Question about Dryers
In a gas kenmore dryer, the tumbler is not working
  • rg22154 Sep 16, 2008
    how did you solve it
    Genius:
  • 1,028 Answers
Belt off or broke
Posted on May 19, 2008
Dryer does not heat up when drying. Tumbler works but no heat.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101././
May 03, 2011 | Kenmore HE2 Plus Front Load Washer
Kenmore dryer Model #6507923 Gas sometimes won't
You may have a bad thermocouple. The thermocouple senses the heat from the flame and "tells" the control unit that the flame has lit. If it is sending no signal, the control will think it didn't light and shut off the gas to prevent an explosion. Good luck.
Jan 03, 2010 | Dryers
I have a Kenmore dryer that is 4 years old, very basic model, and it heats only part of the time. At times when it is running there is a gas smell, no heat. Other times just the fan blows with no heat or...
The thermocouple may be going bad. The thermocouple is what "tells" the control unit that there is a flame. If it doesn't send it's signal, the control thinks the flame went out and shuts off the gas to prevent an explosion.
Jan 02, 2010 | Kenmore 73952 Gas Dryer
Dryer does not heat up. tumbler does work.
Gas or electric dryer? If it is electric the heating element may be bad or a thermal limit switch near the heating element may be defective. Is the outside vent plugged?
Sep 24, 2009 | Kenmore Dryers
I have a Kenmore 70 Series gas dryer, model 76712691. The dryer has 3 plastic ''tumblers'' inside the dryer, to help the clothes tumble. Two of the tumblers have fallen off inside, leaving big holes inside...
Pull the dryer away from the wall, there is no bottom on the dryer, so the screws should be on the floor.
You can then pop the lid up from the front and fold it back. When you do, you will see the drum. Roll the drum around until you see the holes and reattach the tumblers.
You can also access the drum from below. Tip the dryer on its back and you can see the drum from the bottom.
Good luck.
Regards,
May 15, 2009 | Kenmore Dryers
Kenmore 90 series
possible burned out heat element
Jan 25, 2009 | Kenmore 73932 Gas Dryer
Tumbler
You may have had a wheel lock up on the dryer. This could cause the belt to break. Is the drum hard to turn? Is this a gas dryer? use this PAGE as a guide to help you get into the dryer and a lot more
Nov 03, 2008 | Kenmore 62622 Electric Dryer
Tumbler doesn't rotate for Kenmore 76722 Gas Dryer
soulnds like the belt pooped, or broke, remove top you should see the belt wrapped around the drum, if not you need a new one
Feb 21, 2008 | Dryers
Changing tumbler belt on a Kenmore gas dryer
you have to unscrew the screws in the lent trap and pull up on the top piece it has platic snaps the pop up then unscrew the front two on the front piece then the tumbler will pop out thats it.
Jan 12, 2008 | Kenmore 75944 Gas Dryer
Dryers Logo
32 people viewed this question
Top Dryers Experts
