Philips tv model 60pp96013 dreamy/cloudy screen and color is not right, bought used
    Genius:
  • Computers & ... Master
  • 1,689 Answers
Your description is really very vague...
Off colour is usually attributed to the picture tube (CRT) getting weak, and the internal automatic bias control can no longer track the emission of the electron-guns in the CRT to compensate for the bias current change with age and use.
It is possible to have some components failing in the CRT drive and bias circuits, but this is rare in these monitors.
I hope you didn't pay very much for this monitor when buying it used.
I would seriously consider a new LCD monitor. Most of these will give at least 3 years of service with full time use.
Jerry G.
Posted on May 19, 2008
I have a phillip magnovax model # 9p6031c102 serial# 38881954. It has been showing multiple color n is hard to see, n is kinda of cloudy
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 21, 2010 | Philips Magnavox 9P6034C 60" Rear...
Philips magnavox 55" rear projection tv problems
  • Screen looks 3D
Dec 11, 2010 | Philips Magnavox 9P6034C 60" Rear...
Philips big screen hazy/color problems easy fix?
Projection TV sets have two common problems. The first is known as a convergence problem. Common symptoms are....
  • Screen looks 3D
The other common problem is cloudy CRT fluid in the lens.
Common Symptoms - you TV may have one or more of these...
  • Dull Video
  • Bright video - whiteish
  • Redish video
  • Halos around objects
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 28, 2009 | Televison & Video
Tv cloudy and faces are red
TV needs CRT coolant replaced, once this is done the focus and color level of each CRT needs to be adjusted for optimum picture. expect to pay around $300 good luck, Julio at Millenium TV , Las Vegas NV (702) 736-1091 milleniumtvsvc@gmail.com
Jul 21, 2009 | Philips E-Box FTR9965 DTV Receiver
TV Contrast Problem for Philips Magnavox 7P4830 W101
Your TV most likely has one or more possible problems.
  • Screen looks 3D
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
May 18, 2009 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 55P8288 Entire picture has green
  • Screen looks 3D
Apr 09, 2009 | Philips Magnavox 51MP392H Rear Projection...
I have a 2002 philips 64" rear projection tv
Easy DIY Fix...See below.
  • Screen looks 3D
Apr 07, 2009 | Philips 60PP9202 60" Rear Projection...
Just bought the Philips 9P6034C 60 in. rear projection, used. The picture is a bit hazy. The buyer told us that we just need to "have the guns put to it". Is there a special tuning device that the tv...
  • Screen looks 3D
Mar 07, 2009 | Philips Magnavox 9P6034C 60" Rear...
5yr old philips rear projecter tv color bad 50inch
  • Screen looks 3D
Dec 01, 2008 | Philips 9P5034C 50" Rear Projection...
Philips 55p8342 chassis ptv916
To get a new remote call a local TV service company or you can order directly from the manufacture. The cloudiness of your colors are caused by possibility of two things or both: 1) The mirror and lenses inside your TV need cleaning (use window cleaner & soft cloth) spray liquid onto cloth, 2) The fluid in picture tubes need to replaced. To replace fluid (ethylene glycol) take tubes out of unit, drain fluid, clean fluid chamber, add new fluid. How you can tell if fluid is cloudy? Take off screen assembly look into each light (red, green, blue) the picture should be clear. The red tube, light, is normally okay, so use as referance.
Feb 16, 2008 | Philips 50P8341 50" Rear Projection...
Computers & Internet Logo
427 people viewed this question
David Payne
David Payne
