Question about Coleman RoadTrip Sport Grill 9944-851
No propane to the burners
I have a extend-a-flow hooked to the hogh pressure side the the propane tank in the motorcoach-- camping world did the installation-- but when I test ed the grill out no propane will come out of the burners it does not light.
Is the ixten-a-astay on the wrong side of the main tank regulator? I can send pictures.
Brian
  • 68 Answers
Check the regulator they may have it installed backwards
Posted on Nov 02, 2017
4 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: cannot conect regulator to small 16.4 oz propane tank
It must have some sort of packing spacer you need to remove from the hose to attach the tank. LOL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Apr 12, 2009
  • 34 Answers
SOURCE: need a propane regulator for my road trip grill
Try their web site and you chould be able to get one from there.
Posted on Apr 17, 2010
  • 3328 Answers
SOURCE: need pressure regulator for portable grill that
try national energy or propane company , home hardware,
Posted on May 16, 2010
Why wont my old grill work with new propane tank
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 13, 2014 | Weber Q Grill
The electronic ignition (piezo lighter) on my Coleman 2-burner propane camp stove just quit sparking to 1 burner. It still lights the 2nd burner. A fix?
I've had this issue a few times. Complete cleaning of the under side of the burner and all components of the ignition system fixes it every time.
The slightest bit of carbon build up is the probable cause. I would suggest cleaning the contact with 400 grit or higher emory cloth. This will remove any contamination from the ignitor,
Aug 06, 2012 | Coleman 2 Burner Camping Propane Stove W/...
My Jenn air BBQ grill will not heat up all of
Couple things could be happening here. If you do exchanges, have you used more than one different propane tank since you've had this issue? This eliminates the possibility of a low tank pressure and a faulty tank connection. Next you need to look over the burners and the propane flow tubing. Spiders LOVE the sweet smell of propane and make their webbing inside the piping that get's the propane up to the burners. At your flow valves/On/Off knobs you'll notice that the propane shoots from the valves into a pipe with an air gap to gain oxygen. Look in there to see if there's any webs. Also should be a gap were that piping meets the burners, so you need to look there too. Depending on the age of the grill, you need to look the burners over. Corrosion & rust can cause the flame/propane holes in the burners themselves to cake up and close up causing much less flaming/heating opportunity. Also depending how much you've used it, it could be grease/dripping/sauce caked up over them too so they may need to be detailed/cleaned. It's not a pretty job, but grill maintenance that should be done every spring. When the burners get caked is when it's really fun and you need to remove them and clean out the holes with toothpicks. Jenn Air makes quality products, but being a BBQ and outdoors, it's just as vulnerable as any other to elemental and use issues. One last thing to check, some regulators (the disk shaped part right where the hose attaches to the tank) have another air mixture intake there with a screen on one side. Make sure there's no water in it and the opening is face down if you have one like that. Otherwise it's restricting the flow of the propane. I haven't seen one of these in a while, but they're still out there so check it too.
Jun 10, 2009 | Thane Q-BBQ Grill
No propane flow to grill using bulk bottle system.
the office that is open on the bottom of the burner sound like a spider has taken home to.. the hole.... This happened to mine. a small pipe cleaner or wire will break it up...try that. also did you feel the top of the tank regulator and see if it has froze. try turning the tank upside down and turn the unit on.... this may also help by forcing the spider debris out.
Jun 05, 2009 | Coleman Roadtrip Grill LXE 9949-750
Coleman Propane Stove 2 Burner 5430E700
Ho cold waas it out? remember that when its cold out the presswure of the propane tanks are real low and you have to warm them for the pressure to go up. if your by your car then you can place them inside with the heater going till they warm up ofr now worm them up inside first. good luck
Sep 06, 2008 | Coleman Propane Grill Stove 9921-700
Propane will not come thru burners
Most propane problems are due to a new valve on the top of the tank. It is designed to only allow a minimal flow until the line is pressured. This prevents fire flair up from broken or leaking hoses. Always turn the bottle on and wait before trying to light a burner. If the burner is on first, the propane will never come out at full flow or if you have a leak in the system, it won't pressurize sufficiently to allow full flow out of the bottle. There is never "air" in the tank.
May 28, 2008 | Coleman Roadtrip Grill LXE 9949-750
Low flame/ side burner dosen't light
I just read this online and it worked for me. Hope you have similar luck.
Newer propane tanks contain a self regulating feature that will automatically slow down the flow of fuel if it thinks it's too high. This can be solved by turning the tank valve off completely and disconnecting it. Open the control valves (on the grill control panel) and ten close them. Reconnect the fuel tank and slowly turn on the valve. Now light the grill to see if that fixes it.
Dec 02, 2007 | Weber Genesis Silver C Grill
Coleman RoadTrip Sport Grill 9944-851 Logo
299 people viewed this question
Top Coleman Grilling Experts
Paul Carew
Charles T Nevin
Charles T Nevin
john h
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
