Question about Motorola Mobility A1200
Ipaq rz1710 Hi, I have just recently began to use my Ipaq which has been laying around for some time. I have just inserted a 2gb memory card which I can find on settings but when I try to download for example songs, I get the error message "unable to fit on device". My problem is memory card is recognised in program, has 1946.63MB space, but when trying to download programmes from computer, memory is not recognised.
  • 97 Answers
Just format your memory srtick w/ the PDA and / or computer.
Posted on May 21, 2008
Unable to format 2GB sand disk memory card
Hi Sir ^^
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Jun 14, 2010 | SanDisk 2GB microSD Memory Card
    Just bought 4GB SD card that hx4700 does not recognise - help pse
    Your slot in the iPAQ is a SD slot, not a SDHC slot - therefore it will not read the card. Your PC card is probably a dual reader. The SD cards look the same but are different. Have a read of this...
    http://en.wikipedia.org/wiki/Secure_Digital_card
    Dec 10, 2008 | HP iPAQ HX4700 Pocket PC
    Rz1710 bluetooth and memory
    - Yes, memory will increase - you can install programs on card instead of internal memory
    - no, you can't install SIM card as there's no apropriate slot to accomodate it
    Jan 13, 2008 | HP iPAQ RZ1710 Pocket PC
    HP iPAQ RZ1710 Pocket PC freezes on pin entry!!
    If still freeze after the resets, then try to do a Hard Reset.
    With this way you will restore your device at the default condition.
    Take care to remove any external memory from iPAQ before to this and also have it
    full charged.
    The bad of this....you will loose everything stored at the internal memory of iPAQ.
    The good this...your iPAQ would be alive again ;-)
    To to a Hard Reset press at the same time the reset button+calendar button+today button.
    Jan 10, 2008 | HP iPAQ RZ1710 Pocket PC
    Rz1710
    try to erboot it, there is a small hull in the bottom on left side, push in it with the pin u have tp your PDA. that will reboot the system
    Dec 18, 2007 | HP iPAQ RZ1710 Pocket PC
    Hp pda ipaq rz1710 doesn't know to used
    Download the manual off the HP site. It's FREE
    May 12, 2007 | HP iPAQ RZ1710 Pocket PC
    My Pocket PC with a 4Gb Sd
    Hi tHEyOs, Well I?ve been poking around and here are the facts I?ve found: -The largest SD memory card HP lists as an accessory is a 2GB card. -The actual specifications sheet states the SD slot supports SD, SDIO and MMC but makes no mention of any size limitation. My suspicion based on my own personal use of HP hand held PCs is that it will probably accommodate your GB SD memory card. In my own personal experience is that the devices list as accessories only those memory cards that were prevalent at the time the PC was released. So even though the HP site only lists 2GB as the largest its only because the larger cards didn?t exist in the marketplace at the time so it really isn?t any kind of indicator. To me the specifications sheet is the ultimate reference and it doesn?t make note of any type of imitation. If you are still apprehensive buy the memory from a mail order house like TigerDirect and tell them you want a 4GB SD module for an HP H2210 PocketPC. If it doesn?t work you can return it for a full credit. If you have any more questions let us know and please don?t forget to rate the posting.
    Feb 11, 2007 | HP iPAQ H2210 Pocket PC
    My ipaq won't open!
    if you have inserted SD or other cards and devices in your IPAQ try to stay IPAQ without them.... if ypu don`t have it ---- then go to the service center....
    Sep 08, 2005 | HP iPAQ RZ1710 Pocket PC
    Is IPAQ rz1710 bluetooth technology compatible or not ?
    The 1710 does not have bluetooth. You would have to buy a SD bluetooth card and then you could connect to the internet via a bluetooth phone if the phone had internet access.
    Motorola Mobility A1200 Logo
    47 people viewed this question
    Top Motorola Mobility Computers & Internet Experts
    David Payne
    David Payne
     Paul Flint
    Paul Flint
    Level 1 Expert
    Unlockingcom
    Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
