Question about Tablets & eReaders
Where are the bios jumpers?
I'm trying to locate the bios jumpers on my HP TC4200 and furthermore I cannot in the manual find what bios jumper settings there are.
Could you please help me?
  • DaKaiser Jun 02, 2008
    Yes, I understand but unfortunately there is a password on the bios. However the person who sold me this computer cannot remember what the password is.
  • Niels Boehme May 11, 2010
    Generally, laptops and tablets do not have jumpers. To get to the bios, some tablets will give you a chance while booting, or you must connect a keyboard and press a certain key to get to the bios.
    What are you trying to do?
  • 111 Answers
Everything about the tc4200 can be found here http://h18000.www1.hp.com/products/quickspecs/12138_na/12138_na.HTML
Posted on Aug 19, 2008
Bios password
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Jul 21, 2010 | Toshiba Portege R100 Tablet PC
Want to reinstall OS on compaq tc4200. don't have passwords..
If the BIOS password is set, you'll need to return the device to HP/Compaq to get that reset. Only other option I can think of would be to whip the hard disk out and see if it'll boot from a CD at that point. If that is the case, you could theoretically put the drive in another PC, wipe it completely and then reinstall it. The machine will try to boot from HDD, fail and then boot from CD next.
Mar 09, 2010 | Compaq tc4200 Tablet PC
M4-s435 bios password removal
Feb 16, 2010 | Toshiba Tecra M4-S435 Tablet PC
TO REMOVE PASSWORD OF THE BIOS
Jan 30, 2010 | Fujitsu Stylistic ST4120P Tablet PC
Password problems on a Toshiba Protege m200 laptop
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password.
  1. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
  2. On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password.
  3. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper.
  4. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
Many RTC's require an external battery. If your RTC is one of this type, you can clear the BIOS password just by unsocketing the RTC and reseating it.
Good luck and more power
nicole
Oct 03, 2009 | Toshiba Satellite R15 Tablet PC
BIOS LOCKED WITH UNKNOWN PASSWORD
By pass it by software or use omnipoten password. here
Apr 13, 2009 | IBM ThinkPad X60 Tablet PC
I NEED TO RESET THE BIOS ON A COMPAQ TC4200
Try holding the power button for 30seconds. This might reset the BIOS settings. If this doesnt work the your gonna have to remove the CMOS battery inside the laptop. You will have to go through the HP service manual and figure out where it is.
Nov 26, 2008 | Compaq tc4200 Tablet PC
Reset the bios on a compaq tc4200
I haven't tried it yet, but according to HP's "Maintenance and Service Guide" (Available in PDF from their Support website) you have to completely break down the computer, remove the mainboard and the CMOS battery should be located on its underside. Remove it for five minutes, replace and reassemble EXCEPT FOR BATTERY and turn it on under AC power only. I just purchased one that needs reset, but haven't received it yet, so I cannot attest to its effectiveness except that this is deirect from HP. Hope it helps!
BIOS PASSWORD RESET
You can use Backdoor BIOS Password Its depends which one is your BIOS manufacturer. There are some listings for different manufacturers:
If you have AMI BIOS then try the followings:
A.M.I., AAAMMMIII, AMI?SW , AMI_SW, BIOS, CONDO, HEWITT RAND, LKWPETER, MI, or PASSWORD.
If you have AWARD then try the followings:
eight spaces, 01322222, 589589, 589721, 595595, 598598 , ALFAROME, ALLY, ALLy, aLLY, aLLy, aPAf, award, AWARD PW, AWARD SW, AWARD?SW, AWARD_PW, AWARD_SW, AWKWARD, awkward, BIOSTAR, CONCAT, CONDO, Condo, condo, d8on, djonet, HLT, J256, J262, j262, j322, j332, J64, KDD, LKWPETER, Lkwpeter, PINT, pint, SER, SKY_FOX, SYXZ, syxz, TTPTHA, ZAAAADA, ZAAADA, ZBAAACA, and ZJAAADC.
Simillarly for Phoenix try the followings:
BIOS, CMOS, phoenix, and PHOENIX.
For others try the followings:
Manufacturer BIOS Password VOBIS & IBM merlin Dell Dell Biostar Biostar Compaq Compaq Enox xo11nE Epox central Freetech Posterie IWill iwill Jetway spooml Packard Bell bell9 QDI QDI Siemens SKY_FOX SOYO SY_MB TMC BIGO Toshiba Toshiba
You can also download the software to reset your passward using software.
To download click here or copy and paste this link to your browser: http://www.cgsecurity.org/cmospwd-5.0.zip
Thanks
iqbal_delphidev@yahoo.com
Mar 11, 2008 | Eaton 30311 Tablet PC
Tablets & eReaders Logo
565 people viewed this question
Top Tablets & eReaders Experts
Justin
Justin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
