Question about American Pro VS1403 Car Audio Amplifier
American pro vs1403 lost one channel out of four
Im pretty sure it can be repaired but i need help, its a 4 channel amp and the other day one of the channels went out.only three work can i fix the problem?? thanx
  • Mark Skinner May 11, 2010
    Hello tertul, I agree with pbabin, he has helped me out in the past and is currently helping me with an infinity amp and it is unusual for just on channel to stop working. I know about electronics as I have a degre for an electronics tech from the mid 1990. I'm just getting back into repairing electronice and it's mostly car amps.
    But, it is possable for one channel to blow out, meaning the output transistors to short out, that should cause it to go into protection mode though. I'm not exactly sure cause I had an amp the same way and the output transistors were shorted and did'nt cause it to go into protecion mode so like pbabin said, check all connections and speaker at that channel and you head unit. Then let us know. pbabin will be able to help you better than I can at the moment until I get some more car amp repairs under my belt then I hope to be as good as he is. Good luck
  • 77 Answers
I also want to add, I just got a crossfire ct-2200 oldschool amp I bought from E-Bay and the description described it to be as one channel not working but other side plays fine. Well, when I got it took it apart did basic test everthing turned out fine. So I hooked it up turned the power on and one channel was'nt playing. I thought maybe something in the input circuit in the amp, the preamp section maybe an opamp. Anyway it turned out to be the sub frquency switch and the stereo or bridge selector switches had sirty contacts. So I sprayed some contact cleaner in them and then a little WD40 to keep them lubricated for sliding. So maybe that might help you out also. Once again, Good luck and let us know what you find out.
Posted on Jan 28, 2009
  • 631 Answers
Have you moved all of the switches, controls and RCA jacks to make sure that the problem isn't a dirty contact?
Have you tried swapping the RCA signal cable from a working channel to confirm that it's not a signal problem?
Have you swapped a speaker from a working channel to the dead channel to confirm that it's not a speaker problem?
It's unusual that one channel goes dead and the rest work.
Posted on May 20, 2008
How Do I wire my American pro bass machine model number vs 1406 limited edition 4-channel amplifier in Bridged mode
You can bridge 2 channels, Not 4. The individual channels will fight each other and one will cook...
Jul 16, 2015 | American Pro Car Audio & Video
NEED HELPPPP with 94 Jeep Wiring
Check out a web site called NAXJA (North American XJ Association) it's a Cherokee forum.
May 21, 2013 | Denso 1994 Jeep Grand Cherokee Laredo 4.0L...
Can 2 ohm subs be used with a 4 ohm 2 channel amp?
You can but you will have to wire your subs in a 4 ohm load then bridge it to your amplifier.....look up parallel wiring on google....Im pretty sure you will have to run jumper wires from your positive and negative of one sub to the positive and negative of the other sub.....then run the two wires to your amp make a 4ohm load.....let me know if that helps you and gd luck!!!!
Mar 28, 2012 | Rockford Fosgate Car Audio & Video
How to wire a sony xm-444 car audio amp so that it is a 2 channel 222w amp
Your amp is a four channel so you have 4 sets of speaker outputs. to bridge this amp to 2 channels is pretty simple, all your have to do is when connecting your speakers instead of using both +, and - from the same channel, use the + from the one channel, and the - from the adjacent channel. Do this for both speakers, if you'll notice you now have 2 empty - terminals and 2 empty + terminals, if so you did it right... Hope this helps, enjoy your amp.
Sep 17, 2009 | Sony XM-444 Car Audio Amplifier
Lost channels
What I did after loads of trial & error trying t follow peoples advice on here so not sure how much of it you need t do (Stage 2) might not be neccessary so try 1) followed by 3) & 4) first ;o) :-
1) Deleted all the channels & reset the factory settings to 0000.
Turned off the box at the plug, left for a couple of minutes & turned back on
2) I reinstalled the software at (Not sure if thats necessary but I did so try this if 3 & 4 dont work without reinstalling)
3) Turned on the Box & went into the menu pressed 1570 on main screen to get into the CAS SASTEM & turned the EMU key ON
4) Reinstalled the channels using Telewest (Even tho I'm with Virgin) & voila, it worked & I can get all the channels again ;o)
Good luck - Stace
Jun 17, 2009 | StarView SV431USB 4-port KVM...
Amp blowing fuses
Your amp is blowing fuses to protect your circuit. The type of 12V battery does not matter. For whatever reason you are over driving the amp. 2 Ohms sounds like a very low impedance for a car amplifier output. I am assuming you have the two 12" speakers wired in parallel. Most are rated at 4 Ohms which means you are pulling twice the current with the 2 Ohm load. Also, the bigger the speaker, the bigger the magnet, the bigger the coil, the larger the inductance, the heavier the load. Make sure these speakers are matched with your amp. A small amp driving large speakers will shut down at high volumes. Try putting them in different channels. Good Luck.
Jun 17, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Dont have wire schematic to hook up american pro bass machine limited edition model 1406,need to know how?
You should go to they are very helpful and pretty much have a schematic for every single car audio situation and they give you all your options. If they have nothing go to and go to the learning section then subwoofer and amp wiring. It all depends on the subs that u wanna hook up to it as well as the ohm impedence and the amount of voice coils and so forth they have all of that.
Jun 13, 2009 | American Pro VS1406 Car Audio Amplifier
Legend Amp hook up manual.
Pretty Straight Forward get a 8 or 4 gauge amp wiring kit.
Run your hot wire to the +12V from the battery make sure to install the supplied inline fuse near the battery don't connect to the battery until installation is complete.
Run the REM to your stereo power ant. Wire. if available.
Run the GND to Metal Chassis Ground keep it as short as possible.
Run the RCA Cable from the back of the Stereo to the RCA Inputs or Low Level on the amp.
This amp is 2 Ohm Stereo Stable which means you can connect 2 (4 ohm) speakers in parallel to each channel or 1 (4 ohm) speaker on each channel or you can connect 1 (4 ohm) Speaker in bridged mode.
There are other speaker configurations you could use but you cannot drop the load below 2 Ohm in stereo mode and no lower than 4 ohm in bridged mode.
Hope this helps
Mar 25, 2009 | Legend LA1490 - American Legacy Series 2 -...
Adding a woofer to a 4 channel amp with 4 speakers
well yeah thats what im doin riht now in my ford taurs what u do is u can hook up your 5x7s and ur 6x9s on ur amp sill have room for a sub the way too do that is get the front speakers off the amp just run the back andsince its a four channlel amp 1 and 2 channel are used for the back and 3 and four are used for thesub of couse u brige the sub to the amp 3 and four are used for the sub hope that helps friend let me no what happens
Apr 08, 2008 | Car Audio & Video
Polk Audio RC55i In-Wall Surround Speakers (can't hear whispers)
I'd make sure that the receiver surround mode is set for one of the digital settings, such as Dolby Digital or DTS, and make sure that you have the center channel level adjusted to a level similar to the other two front channel speakers. I've seen/heard this happening when using dolby digital material & having surround set on something like 'hall' or 'stadium' or dolby surround, where only 4 channels are used & the amp has to 'mix' sounds to the left & right front speakers. It'll often sound like the actors on screen are talking out of the bottom of a barrel, with a hollow & tinny character to the voices.
Jan 07, 2008 | Polk Audio RC55i Main / Stereo Speaker
American Pro VS1403 Car Audio Amplifier Logo
160 people viewed this question
Top American Pro Car Audio & Video Experts
xxxxxx xxx
Are you an American Pro Car Audio and Video Expert? Answer questions, earn points and help others
