My scanner is showing a green light for power however when I press the scan copy or power button it does nothing. If there is any way you could help me that would be great
Thanks for reading
Have the same problems, scanner shown installed on computer, connections all made, lights on but does nothing! Any help would be appreciated. (tried on lapto and PC and nothing. Have the same problems, scanner shown installed on computer, connections all made, lights on but does nothing! Any help would be appreciated. (tried on lapto and PC and nothing.
You can't post conmments that contain an email address.
Copier may require you use the scan feature to make copies either ise the feeder otr flatbed. Press start on machine for manual entry but still use scan to get things working.
Yes follow the first steps to set up the scanner (charge it, properly insert the memory card, etc.) Then you are ready to scan Once
you press the SCAN button and the Green LED stays lit its time to roll
the scanner down your document to be scanned. When finished press the
Scan button again to STOP the scan. If successful your Document count
in the display will move from 000 to 001. That is the only indication
that you now have a successful scan. Next Press and hold the SCAN button until the display goes blank. Now
you can remove the memory card (by pushing in and it will release).
Place this memory card into a memory card reader on your computer to
transfer and view your scanned documents. Rinse and repeat. BTW, I found a quick start guide for this Pandigital Handheld Wand Scanner Model PANSCN08 at: http://www.qvc.com/footers/E167092_quick-start-guide.pdf
he HP All-in-One product displays one of the following error messages on the control panel when scanning or copying:
Scanner failure, power off and on
Scanner System Failure
Scanner failed, cannot make copies or fax
Scanner failure. Unable to scan, copy, or send a fax
Scanner failure, cycle power
Additionally, the scanner bulb might not turn on during scanning.ry the following
solutions in the order presented to resolve the issue. When one of the
solutions resolves the issue, there is no need to continue
troubleshooting.Solution one: Check the scanner lightFollow these steps to check the scanner light by making a color copy of any document.
Load plain white, unused, letter size paper in the paper tray.
Lift the scanner lid, place the original face down on the scanner glass, and then lower the scanner lid.
Make a color copy.
When
the product starts to scan the document to copy, slightly lift the
scanner lid to see if the scanner light turns on. It is not necessary to
lift the lid completely CAUTION:Do not look directly at the scanner light.The scanner light should be visible under the scanner glass to the right or left.Figure 1: Scanner light visible underneath the glass 1 - Area where scanner light is visible2 - Scanner glass
If the scanner light does not turn on
when the scanner mechanism moves across the scanner bed, continue to the solution to reset the product.
If the scanner light turns on
, continue with the next solution.
Solution two: Check the power connectionFollow these steps to troubleshoot the power connection.
Press the Power button (
) to turn off the product.
Unplug
the product power cord from any surge protector, extension cord, or
power strip, and then connect the power cord directly to a wall outlet.
) to turn on the product.
Try again to make a color copy.
If these steps resolved the issue
, you do not need to continue troubleshooting.NOTE:If
the product works properly when plugged directly into a wall outlet
rather than a power strip or surge suppressor, the power strip or surge
suppressor might not allow enough voltage for the product to work
properly.
If the issue persists
, continue with these steps.
) to turn off the product, disconnect the power cord from the wall outlet, and then reconnect the power cord to a different
wall outlet.
, continue to the next solution.
Solution three: Reset the productFollow these steps to reset the product.
) to turn off the product.NOTE:The product might not turn off after pressing the Power button. Continue to the next step regardless.
Disconnect the power cord from the rear of the product.
Unplug the power cord from the electrical outlet.
Wait 30 seconds.
Replug the power cord into the electrical outlet.
Reconnect the power cord to the rear of the product.
Make a color copy.
When the product starts to scan the document to copy, slightly lift the scanner lid to see if the scanner light turns on. It is not necessary to lift the lid completely.
Solution two: Check the power connection Follow these steps to troubleshoot the power connection.
Press the Power button to turn off the product.
Unplug the product power cord from any surge protector, extension cord, or power strip, and then connect the power cord directly to a wall outlet.
Press the Power button to turn on the product.
Press the Power button to turn off the product, disconnect the power cord from the wall outlet, and then reconnect the power cord to a different wall outlet.
Try again to make a color copy.If these steps resolved the issue , you do not need to continue troubleshooting.If the issue persists we have to reset the printer. Doing reset in the beginning stage is not recommended. Reply me back and i will provide the reset step instruction.
Disconnect the power supply from the back of the scanner base. Disconnect the USB Interface cable and the ADF Accessory cable from the back of the scanner. Press
and hold the E-mail and Copy buttons at the same time. While pressing
the E-mail and Copy buttons, reconnect the power supply to
the scanner. Reconnect the power supply and turn on the scanner. Press the Scan Doc button. the carriage will start moving back and forth in the full scan bed length. To exit test, disconnect the power supply.
If u find this kind of prob then u have scan the required stuff by using ur scanner software if u r using hp then go for controlpanel click on scanner and camera devices and follow the on screen instructions to scan the required one hope this will solve ur prob.
The flashing green light has the following meaning:
• Blinking green: indicates the scanner is waking up from power saving and preparing to scan. • Steady green: indicates the scanner is ready to scan.
How to Adjust the Power Save Settings for the DocuMate 252 1. Right-click on the One Touch icon and choose Show Hardware from the pop-up menu. You can also click the scanner icon at the top of the One Touch Button Panel. If the Hardware View of the panel is open you can also right- click on the DM252 icon. The Hardware Properties dialog box opens and shows information about your Xerox DocuMate 252 scanner. 2. Click the Properties button. Your scanner has a built-in power saving feature that is set to power down after 15 minutes of idle time. You can change the time before the scanner powers down, from 1 minute to a maximum of 3 hours. 3. Click the arrows for the Lamp timeout setting and choose a time setting. To return the scanner to its factory settings, click Reset Device. 4. Click OK to save the changes and close the dialog box.
Let me know if this solves the problem and thank you, Binary Bob
Scanner Failure, Power Off and On' Message Displays on the Control Panel when Copying or Scanning
Issue The message 'Scanner failure, Power off and on' displays on the control panel of the product. This error usually occurs when trying to scan, to make copies, or during the product start up. Try the solutions in this document until the issue is resolved. It is not necessary to continue to the next solution if one solution resolves the issue. Solution one: Check the scanner light Make a color copy of any document by pressing the Start Copy Color button on the control panel. While the product is making the copy, slightly lift the scanner lid to see if the scanner light is visible. CAUTION: Do not look directly at the light. It is not necessary to completely open the lid to see the light. If the scanner mechanism moves across the scan bed, but the light is not lit, click here to service the product . Solution two: Check operating conditions Extreme temperatures can affect the operation of the product. Make sure the operating conditions match those recommended in the User Guide provided with the product. Solution three: Check the power connections
1. Make sure that the product is connected directly to a grounded wall outlet and not plugged into a power strip. 2. Make a color copy by pressing the Start Copy Color button on the control panel. 3. If the error message persists, temporarily move the product to a different room or outlet, and then make a color copy by pressing the Start Copy Color button on the control panel. 4. Check the part number on the power supply to make sure that it matches the part number listed in the User Guide.
Solution four: Perform a power cycle
1. Turn the product off. 2. Unplug the power cord from the product. 3. Wait 30 seconds, and then reconnect the power cord to the product. 4. Turn the product on. 5. Make a color copy by pressing the Start Copy Color button on the control panel.
Solution five: Reset the product Follow these steps to reset the product. Step one: Perform a partial reset
1. Unplug the power cord from the product. 2. Press and hold # and 3 while plugging in the power cord. 3. Make a color copy of any document by pressing the Start Copy Color button on the control panel. If the partial reset resolves the issue, do not continue to the semi-full reset.
Step two: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any phone numbers that are saved on the product.
1. Unplug the power cord from the product. 2. Press and hold # and 6 while plugging in the power cord. 3. Make a color copy of any document by pressing the Start Copy Color button on the control panel.
Solution six: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
