ever!
I'd suspect one of the controls that would be overriden by analog direct is unknowingly activated. LOOK at the front panel and interpret every indicator for how it could cause silence. Refer to the manual for those you don't understand.
Any Tape Monitor activation would disable digital sources completely.
See page 14 for how Line Direct affects DSP modes.
Jun 27, 2011 | JVC RX-8020V Receiver
I have the Subwoofer plugged into the output and have it turned ON but it's still not working!
It only drives a self-powerd sub.
The manual...
http://www.retrevo.com/support/JVC-RX-8010VBKC-Receivers-manual/id/315dj079/t/2/
Page 17:
Setting the Subwoofer Information
Register whether you have connected a subwoofer or not.
Before you start, remember....
• There is a time limit in doing the following steps. If the setting is canceled before you finish, start from step 1 again.
On the front panel ONLY:
1. Press SETTING repeatedly until "SUBWOOFER" appears on the display.
The display changes to show the current setting.
2. Press CONTROL UP / DOWN to select "YES" or "NO."
• Each time you press the button, the display alternates between "YES" and "NO."
YES: Select this when a subwoofer is connected.
NO: Select this when no subwoofer is used.
Note:
You cannot use SUBWOOFER OUT ON/OFF on the front panel (see page 14) and adjust the subwoofer output level (see below) when "SUBWOOFER" is set to "NO."
Then continue with setting its relative level and other things.
Feb 06, 2011 | JVC RX-8010V Receiver
Yamaha RX-V861 no sub woofer output
It sounds like you have switched off the sub channel.
Keeping pressing C Level on the remote till you see SWFR.
Press D l / h to adjust the speaker output
level.
Jun 25, 2017 | Yamaha RX-V861 Receiver
AV receiver single line output to two line input on sub woofer
You are trying to connect the powered sub output of the receiver to a standard (unpowered) subwoofer. Can't be done.
May 05, 2017 | JVC Audio Players & Recorders
Subwoofer problem
If you get your system up and running and hear an audible buzz or hum, the first culprit to look at is either the powered subwoofer or your reciever feed at the entry point to your system.
Dec 23, 2009 | JVC RX-6018V Receiver
I am trying to hook up a powered sub woofer to a yamaha rx-v461 and i dont know what cables go where on the back of the sub there are two speaker ports and there are two plug ins but each speaker port has...
Your subwoofer probably has both high-power inputs and "normal"low inputs. The first are for receivers, which don't have link-level output for sub, so they are able to take already amplified signal as input.
You need to use link-level input of your sub and connect it to subwoofer-output of your receiver. The output is marked as OUTPUT - Subwoofer and is black-color RCA plug (don't confuse with subwoofer INPUT under MULTI CH INPUT).
Receiver has only mono output for subwoofer. If your sub has stereo input (white/red RCA plugs), connect just the left channel to the receiver, it will still work.
Don't connect anything to the speaker output on the sub, you don't need that.
Sep 28, 2009 | Yamaha RX-V461 AV Receiver
No sound out of subwoofer
Connection from receiver subwoofer output jack RCA plug male go into your powered subwoofer low level input with other end of cable, then you need to select Subwoofer YES/NO on the JVC receiver speaker setup menu option, select YES if this is a powered subwoofer you are using, should power up the subwoofer, may have to adjust a test tone balance for multi speaker output also, try trimming up on the subwoofer channel to initiate the signal on if the sub has an auto-on feature.
Feb 07, 2009 | JVC RX-5020VBK Receiver
Subwoofer-no output
ther should be a diagram in the left hand corner of display of speakers hooked up, make sure sub is shown right under the left right (and possibly) center speaker icons. under adjust, there is a subwoofer volume level. Under settings there is sub (yes, and no for on and off) there is a sub crossover frequency, and i believe there is also a "LFE" att, which is another subwoofer level.
May 23, 2008 | JVC RX-8020V Receiver
No subwoofer output
yes, you do have to set up the sub output in the reciever.
May 17, 2008 | JVC RX-8020V Receiver
Sub Woofer
Yes, this output on this receiver is at line level, (.775 MV) Or better known as 0 db level. You will need a powered subwoofer to get the bass to work. If you need an owners manual, you can get one here: http://books.jvcservice.com/download/256239653/17839.pdf Good Luck
Apr 03, 2007 | JVC RX-554V Receiver
JVC RX-8020V Receiver Logo
189 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
