Question about Sony DCR-HC19E Mini DV Digital Camcorder
Picture package menu error
Hi, When i click on the picture package menu i get this following error pops up and i have nothing but ok button to click.
"Pixela_ImxVcd2_01.info pfile== NULL"
Before this error i had mecromedia flash player error and i went on-line and got the update and installed it and then i get the above error
("Pixela_ImxVcd2_01.info pfile== NULL").
I have tried to un-install and install the picture package again but nothing happens. Please help. my E-mail is mcpatel77@yahoo.com.
Thanks,
Mital.
  • baldcats Jul 26, 2008
    Same problem. Couldnt open picture package due to error that stated I need to install Macromedia Flash Player first. The title of the error box is SonyPotl. Flash has been installed on my PC all along, but I updated the latest version anyway. Then from another message board advice, I updated the picture package menu from the Sony website at http://www.ppackage.com/e/index.html as per Sony recommendation to fix this problem. Now I get this whole new error and nothing on the internet has any reference as to what this is. My email is Alicatz2@hotmail.com, my product is Sony DCRDVD405.
5 Suggested Answers
SOURCE: Picture package problem opening
i have Sony Handycam DCR32E, but I
am not able to get picture package i my pc.
Ajay
Posted on Jan 07, 2008
SOURCE: dcr-hc19e & picture package menu & macromedia flash player
can I download the software to allow me to play my jvc high band digital camera
Posted on Mar 11, 2008
Here's were you need to go and updated the picture package version that you have.
Posted on Jun 24, 2008
SOURCE: Macromedia Flash
I am wrting in regards to my Sony Handycam DCR-HC36. I am having problems with the Picture Package software when I try to load my video. When I try to transfer my videos (from my Handycam) to my Pesonal Computer, the picture package(software) menu does not appear on my PC(The picture package software is already installed).
Everytime I try to click on the Picture Package Icon on my desktop, there is a pop-up that says I "must install Macromedia Flash Player for Application to continue".
I went ahead and installed the Adobe (Macromedia) Flash Player and it still doesn't work when I try to click on the Picture Package Icon. The pop-up still comes up. I also, re-installed some of the requirements for the for the camera to work such as Direct X and Windows Media Player.
I also enabled my Javascript(active Script).
The problem is most likely within my PC(maybe I'm missing another type of software???), what do you think are my options in resolving this matter?
Please help me out
Anindya
Posted on Oct 04, 2008
wipdhuls
  • 133 Answers
SOURCE: WHENEVER I START PICTURE PACKAGE MENU , THE ICON
Download version 1.8 from the following link and let me know if that resolves the issue:
http://www.ppackage.com/e/download.html#dl
Posted on Apr 02, 2009
I am trying to download iTunes onto my computer, but when I get to the end of the process where iTunes and QuickTime are to be installed it wont. A small box pops up saying "iTunes could not be...
Hi there!
There can be several reasons why you are getting this error message. First, make sure that your user account is an administrator account. If you are sure that your account is an admin, follow this steps:
1. Choose Run from the Start menu. type %Temp% and click OK. delete all files inside the temp directory 3. Click again on run from start menu. Type cmd and hit Enter. 3. Drag iTunesSetup.exe from the Desktop into the C:\\WINDOWS\system32\cmd.exe window. 4. Add a space and then this text: /extract %TEMP% 5. Press return/enter. This will extract three Windows installer packages into your TEMP directory. 6. Navigate back to your TEMP directory. 7. Launch the AppleSoftwareUpdate Windows Installer Package. Complete the installation. 8. Launch the QuickTime Windows Installer Package. Complete the installation. 9. Launch the iTunes Windows Installer Package. Complete the installation.
Please reply if this will not fix the problem. Cheers!
Apr 23, 2011 | Apple iTunes
Imtryinig to log off so someone else can log in
Hi there...
If you use Microsoft Windows based computer, logging off is very easy..
1. Go to Start menu (Its a button saying ' Start ' on it. And it locates Most commonly at lower left of screen) and click it.
On Clicking, it will pop open showing contents of start menu
You may have start menu look like one of these.. (Assuming that you uses Windows OS)
2. Follow either A / B / C option corresponding to your start menu appearance. If Your Start Menu Looks like Option_A, then follow its instructions. So do others
Option _ A
Click On button ' Log Off '
Then Choose " Log Off " button to Log off from system
Option _ B
Click On Small arrow next to Lock Symbol . It will show a menu containing many options including " Log Off".
Then Choose "Log Off" to Log off from system
Option _ C
Click on "Shut Down ...". This will open new window showing many options. On Drop menu (Looks like a text area and it will have a down pointed arrow or triangle) choose "Log Off".
Click on Ok Button will Log you off the system
Mar 12, 2011 | Computers & Internet
Trying for format my memory card - keep receiving error message will not let me format
Follow these steps to format your memory card. In any mode, press the Menu button. Press to highlight Setup , then press the OK button.Press to highlight the setting you wish to change, then press the OK button.Choose an option, then press the OK button. Press the Menu button to exit.You will be having a setting named as format. Click that and format your card. This will reformat your card.
Thank you !!
May 24, 2010 | Kodak EasyShare C330 Digital Camera
When I hit the bottom left hand MS Icon to bring up list of programs to launch the list on the right hand black column list my main file areas such as 'Pictures' and used to list 'Documents' but for some...
Click the start menu button so it opens up the menu where the documents used to be, then right click on the start menu. Click properties a pop up should open up saying taskbar and start menu properties. Click the start menu tab, if your not already on it. Then click the customize button. It should open up another pop up saying customize start menu. Then click use default settings button near the bottom of the pop up or you can click the check box under the documents that says display as a link. After doing all that click ok on the pop up it should close. Then click apply and ok on the other pop up it should then close that. Then click the start button and it should show your documents. If you need more help comment and ill try again. If i helped please leave me a rating.
Jan 14, 2010 | Microsoft Windows Vista Ultimate Edition
Problem about "services.exe - Application Error" pop-up menu
Apparently, you computer has some unexpected software running during the startup. In order to get ride of these software, you could check your register table manualy by regedit or download this software, which will help you to find if there are any suspect software running at the startup.
files.filefront.com/sreng2zip/;8049311;/fileinfo.html
May 07, 2009 | Computers & Internet
N95
HI,
To change the date on your Nokia N Series or E Series, follow these instructions:
* Click on the Menu button, highlight Tools and click the centre selection key (the ‘OK’ key)
* Highlight Settings and click the OK key
* Highlight General and click the OK key
* Highlight Date and time and click the OK key
* Highlight the date and click the OK key
* Use the Right Navigation key to highlight the year. To change the year back one year, press the Down navigation key once.
* Press the Red “End” key to return to standby mode.
Aug 05, 2008 | Nokia N95 Cellular Phone
Help... 1640n
Here's what HP has to say about your error...It appears to be an issue with Sonic MyDVD. Reinstallation of the program seems to be the solution.
Jul 20, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Navigation fatal error Error 1706
oops..sounds like maybe your drivers are unhappy...
Mar 09, 2008 | GPS
Background
To change the windows vista desktop background,
start by right-clicking on a blank area of the desktop.
Click Personalize from the menu that pops up.
Click on the desktop background link.
choose your desktop background by following these steps:
  1. Select the kind of background you want from the location menu.
  2. Click on the desktop background you wish to use.
  3. Select how you want the picture to be positioned.
  4. Click the OK button
Jan 16, 2008 | Acer Aspire 3610 Notebook
Macromedia Flash
Please help me out
Anindya
Apr 20, 2007 | Sony Handycam DCR-HC36 Mini DV Digital...
Sony DCR-HC19E Mini DV Digital Camcorder Logo
513 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
