Question about Kenmore 24032\24036 Top Load Washer
Washer leaks after installing new lid switch
I recently replaced the lid switch on my Kenmore 90 series washer, as the washer was not draining or spinning. The new switch fixed my problem; however, I think I made a mistake in putting the washer back together. My washer now leaks when it fills and agitates. Also looks like it is filling up with too much water. Any help or tricks as to what I can check to see if I put it back together correctly?
  • pc9400 May 18, 2008
    Disregard. Went back over everything and I had forgot to re-connect the hose for the water level switch back to the console.
  • 246 Answers
Glad this was taken care of. I'm just closing out some old tickets here.
Posted on Jun 19, 2008
My Kenmore washer is not draining or rinsing
Check the lid down safety switch. On the lid there is a small spike that goes through a hole when the lid is down.
Under the hole is a switch that allows the timer to advance and the washer to spin only when the lid is down. Two screws hold the switch in place and the plastic switch will sometimes break and be hanging by the wires.
In other words, it is the timer. That is stopping the advance. You may have to replace the timer.
How to replace the timer in Kenmore top load washer
Aug 27, 2017 | Kenmore Washing Machines
My kenmore 90 series washer will not drain i have tried playing with the lid leaver any thing else i can do ,can i replace the leaver switch?
Yes you can replace the lid switch its fairly easy to do...this tip i wrote will help ya to replace the lid switch http://www.fixya.com/support/r9939128-whirlpool_kenmore_estate_kitchen_aid
Series 90 is unfortunitly not a model number please reply with exact model number as found on a label on the rim of the tub inside of the lid and i will give you the part number for the lid switch.
GENE
Sep 12, 2011 | Kenmore 24032\24036 Top Load Washer
I HAVE A KENMORE 90 SERIES WASHER JUST REPLACED
it mounts to the metal where the lid closes, not on the drum... there's usually two holes where the screws go through... and a third hole where the actuator(plastic post) on the lid goes through to activate the lid switch...
Sep 25, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 Series Washer
CHANGE THE LID SWITCH
Apr 18, 2009 | Washing Machines
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Dec 17, 2008 | Kenmore 23822 Top Load Washer
90 Series Kenmore Washer Not going to spin cycle not draining water
I've had the same problem...you can purchase a replacement lid switch at your local appliance parts store for about $35. Fortunatly, the sales person at the appliance store had diagrams and provided instructions to replace the switch. I was able to finish the job and fix the switch in less than 1 hour. Good Luck.
Oct 25, 2008 | Kenmore 15864/15862 Top Load Washer
Leaking Washing machine
I would recommend you inspect the washer with the exterior cover removed, so you can actually see where the leak may be coming from. The following link explains how to replace a drain pump on a Kenmore. I submit this to you, because it not only explains how to remove the exterior case of the washer, but in the event that the pump is leaking, it gives you the necessary steps required to install a new one. The pumps are sealed units and not servicebale. If they leak, they need to be replaced:
http://www.fixya.com/support/r397094-replacing_water_pump
When you remove the exterior case, the washer will not operate without the lid switch by-passed. You will need to do this in order to fill the wash tub to see where the leak may be coming from. To by-pass the switch, you will need to unplug the washer and jumper the two black wires together at the lid switch connector on the timer. Use aligator clips on the connector pins to do this. With the lid switch by-passed, you can plug the washer back in and start a cycle.
Look for signs of leaking around the drain pump (located in the front under the wash tub) and all hoses. Also inspect the entire perimeter of the wash tub for any possible leaks. Generally, if you have a leak in the front of the washer, its a drain pump or drain hose connection. If you have a leak under the tub you may have a worn tub seal or cracked tub.
I hope you find this information helpful. Hopefully, you will not need any repair parts. If you have any questions, please let me know.
PS Use caution when operating the washer with the case removed. There are exposed electrical components and moving parts.
Sep 02, 2008 | Kenmore Washing Machines
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
114 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
