Question about Euro-Pro 8260 Mechanical Sewing Machine
Deluxe denim euro pro
How do I thread this machine?
  • Anonymous Mar 18, 2014
    Euro pro denim machine
  • 323 Answers
All machines thread the same. TTN tension,take up, needle.
Beginning with the spool guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Posted on May 19, 2008
4 Suggested Answers
  • 13 Answers
SOURCE: trhreading
http://cgi.ebay.com/Euro-Pro-Deluxe-Denim-Silk-Sewing-Machine-EP-377_W0QQitemZ8271336746QQcategoryZ3118QQcmdZViewItem#ebayphotohosting If so it threads just like my sewing machine.Draw your thread across the top,down into the first slot,then up and thru the second slot,come down,pass it thru the thread guide on the needle,then thread your needle.Most all machines are basic when it comes to threading.HTH
Kathi
Posted on May 27, 2009
SOURCE: How to thread the euro-pro denim machine model
I need to know where I can purchase a foot pedal for my Euro-Pro Denim 1260 sewing machine.
Posted on Jan 30, 2011
SOURCE: my sewing machine thread keep breaking i dont know
Usually there is a flat spot on the part of the needle that makes it so you can only install it the correct way. Try changing the thread. If it keeps breaking you will need to adjust the threads tension control. If it is too tight your machine won't be able to pull the correct amount of "slack" it needs to make a good stitch. You might only need to turn the adjustment a small amount to make a big difference. The thread should come off the spool and go through an arm that moves up and down. Then the thread loops around the tension adjustment. It will most likely be a knob or dial with numbers on its face. I hope this helps.
Posted on Nov 03, 2011
I need a replacement feed dog and a striker plate for the Euro Pro Deluxe Denim Sewing machine model 1262D
here are 3 sites to email about the parts you need
sewingpartsonline.com
sewvacdoctor.com
a1sewingmachines.com
Aug 03, 2012 | Euro-Pro Sewing Machines
Hello, I have a Shark euro-pro sewing machine. I am sewing denim on denim using singer needles that were suggested for denim. The numbers on the package are 2020 110/18 808 R 130/705H 05 un I...
The size of needle is fine for sewing on denim so unless the needle is bent (and even so) I doubt that is the problem. Breaking upper thread typically has more to do with the threading, ie wrapped around some place along the way or misthreaded somehow, of even if you somehow got knots or that it has somehow got thread around the spindle for the spool. So first recheck the threading. Best to do by simply totally unthreading it, looking closely at the spool and winding and then rethreading it again. Make sure your upper tension hasn't been accidentally tightened too.
Next check the bobbin and bobbin thread. First pull on the thread. Is it pulling real tightly or does it flow out readily? Take the bobbin out and look at it. Check the tension also. Is it too tight? That too can cause the upper thread to break.
Is the needle penitrating the material smoothly? Again examine the needle closely to see if it's developed a burr. Better yet just swap the needle with a new needle and try it.
The majority of the time it is one of these things that will cause the top thread to break.
May 18, 2011 | Euro-Pro Shark 80 - 7133
How to thread euro pro 380a sewing machine lost mannel
My needle will not pick up my bobbin? I have tryed everthing! my bobbin was placed in the holder right. my needle is in the EP correctly! not sure if my Thread is correct in my machine. but I have read the manual and still cant get the needle to pic up. Can some one help me out on this! Euro-PRo 380A
Dec 16, 2010 | Euro-Pro Denim Sewlution 380 Mechanical...
Where can I get bobbin replacements for my Euro Pro EP 380 Denim Sewlution machine? It only came with one. Online somewhere?
You should be able to pick up bobbins to fit the machine at any fabric store. Just take the one you have with you - make sure it still has thread on it, so it isn't taken for store stock.
If you are looking for a bobbin case, then contact the manufacturer's parts department. The number is listed in the back pages of the machine manual. You can also call in at your local sewing machine repair shop - establish a relationship with the repair person. It will serve you well in the future. Good luck!
Aug 30, 2010 | Euro-Pro Denim Sewlution 380 Mechanical...
I need a replacement Auto needle threader. There seems to be no where that I can find the pat numbers for anything on the machine....Euro-Pro 9106 Deluxe Denim & Silk sewing machine.
I've never had an auto needle threader work properly for very long. My suggestion is to not bother to replace it and just relearn how to thread the needle. Sorry.
Jan 13, 2010 | Euro-Pro 9105 Computerized Sewing Machine
How to thread the euro-pro denim machine model 90-1260DX ...or where to locate a manual, Thanks.
Dec 03, 2009 | Euro-Pro 1260DX Mechanical Sewing Machine
Trhreading
Kathi
May 20, 2009 | Sewing Machines
Euro-Pro 8260 Mechanical Sewing Machine Logo
195 people viewed this question
Top Euro-Pro Sewing Machines Experts
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
