Question about Brother IntelliFAX 775 Plain Paper Thermal transfer Fax
Fax number change
How do I reprogram the fax after it's phone number was changed?
  • 667 Answers
Hi ajames - I could tell you how to do it but it would probably be easier acd less confusing if you looked at the manual. Below is a link for your manual. If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_IntelliFax_775_EN_86.PDF
Jeff
Posted on May 18, 2008
How do I change my fax number on my HP 2610? I had two phone lines but discontinued the number that was for my fax. I now want to connected to my home phone.
To send or receive faxes, you just need to make sure the correct phone cable (the one that came with the all-in-one) is connected to the jack of the active phone line. If you had a distinctive ring for the second line, you need to turn that feature off. (Setup > 4 > 3 and change the Answer Ring Pattern to off). Make sure that you connect any other devices so that they will not interfere.
To change the fax header (including the phone number), Press Setup > 4 > 2. (Basic Fax Setup and Fax Header). Enter your name (if you need to adjust that line) followed by Done on the visual keyboard and press OK. Then enter your phone number with the numeric keyboard and press OK. An easier option is to change the header in the HP Director software on the computer. (This is part of the HP Image Zone software.) If you do not use that package, adjust the headers in any computer fax program that you have.
I hope this helps.
Sep 23, 2010 | HP Photosmart 2610 All-In-One InkJet...
I need to reprogram the phone #. How do I do that?
You will need to change the station ID
Press the buttons, menu,0,3, and follow the steps from there.
Mar 29, 2010 | Brother IntelliFax-2820 Laser Fax
How do i change the phone number on an hp
To change the information contained in the fax header:
Press <Setup>, <3> then <2>
Enter or change info
Press <OK>
I hope this helps. If it does, please vote.
Dec 31, 2009 | HP Officejet 5510 All-In-One Thermal...
MFC-8820D we have moved our office and have a new phone numder. How do we re program that number into our fax. Thanks matt
The following procedure will reprogram a new station (home fax number) for your machine. Thank you for using Fixya and please post back with any questions or to rate the answer provided.
Greg
  1. Press MENU 0,3
  2. Enter your new fax number (if the old still exists, move the cursor/arrow back ward to the first position to change the number displayed
  3. Press SET
  4. Enter telephone number (if it's the same as the fax number, enter the fax number again)
  5. Use the dial pad to enter your name (if your name still exists, leave it as it reads)
  6. Press SET
  7. Press STOP/EXIT
You will be given a choice to press 1 to continue with the change or 2 to exit without changes.
Press 1
The date and time will now appear and the change is complete
Sep 10, 2009 | Office Equipment & Supplies
Wrong Fax Number on Transmission Report
To change the fax number, do the following:
  1. Press Menu/Set 0 3
  2. Your station ID should appear, use back arrow (<) to move the cursor to the position where you want to change the number
  3. Press Menu/Set
This procedure will change your phone number which will be displayed on all cover pages and Tx reports
Best of luck.
Greg
Jul 28, 2009 | Brother IntelliFAX 2800 Laser Fax
Entering my own phone number to a fax machine
press help key then print your setting phone no or change
Jun 28, 2009 | Sharp UX 355L Plain Paper Thermal transfer...
I have an hp v40xi. I recently changed my home number and can't remember how to replace my old phone number with the new, in order to get my fax to work.
The FAX header information can be changed using the HP software or the front panel on the printer. Instructions can be found here on the HP website.
Changing your phone number should not affect the fax operation. Are you sure that was all that was changed?
Jan 07, 2009 | HP OfficeJet V40xi InkJet Printer
Change phone number on fax
FAX PRINTS OUT OLD PHONE NUMBER. FAX NEEDS TO REFLECT NEW PHONE NUMBER ON SENDING HEADER OF FAX
Apr 18, 2007 | Muratec F360 Plain Paper Laser Fax
Brother IntelliFAX 775 Plain Paper Thermal transfer Fax Logo
32 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
