Question about Fisher and Paykel GWL11 Top Load Washer
Washer gw11us washer started to make louder noise while filling.sounds like slow bearing noise.only does this while filling sounds normal on all other cycles. thanks.
  • 868 Answers
If it makes it through the cycle from start to finish ,consider yourself a lucky one.If it breaks I don't recommend fixing this.
Posted on May 25, 2008
Whirlpool 5761 Making loud squeaking/odd noises
It sounds like a bearing going since you hear grinding. There is a main bearing on the back in the middle of the machine. There are also two on the bottom about 18 inches apart. Less likely is the belt going from the motor around the drum.
Jan 05, 2014 | Whirlpool Washing Machines
Loud humming or buzzing only when it spins at high speeds
This noise causes by the drum bearing is getting worse. As soon as the noise is getting far louder and extremely louder then you have to replace the bearing of the outer drum. Normally, the repair cost is as high as buying a good deal new washer.
Oct 14, 2013 | Whirlpool Duet 4.0 cu. ft. Washer
2002 camery roaring from front seems louder when slowing down. It is not brakes
check wheel bearing...transmission output shaft bearing. noise is louder because when bearing slow down, they get louder from worn down ball bearing inside the cage, space is developing between the ball bearing..caused by lack of lubricate, or just worn out bearings
Aug 01, 2012 | 2002 Toyota Camry
We have a Whirlpool Duet Sport Front-Loading Automatic Washer and it makes a pretty loud noise when in the spin cycle. The volume is directly proportional as to how fast the washer is spinning. It's a...
The symptoms that you describe are caused by bearing failure. The water seal in the wash tub has failed, allowing water to leak into the bearing causing the bearings to rust. As the bearings start to rust, they will not roll properly and start to make a rumbling sound. The sound get louder the faster the bearing turns.
It a major job to repair since the washer has to be taken apart and the wash drum needs to be removed to replace the seal and bearings. Get a few estimates before deciding whether the washer is worth the cost to repair or replace. Sorry.
Oct 04, 2010 | Washing Machines
Frigidaire dishwasher noticeably louder - circulation motor?
Try to position the machine, so that you can run the cycle and watch the dish washer. Remove the back panel and hear the sound of origination. Take suitable action as per your convenience. You can clean & replace the bearings if they are worn or replace as a whole unit.
Jul 06, 2010 | Frigidaire Dishwashers
My amana washer makes a whril noise when it spines.
UNFORTUNATLY IT IS PROBABLE A SPIN BEARING THAT IS MAKING THE NOISE. THIS IS USUALLY CAUSED BY A LITTLE WATER LEAKING FROM THE CENTER SEAL ONTO IT. IT IS VERY EXPENSIVE TO FIXED AND VERY TIME CONSUMING, PLUS YOU WILL NEED SPECIAL TOOLS DESIGNED FOR THE JOB
Aug 11, 2009 | Washing Machines
Roper RAS7233KQ0 NO SPIN
chek the water elctrovalvles and replace it , this most be 1 solution another will the hyperstatic hose or sensor of load size
Mar 04, 2009 | Roper RAS8244KQ Top Load Washer
Noise in front that like a roaring
is it more of a whining noise,does it go away when you turn corners if it does then it sounds like a wheel bearing.
Dec 15, 2008 | 2004 Suzuki Verona
Maytag Neptune Front Load Washer
No, I'll tell you before forking out $ $ for some bad news.The noise is your bearing. You have to replace the outer tub .Its not going to be repaired any other way.The idiots who designed this washer made this a non servicable bearing.The labor is high not to mention the outer tub is also.REPLACE THE OUTER TUB.
May 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer noise
probably is the bearing will eventualy start leaking from seal
Mar 12, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Fisher and Paykel GWL11 Top Load Washer Logo
228 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
