Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Problem with usb
"insert a disk into drive" this message appear when i open my usb
  • 2 more comments
  • zulqernan May 19, 2008
    the problem is start when i install folder lock password to my usb.then i install another usb password protect.now when i open my usb. the message appear"plz insert a disk into your drive.when i check usb properties;its shows total space 0 and free space 0 plz help me out to this problem
  • Anonymous Jun 09, 2008
    my device is not detected by my laptop
  • Anonymous Jun 13, 2008
    i m having same prob when i plug in my usb and want to open it it shows insert a disk into drive
  • Anonymous Oct 03, 2008
    my USB appears to be Removable Disk F: in my pc. i inserted it in another PC but still the same problem. I think the SoWar virus caused it.
No thing
Posted on Jun 01, 2008
    Problem Solver:
  • 5 Answers
It seems like your USB drive is not detected by the computer. Try inserting it on a different USB port. You will see another drive letter like F: or G (removable drive) when you USB drive is detected.
Posted on May 18, 2008
3 Suggested Answers
SOURCE: My USB flashdrive cannot be opened
my usb flash drive cant be opend.
Posted on Dec 29, 2009
odiebugs
  • 949 Answers
SOURCE: "Plsase insert a disk in the drive" message for USB drive
Up to you,, if you put a flash drive into your USB port, and windows see's the drive, because its listed under my computer, but when you go to open the drive it says, please insert disk
This is telling you the flash drive has failed.
The only good thing is, if you have anything on the drive, there are programs that will extract the data from the drive so you don't lose it.
You have three options,
Extract the data that is on the drive.
Try a repair program, which can erase the drive when it tries ti repair it.
Send the flash drive to the company for repair.
Posted on Feb 16, 2010
Testimonial: "Thank You very much sir."
My USB giving message of Insert a Disk into drive !
Your USB IS DAMAGED TRY TO PULL OF THE COVER OF THE USB DAN CLEAN IT WITH A TOOTH BRUSH OR ANY SOFT BRUSH DAN PUT IT BACK TO YOUR COMPUTER AND GO STRAIGHT TO MY COMPUTER AND FORMAT IT USING QUICK FORMAT SYSTEM. :)
Apr 16, 2010 | Electronics - Others
MY PENDRIVE IS NOT ACCESSIBLE . WHEN OPENED MESSAGE APPEARS INSERT DISK IN DRIVE:E
First try another computer if the same problem appear, try to open the system of the pc by pressing F2 or F10 depending on your BIOS and select USB boot device there.Restart the computer and try to load the pendrive. Another you may need to installe USB driver from your motherboard installer.
Jan 26, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
USB DRIVE NOT ACESSABlE
youve got a problem with you USB connection in your PC... try to use another USB connection...
Jun 16, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
KINGSTONE 2GB pENDRIVE dID NOT WORKING
show my drive but not open it and display insert disk to drive.
Feb 02, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Solve the maxell 2gb usb problem
virus............
remove the virus with an updated virus cleaner.
Nov 21, 2008 | Electronics - Others
How do I get started using a USB flash drive and how do I set up a security system?
hey, heres something that would help u:  Copying files to a flash drive on a PC:
  1. Open My Computer and see which drives are shown. Most computers, for example, have a hard disk such as a C: drive and a few removable storage devices such as a floppy drive, a CD-ROM drive, and perhaps a zip drive.
  2. Insert the flash drive into the USB port and watch to see where the USB flash drive appears. Most will appear as removable storage, but some will instead appear as hard drives. Note the name Windows is using to refer to the flash drive ("Removable Disk (G:)," for example).
  3. Open My Documents or the location from which you want to transfer files to the flash drive. Select the files or folders you want to save to the flash drive by left-clicking on them. To select more than one, hold down the CTRL key while you click and select all of the files you wish to save.
  4. Right-click on the file(s) or folder(s) you selected, then select Send to, then select the name you saw appearing in My Computer for the flash drive ("Removable Disk (G:)," for example).
  5. When the copying is finished, do not immediately remove the flash drive from the USB port. Instead, left-click on the Remove Hardware icon toolbar.gif located in the System Tray. A window containing a list of the USB devices will appear. Left-click on the Safely Remove Mass Storage Device line that matches your flash drive (for example, Safely Remove Mass Storage Device - Drive(G:)).
  6. When you see the following message appear in the bottom left toolbar, it is, as it says, safe to remove the flash drive from the USB port; you may close the message or ignore it, as it will close itself automatically:
Copying files from a flash drive on a PC:
  3. Double-click on the flash drive to locate the file(s) or folder(s) you want to copy to this computer. Select the files or folders you want to copy by left-clicking on them. To select more than one, hold down the CTRL key while you click and select all of the files or folders you wish to copy.
  4. Right-click on the files or folders you have selected and choose Copy.
  5. Open My Documents or the location to which you want to transfer files from the flash drive.
  6. Click on the Edit menu, then select Paste.
  7. When the copying is finished, do not immediately remove the flash drive from the USB port. Instead, left-click on the Remove Hardware icon toolbar.gif located in the System Tray. A window containing a list of the USB devices will appear. Left-click on the Safely Remove Mass Storage Device line that matches your flash drive (for example, Safely Remove Mass Storage Device - Drive(G:)).
  8. When you see the following message appear in the bottom left toolbar, it is, as it says, safe to remove the flash drive from the USB port; you may close the message or ignore it, as it will close itself automatically:
    ok_msg.gif                                      =========================================================
For the security system setup go through the following link .. http://www.rohos.com/configuring_usb_stick_logon.htm
if u require some other sort of security system let me know.
cheers
Oct 13, 2008 | Computers & Internet
Kingston pen drive locked by LOCKv116.exe
i have same problem with kingston 2GB, i format my pc, also with pen drive attached , now it saying please insert message but pc will detect it
Feb 07, 2008 | Computers & Internet
LOCKV116
hello, i have a Kingston 2GB Pendrive.I had run a program "LOCKv116.exe" on my pendrive and set password on it, but now after inserting pendrive to my pc, it is detected but when open it this message appears "please insert a disk into drive G:" If try to format it message is "There is no disk in drive G:"..If I run the program LOCKv16.exe it shows a message "please insert the device or run this utility as previledged user."
Dec 28, 2007 | Computers & Internet
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
291 people viewed this question
Top Kingston Computers & Internet Experts
Alun Cox
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
