Question about Canon imageRUNNER 5000 Copier
Canon Imagerunner 5000 error E000001-0000
Is this error message regarding the same as E000003-0000? If so, how do I resolve? Thanks for you input.
  • 18 Answers
Sort of, since both are fuser temperature related. First, the error needs to be cleared. Turning off/on won't do that.
You could go into service mode and clear the error (*28* > copier> function > clear > err > ok. Then turn the copier off, then on again and watch it heat up. I always monitor the temperature to make sure it's in the acceptable range (190 C or around that range).
If it happens often I'd have the thermistors changed. If it still happens, check the connectors in back of the fuser. They may need to be shimmed.
Posted on May 26, 2008
  • 679 Answers
1) Drum unitIs the drum unit installed in host machine?
NO : Install the drum unit.
2) Connection
Is the connection of the connector (J908) on the BD detection
PCB, connector (J907) of the laser unit, and connector (J102) on
the DC controller PCB normal?
NO : Correct the connection.
3) Laser/scanner unit, DC controller PCB
Try replacing the laser/scanner unit. Is the fault corrected?
YES : End.
NO : Replace the DC controller PCB.
Good Luck
Posted on Feb 03, 2009
good morning sir, my ir machine is 3300 the problem is showing to my machine is E000003-0000 please suggest me answer
Apr 21, 2014 | Canon imageRUNNER 3300 All-In-One Laser...
Tanda error E00000i-0000
Error : E000003-000
Not working any key
Neither Additional function nor *
What to do...
Nov 22, 2013 | Canon imageRUNNER 5000 Copier
Error code e000003 0000
Have you tried unplugging it and plugging it in again?
Nov 16, 2013 | Canon imageRUNNER 5000 Copier
Our Canon ImageRunner 5000S shows the Error Code E000003-0000
this error is related to fixing unit,to reset error:* with head 2&8 together* with head LCD display change press COPIER> Function>Clear>Err>OK switch off/on the machine,if the error return check the AC supply unit or you have to call your service provider
Jul 22, 2009 | Canon imageRUNNER 5000 Copier
Hello sir; Here have few steps you have to follow;
1, press "*"key,
2, press "2"&"8" at the same time .
3, press"*.".
4, click on COPIER then FUNCTION then CLEAR then ERR.
5, press OK, thenturn power off and back on.
Jan 09, 2009 | Canon imageRUNNER 5000 Copier
Error code E000003-0000
im not sure what you had changed but this code is for the upper heat roller thermister detecting an heater error if it wont reset it is bad
Dec 18, 2008 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 5000 Copier Logo
4,980 people viewed this question
old marine
old marine
