Dvd/vcr combo I didn't get an answer please answer my question How do I get the channels on my vcr so i can set shows to tape. All I see is L1 & L2
  • 5 more comments
  • Viki2 May 18, 2008
    it is model # DVP3345V/17
    Digital Video Player & Video Cassette Recorder
    it's coming from L1 but how do I get the channels when I am setting a program to set?
    how do I turn on my external tuner?
  • Viki2 May 19, 2008
    I don't feel like u have explained anything to me that I didn't already know.
    All I need to know is how do I set my VCR/DVD player to tape programs, & how do I program my t.v. channels onto my combo player.
  • Viki2 May 20, 2008
    thank u for your time & help.
  • bibliomania Sep 21, 2008
    How do you put the selected channel in to record a tv show? (either dvd or vhs)
  • Ekse May 11, 2010
    You still didn't say which brand and model device you got?
  • 13,433 Answers
I'l make sure, but I beleave L1 and L2 are inputs. You need to select the one where the show comes from, Its it coming from the L1 connector or L2.
Your device doesn't have a tuner input jack. To record TV programs on your DVD/VCR, you need to connect this DVD/VCR to an external tuner device (e.g., set top box, cable box or satellite receiver) that has audio/video output jacks.
Il confirm this and reply to you in a moment.
Posted on May 18, 2008
  • 10 more comments
  • Ekse May 18, 2008
    Yes thats it. L1 are the connectors in the back and L2 are the ones in front.
  • Ekse May 18, 2008
    Heres how to program automatic recording
    CLICK HERE
  • Ekse May 18, 2008
    I beleave you need to have the device where the show is coming ON and on the right channel.
  • Ekse May 18, 2008
    your product is not that great in recording shows as it needs a outside tuner.
  • Ekse May 18, 2008
    What is your external tuner? - Brand - Model.
  • Ekse May 18, 2008
    Just make sure its turned on and on the right channel. or set to start up at the right time and on the right channel.
    If you need more assistance let me know
  • Ekse May 19, 2008
    Whats with the inappropriate? Explain
  • Ekse May 19, 2008
    1. To record a TV channel using this VCR, you will need to have a Cable/Satellite box connected to the player. (Important)
    2. Mutiple channel timer recordings using the VCR is NOT possible as the VCR will only record the current channel selected on the cable/satellite box .
    3. You will need to leave your cable/satellite box ON and tuned to the correct channel for proper recording to occur.
  • Ekse May 19, 2008
    There is no way to record difrent channel with this player as it has NO TUNER.
  • Ekse May 19, 2008
    How can I program a timer for automatic recording?
    Before you begin:
    • This DVD/VCR does not have a tuner input jack. To record TV programs on your DVD/VCR, you need to connect this DVD/VCR to an external tuner device (e.g., set top box, cable box or satellite receiver) that has audio/video output jacks.
    • Set the clock.
    • Put a tape in the cassette compartment of the DVD/VCR. Make sure the tape’s record tab is intact and the tape is long enough to record the program(s).
    • Press [VCR] so VCR light appears on the front of the DVD/VCR.
    • Turn on your external tuner.
    1. Press [SETUP] so MENU appears.
    2. Press to select TIMER PROGRAMMING. If you can not select this be sure your clock is set.
    3. Then, press . Program numbers that do not have a Timer Recording stored will flash.
    4. Press to select an empty program. Then, press .
    5. Press to select ONCE, DAILY or WEEKLY. Then, press .
      • ONCE - The VCR will record a TV program on any day you choose, up to 12 months away.
      • DAILY - The VCR will record a TV program at the same time on the same channel every day, Monday through Friday.
      • WEEKLY - The VCR will record a TV program at the same time on the same channel every week, for example, every Monday.
    6. To set the recording date and time, press until the desired setting appears, then press .
    7. Press to select the appropriate external input channel:
      • L1 if you are connected to back of player
      • L2 if you are connected to the front of the player
    8. Then select the desired channel to record on the external tuner.
      Leave the external tuner on for the Timer Recording.
    9. Press to select a re cording tape speed. The arrow will appear beside your choice. The selected speed will flash beside REC SPEED. You must select the recording speed to complete the timer programming.
    10. Press [CLEAR] to remove the menu.
    11. Press [TIMER SET].
      In some cases, the DVD/VCR will switch to DVD mode instead. You may use the DVD player during a Timer Recording.
    Canceling a Timer Recording Before the Recording Starts
    1. Press [VCR], then press [SETUP] so MENU appears.
    2. Press to select TIMER PROGRAMMING, then press .
    3. Press to find the program you want to cancel.
      While the program number is flashing, press to clear all the information for that program.
    4. Press [CLEAR] to remove the menu.
    To stop a Timer Recording once it has started.
    Press STOP/EJECT on the front of the DVD/VCR. (You cannot stop a started Timer Recording with STOP on the remote.)
    If the icons are unclear READ THIS PAGE
  • Ekse May 19, 2008
    • how do I program my t.v. channels onto my combo player.
    Solution:
    Not possible
  • Ekse May 20, 2008
    Here it is ones again
    -You can only record the channel which is turned on in the cable box / satteli box or other device where the show is coming from
    -YOU CAN NOT PROGRAM CHANNELS INTO THE PLAYER
I was able to connect a dvd player to old tv with a rf modulator.now is there a way to hook up a vcr on same rf modulator so as not to change connections each time you want to watch the vcr with instead of...
well...the reason its sooo hard is that this modulator is not intended for this use. its used for BIG jobs. you can normally do what you want with a simple rf modulator you buy at walmart or radio shack as it has a cable in and cable out, but
You dont even need a rf modulator.
The VCR can do it for free simply; hook the yellow , white if your vcr has red as well (depending on how old )...BOTH or all Three color to color from VCR(INPUT) to DVD
then use a piece of coax cable from the vcr out to tv.
test vcr by making sure that it work on either channel 3 - or 4 on tv. (leave VCR on)
Then to test your DVD connection first turn DVD player on.;.Then on front of VCR press channel down ON VCR until it says L1 or L2 this is under channel 2 when channel downing.
you should now see the dvd player on screen on either L1 or L2 depending on vcr.
now buy doing this your vcr must be on the L1 (L2) anytime you watch a dvd but when you want to watch a tape you just put it in and press play since TV itself is never changed.
when you want to go back to dvd,...stop tape and should still be right on the L1 or L2 again.
Aug 05, 2011 | Channel Vision E-1200 Video/audio Rf...
I have an older tv with only a coaxial cable connection on the back, no others. I have a Magnavox dvd/vcr combo that does have RCA connections available and also a coaxial cable connection on the back. I...
First make sure you have the cable connected properly.. on the vcr it should be connected to the OUT coaxial connector.
Second.. the VCR usually has a VCR/TV setting..
Most TV's must be set to channel 3 or channel 4 to output the signal from the VCR when getting the signal via Coax.
So..insert a tape...hit play..tune the tv to channel 3 if you are not getting the playback signal..press the VCR/TV button on the vcr or vcr remote.
Repeat this on Channel 4
Check your cable to make sure the connections are tight.
Finally check your television menus for Input settings..make sure it is set to COAX/ANT
Make sure your VCR's output is not on some alternate output like L1 or L2 (line one or line two)
Best of luck!
Apr 22, 2011 | Televison & Video
I have a Sylvania DVD/CD player with VCR, model DVC841G, when I put in a tape to watch it it gets stuck and pulls the tape and breaks it, and won't play. This problem just started recently and it worked...
When trying to program a show on my Sylvania Model DVD/CD841G when it tells you to put in the channel it comes up automatically with L1 and L2. What is this and how can I fix it.
May 23, 2010 | Sylvania Televison & Video
What channel do you watch a vcr/dvd on.
It depends on the way you have the combo set up, your instruction manual shows you different ways of doing this, but to answer the question it would be channel 3 or 4 if you are using the RF out ot OUT to TV connector in the back of your combo. You can also view tape and disc playback if you set the TV for VID1 or VID2 if you are using the rca dubbing cables(yellow-red-white).I hope this helps!
Jan 05, 2010 | Insignia NS-L37Q-10A 37 in. HD-Ready LCD...
Panasonic PV-9451 VCR, When setting up the VCR to record a channel, the only channel options are Channel 02 thru 25 and L1 And L2. What has to be reset with the digital cable input??
You will need to use L1 or L2 (one is probably on the front of the VCR, and the other on the back, they should be labeled).
YOu need to plug the digital receiver's output into L1, or L2, and set the VCR to record the one you're using. Then set it to the time you want, and then set the channel on the digital box tho the one you want.
One Channel, One time. (or recurring daily, if your VCR allows daily recording from L1,2)
Jun 13, 2009 | Televison & Video
TRYING TO HOOK UP OLD RCA COMBO (DVD/VCR) TO MY NEW TV. USING THE RED/WHITE/YELLOW CABLES ALONG WITH PUTTING MY CABLE SIGNAL DIRECT INTO THE DVD/VCR PLAYER AND THEN CONNECTING THE OUT LINE TO THE NEW...
ok so what you need to do is put the cable from your cable provider/ antenna (or what ever you use)to the combo players CABLE IN connection.. then color match of the red yellow and white cables from the OUT on the combo to the IN on the TV your tv has to be set on AUX sometimes called L1 or L2 depending on your tv and which set of red yellow and white holes on the tv you use... your combo will also probably need to be turned on.. try that should work!
Oct 16, 2008 | RCA Televison & Video
Channel setup for VCR recording
WHAT YOU HAVE TO DO IS GO INTO SETUP AND DO A 'CHANNEL SET' EITHER AUTOMATIC (WHICH DID NOT WORK ON MINE) OR MANUAL AND ENTER EACH AND EVERY CHANNEL YOU WANT TO RECORD. THIS IS TIME CONSUMING BUT THAT IS THE ONLY WAY IT WILL WORK - IF YOURS WORKS WITH 'AUTOMATIC' YOU GOT IT MADE
Jan 24, 2008 | Philips Magnavox DVD/VCR Dual Player
Vcr taping
You need to run the autotuning feature on the tuner setup page. It doesn't yet know what channels are available to it and is defaulted to the minimum.
Hope Ya Fix it!
Jan 21, 2008 | Emerson EWV601 S-VHS VCR
Recording from cable
L1 and L2 are different inputs on the VCR.If you have red, white and yellow input on the front of the VCR then when you put the VCR on L1 it should pick up a signal from the front.To get more channels on your vcr you want to do an autoprogram make sure the cable from the wall is plugged into the input in the back and go to the menu on the VCR and look for channel search or auto program and start the search.usually you can find this setting under something like SETUP, Programming,settings on the main menu of the VCR.You may have to search in the menu of the vcr for a little bit until you find it.Youll know when you got it when the channels automatically start scanning from 1-98.GOOD LUCK and rate me if this fixesya or is helpful.
Nov 16, 2007 | Lands Phones
Televison & Video Logo
530 people viewed this question
Top Televison & Video Experts
