GE Profile Spectra JGBP90 Gas Kitchen Range Logo
Posted on Sep 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I was baking bread suddenly the oven stopped,again it's not working why?
Anonymous
Level 3:
  • GE Master 43,501 Answers
  • Posted on Sep 19, 2010
Anonymous
GE Master
Level 3:
Answers
43501
Questions
0
Helped
10843918
Points
101584
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
1helpful
My DeLonghi Alfredo toaster oven XU21 ST suddenly stopped working after baking. What is best troubleshooting to do? I'd like to try to repair it. don't have any electric tools. Thanks.
Sometimes they have a external fuse which is close to where the wire goes in.
Or, the element has failed. Do you have a digital multimeter? Both items are easy to test.
Or it may have a thermal fuse, again an easy test with a meter.
https://www.google.com/search?q=DeLonghi+Alfredo+toaster+oven+XU21+ST+suddenly+stopped+working+after+baking
Videos. The make is not important as they all work the same and are all made by the same factory in China.
1helpful
Is there a pizza oven cook book with recepie other than pizza
Plenty of online offerings for wood fired ovens. A baker in the north of England uses a wood fired oven to bake speciality breads. The oven is fired to a high temperature early in the morning and different breads are baked as the oven cools, including a Russian black bread from a culture centuries old.
Dec 28, 2018 • Ovens
2answers
Mixing OK but not heating/baking
That's not a good sign. This will keep your bread from rising properly and baking, obviously.
If you are still under warranty, contact your manufacturer, otherwise, you can still use the machine to mix but you will need to use your oven to finish your bread.
If your bread is not rising in the machine:
  • Remove mxing chamber from machine
  • If the chamber is not removable, UN-PLUG THE BREAD MACHINE so the blades DO NOT TURN.
  • Be careful of the mixing blade in the chamber
  • Remove dough gently with slightly oiled hands into a lightly oiled bowl with room for about 2x the volume of the dough
  • Cover with plastic wrap to prevent the dough from drying
  • Place the bowl of dough in an unheated oven and leave the oven OFF
  • Place an empty lasagna pan in the cold oven on a shelf below the dough or on the floor of the oven if there are no exposed elements
  • Boil some water and pour it carefully into the lasagna pan
  • Close the oven door - You have just made a proofing box. The steam and heat from the boiled water is sufficient to make a great proofing cabinet out of your oven hot box
  • Allow the dough to rise to about twice the original volume
  • remove the dough from the oven and remove the pan of water
  • continue with the baking instructions below
If your bread is rising in the machine or you have finished the above instructions:
  • Remove dough gently with slightly oiled hands into bread pans. Breadmakers are different sizes so you may need to use one or two pans. Or make an artisan style loaf on a cookie sheet lined with parchment.
  • Be careful not to compress your risen dough as this will make the loaves dense
  • You may also choose to make buns by separating the dough into smaller balls and placing on parchment lined cookie sheets
  • You can allow the dough to rise again for a short time in the proofing box above but I would just leave them on the counter under clean towels to prevent drying for say another 20 minutes. Over-rising bread should also be prevented. The result will be 'deflated' looking bread.
  • Preheat your oven to 375F and bake the bread until it is golden and makes a hollow sound when thumped on the top or the bottom crust
Personally, I love that a machine will mix and knead my dough for me while i go do something else but I don't like the appearance of a machine baked bread. I like the artisan hand-made look. I recommend you keep the breadmaker until you find one you like that is drastically reduced in price and just use the artisan proofing & baking options above.
If you have a Pizza Stone, you can also try that for baking an artisan bread. Use the breadmaker as the workhorse, use your oven as an artist.
Good Luck and may the Yeast be Lively!
How do you stop the clock ticking?
You could turn off the oven at the isolator switch. Turn it on again when you need to use it.
The time really only needs to be accurate when you make use of features like a delayed start when baking bread, or to stop baking meringues and let them cool slowly in the oven.
Just be sure to check that the Auto/Manual switch is set to manual unless you're doing the above type of baking.
Feb 28, 2014 • Candy Ovens
1helpful
Why does my Morphy RIchards Breadmaker keep beeping HHH ? Will not work
That usually happens when you have baked a loaf of bread and you try to bake another one too soon. Most bread machines do that to let you know the oven is too hot for your yeast to work properly. Did this happen just after baking a loaf of bread?
1helpful
Breadmaker stopped and bread not baked
It usually isn't worth it to try to repair a bread machine and yours does sound like the eletronics have gone bad. I have several good machines for sale at very reasonable prices. contact me at breadmachineshelp.com if you are interested in replacing your k6725
1helpful
Accidently pushed stop , how to continue to bake, bread has risen but not baked. what can I do
Finish it in the oven at 350F for 30 minuts, some times when the program is cancelled you need to manually bake it (unless your bread maker has a resume option) look throug the menu for RESUME...
8helpful
2answers
Whirlpool GS563LXSS: bake and broil doesn't work.
Oven suddenly stopped to work.
After trying to turn on "bake" or "broil" I can hear couple clicks but nothing else happens.
No flame/no gas is coming out.
1helpful
Hi. I have a ge convection oven(JCTP17) that has been working great until recently. I bought a Taylor oven thermometer model number (503) To check othe oven temps to see how accurate the oven is. I do a...
The Taylor oven thermometer you bought is decent at best. It is most likely the sensor inside the oven. Has your clock displayed any fault codes? F, followed by a number? Changing the sensor will probably correct the problem.
Aug 19, 2009 • Ovens
Best setting for baking cakes
good day,
hope this link below will solve your problem.
baking.
The best bread machine we've found for gluten-free bread baking. Programmable feature puts you in charge. Bakes a delicious 1.5 to 2 pound loaf every time. It has a viewing window, automatic settings for breads, cakes and jam, sourdough starter and programmable cycle that makes gluten-free bread in under two hours!
Top Kitchen Ranges Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Kitchen Range Expert? Answer questions, earn points and help others
