KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
Posted on Sep 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dishwasher does not drain - KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Anonymous
Level 2:
New Friend:
  • Expert 83 Answers
  • Posted on Sep 19, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
83
Questions
0
Helped
29750
Points
232
Be sure the screen under the botton spray arm is free of food particles. You may need to remove it to clean it. Make sure the drain hoses are not kinked.If this doesn't help the problem, you will need to pull the dishwasher and disconnect the drain hose from both ends and flush out debris at the sink. You may need to replace the drain valve.
Frigidaire dishwasher doesn't drain at end of cycle.
Question edited for clarity, spelling of maker.
Question moved to category
4 Tips for a Frigidaire Dishwasher Not Draining Water
Lake Appliance Repair https://lakeappliancerepair.com > blog > frigidaire-dis...
Sometimes, a Frigidaire dishwasher not draining water is due to an air gap or garbage disposal clog and not a dishwasher issue. If you have an air gap or ...
There is a 1 to 2 inches of water left after cycle ends.
iFixit https://www.ifixit.com > Answers > View > There+is+a...
Sep 25, 2017 - A dishwasher filter/trap/drainage basket that is clogged with chunks of food is the leading reason water remains at the bottom of a dishwasher.
3 answers · Top answer: Hi @cadillachawk , Try running the drain hose along the floor and into a bucket (or two) and ...
Does not drain the water at the end of cycle - Dishwasher
Apr 30, 2010
New Dishwasher won't drain water at end of cycle
Jul 11, 2017
More results from www.ifixit.com
Frigidaire Dishwasher Not Draining ...
Repair Clinic https://www.repairclinic.com > RepairHelp > Frigidaire...
The check valve prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining.
Frigidaire Dishwasher won't drain at end of cycle
Reddit · r/appliancerepair 8 comments · 1 year ago Check drain hose for debris, kinks, and partial blockages. check float sensor. Make sure it moves freely. check chopper to see if full of debris ...
Frigidaire dishwasher not draining. : r/appliancerepair - Reddit
Jun 26, 2022
Frigidaire Dsiwasher not draining. Any advice please? - Reddit
Aug 8, 2022
r/fixit - Frigidaire dishwasher has water sitting at the bottom at ...
Feb 8, 2023
Frigidaire dishwasher not draining before dry cycle - Reddit
May 25, 2023
More results from www.reddit.com
Frigidaire Dishwasher Not Draining? Here's What to Do
fredsappliance.com https://fredsappliance.com > dishwasher-repair > frigid...
Jul 7, 2021 - Another common cause of a dishwasher not draining is a defective drain pump. To access the drain pump, you will need to follow the instructions ...
2answers
Dishwasher ADPU 701 WH showes error code F6 E1. Stopped mid cycle. How can I drain the machine ?
Error code F6 E1 on a Dishwasher ADPU 701 WH typically indicates a problem with the water pump or drain system. It is possible that the dishwasher stopped mid-cycle because the pump is clogged or the drain is blocked.
To drain the machine, you can try the following steps:
Unplug the dishwasher: To ensure your safety, unplug the dishwasher from the power outlet before attempting any repairs.
Locate the drain hose: The drain hose is typically located at the back of the dishwasher, near the bottom.
Detach the drain hose: Use a pair of pliers to gently loosen the clamp that secures the drain hose to the dishwasher. Then, carefully remove the hose from the dishwasher.
Place the drain hose in a bucket or sink: Position the end of the drain hose in a bucket or sink to allow the water to drain out.
Check for blockages: Inspect the drain hose for any blockages or debris that may be causing the error code. Use a small brush or toothpick to remove any blockages.
Reattach the drain hose: Once you have cleared any blockages, reattach the drain hose to the dishwasher and secure it with the clamp.
Plug in the dishwasher: Once the drain hose is securely in place, you can plug the dishwasher back in and try running a cycle to see if the error code persists.
Dec 25, 2022 • Dishwashers
Kitchen aid dishwasher m # kdfe304dss wont drain , can hear clicking sound from underneith.what do you recommend? 14 months old.
KitchenAid Dishwasher Not Draining - Model KUDP02CRBL0
www.repairclinic.com/RepairHelp/...Dishwasher/...-/KitchenAid-Dishwas...
See All Dishwasher Parts for model KUDP02CRBL0. Cause 1 Drain ... If the drain pump motor is not working, the dishwasher won't drain. To determine if the ...
How to repair a dishwasher, not draining - troubleshoot ...? 6:18https://www.youtube.com/watch?v=rO19zoOyNHAFeb 26, 2014 - Uploaded by AdamDIYMost of the time if it is not draining, the garbage disposal is clogged or there ... If you have a newer model dishwasher that looks different from the one .... But with the help of your video, I was able to show her where her ... How to Fix a Dishwasher thatWill Not Drain : How to repair your home - Duration: 1:50.Missing: kdfe304dssDishwasher Repair-Will Not Drain-Part 2 - YouTube? 4:14https://www.youtube.com/watch?v=dYHTdzQrsBAApr 20, 2013 - Uploaded by Frosty LifeInstructions 1 Press the "Cancel/Drain" button on yourKitchenAid dishwasher after the Clean light comes on to manually drain the standing ...Missing: m ‎kdfe304dssReviews on kitchenaid dishwasher kdfe304dss
Model 665.13929kq11. Why isn't it draining completely?
Dishwasher is draining slowly , and not completely ... - iFixit
https://www.ifixit.com/.../Dishwasher+is+draining+slowly+,+and+no...
iFixitJun 26, 2014 - I have a kenmore dishwasher (about three years old) ! ... with a solid plug in the drain tube for situations where a dishwasher isn't connected.
My Kenmore Dishwasher Won't Drain and is Leaking- How ...
? 5:35
https://www.youtube.com/watch?v=u7uaA2NZKl0
Nov 14, 2011 - Uploaded by mkbrennan13
This is a video to help someone fix their dishwasher. It's a How to fix your dishwasher that won't drain. If your dishwasher isn't draining and ...
How to fix drain problem with kenmore dish washer - YouTube
? 6:46
https://www.youtube.com/watch?v=ZMPXn6XgRkk
Aug 16, 2010 - Uploaded by itdatanow
Kenmore dishwasher would not drain. ... How to fix drainproblem with kenmore dish washer ... Is Your Dishwasher DrainInstalled Properly?
Doesn't drain
If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
HERE ARE SOME OTHER COMMON CAUSES:
H Drain impeller. The drain impeller is attached to the pump and pushes the water out of the dishwasher through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit. The drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve. The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced.
Clogged or Improperly Installed Garbage Disposer. If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug needs to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve. The check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball. The check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
HOPE THIS HELPS.
HOPES THIS HELPS.HOPE
Bosch shu43c02uc
test this steps and fix it. God bless you
Belt, Water Pump
Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Drain Pump
Drain Impeller
The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit
If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve
The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly
If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose
If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve
If the dishwasher won't drain the check valve might be stuck closed. The check valve is a device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is located in or at the outlet of the pump that the drain hose attaches to. Sometimes the check valve is accessed from the inside of the unit depending on the model.
Check Ball
If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Jul 22, 2013 • Dishwashers
1helpful
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
3answers
Dishwasher not draining
Thanks for writing to Fixya.com.
To fix a dishwasher that will not drain, remove any clogs that are blocking the drain line by pouring a paste of baking soda, vinegar and water down the drain, and then pouring boiling water to clear the clog. Repeat the process several times to remove a severely clogged dishwasher drain. Thanks for contacting Fixya and please accept the solution if it has helped you.
5helpful
MY SON'S DISHWASHER WON't drain
Hello there:
Please try these things below my post and click on the links that are available for you ok
I hope that tthis is very helpful for you
best regards michael
Water will not drain from my dishwasher. Investigate these six areas if water will not drain from your dishwasher :
dishwasher_drain-hose.jpg Drain Hose
It is quite common for a dishwasher to not drain because either the drain hose or the air gap (if the unit has one) is clogged up. Drain hose clogs commonly occur where the hose is attached to the main household drain line, or where the hose connects with the garbage disposer. Try removing the drain hose to unclog any debris. Don't forget to reattach the hose before you start your dishwasher again.
dishwasher_pump-repair-kit.jpg Pump Assembly
The pump assembly is comprised of a pump, wash impeller, and drain impeller. The pump ejects the water from the unit, the wash impeller pushes water through the spray arm, and the drain impeller directs the water towards the drain port. Examine your dishwasher's pump assembly. Clean out any debris that may be blocking it. Replace the pump assembly if any of its parts appear to be worn or defective.
dishwasher_belt.jpg Belt
It isn't very common, but sometimes a dishwasher's pump assembly is driven by a belt. If that belt becomes worn and defective, then it cannot properly run the pump that drains your dishwasher's tub. If your dishwasher uses a drive belt, examine it now. If it shows signs of wear, replace it.
dishwasher_timer.jpg Timer
A defective timer could interfere with a dishwasher's ability to drain properly. Test your dishwasher's timer mechanism. If it is faulty, replace it. Keep in mind that you can replace either the entire timer assembly or just the timer's motor.
dishwasher_motor.jpg Motor
The motor plays a key role in a dishwasher's ability to drain water. If your dishwasher's motor is not functioning properly, it will negatively affect the draining capability of your machine. Test your dishwasher's motor for continuity. If it fails the test, replace the motor.
dishwasher_drain-solenoid.jpg Drain Valve and/or Solenoid
In some models, a valve has to open in order for the water to drain out of the dishwasher. This valve is controlled by a solenoid, but it is the timer that decides when the valve should open. If your timer is working fine, check the drain valve and its solenoid. If need be, replace them.
Top KitchenAid Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
