Question about Frigidaire Refrigerators
How do I get scotch tape off the metal frigidaire?
    Genius:
  • 1,073 Answers
Wd 40 or gue gone both at lowes
Posted on May 18, 2008
Switch not working
I have an older electric Perfect Chair model and the switch has go out twice.
To fix mine here's what I did. you will need a butterknife, scotch tape, flat screwdriver, allen head wrench to fit screws on inside panel.
1. Scotch or painter tape on the wood around the switch so as not to scratch it.
2. Pop the switch box out of the wooden chair leg by using a butterknife edge (similiar flat tool will work).
3. There are six wires attached to the switch-single orange, double orange, single yellow, double yellow, blue one and a red one. Diagram which
wires go where so can hook back up correctly.
4. Unhook the wires from the switch.
5. Easier to rehook up the wires if remove the panel from the inside of the wooden chair leg. Need the correct size allen head or six sided wrench to remove the the 3 screws on this panel.
6. Open the switch by popping up the button. gently use a small screwdriver to do this.
7. There are 2 small metal slips/pedals at the bottom of the switch. the switch stops working when one or both of these get out of place.
8. Need to replace the metal pedal in correct position.
9.Replace the the button on the switch carefully to avoid disturbing the metal pedals.
10. Hook up the switch wires-see #3 and 5 above. my chair worked after this fix ! let me know if this helps - rhph@sbccglobal.net
Apr 05, 2013 | Human Touch The Electric Zero Gravity...
What makes duct tape stronger than scotch tape?
Duct tape is much stronger than scotch tape for a few reasons. The first being that it is generally wider than a roll of scotch. Also, duct tape is made using cloth and is even coated in polyethylene.
Jan 30, 2013 | Hardware & Accessories
How do you open a Scotch Tape Dispenser C60 to change the tape
The entire carriage lifts out using a good amount of lifting force. Slide your finger under the empty roll from the front of the dispenser. Apply upward pressure. You may be concerned that you will break the plastic roller, you won't. the entire carriage will pop up. When it does it's a simple matter to replace the old tape with a new roll. Snap the carriage back into place to use the new roll.
Jan 21, 2013 | Scotch C60 black 2 Tone Desktop Tape...
Spl-s302d shredder door open
Check to see if there's a little piece that broke off from the door. This would be the "safety interlock switch" or little thingy that pushes down the basket sensor. The basket sensor is located on the bottom front of the shredder. I bent a paper clip to hold down the metal switch (basket sensor) and taped it to the front of the shredder with scotch tape.
Jan 07, 2012 | Staples Office Equipment & Supplies
I am using Scotch Magic Tape 3/4" purchased from
I can't give you a refund, seeing that I don't work for Scotch, but you might have success if you go back to Costco, or if you call the Scotch company to complain about the lack of quality in their products.
Apr 04, 2011 | Scotch Magic Tape Multipack
How can ii remove scotch tape adheasive from a metal table
WD-40 or lighter fluid removes adhesive pretty good, or you can go to any hardware store and buy adhesive remover.
May 17, 2010 | Garden
How do I remove scotch tape from paited surface? When I peel it, it takes off the paint. I used scotch tape to hang spider webs for a Halloween party and now I cannot remove the tape without taking off the...
Yikes, sounds like you had a bad paint job! I would try goof off the waterbased orange gel first.
Sounds like you may need to take a bit of the peeling paint to your local paint store and get them to match it. A chip at least the size of a quarter will help them. Then fill the chipped area's with Crack Shot filler and touch up.
www.outbackpaintingusa.com
Nov 02, 2009 | 3M Scotch Filament Tape Hand Dispenser...
I have a VHS tape that had the tape severed can I use regular scotch tape to repair?
Yes, but to minimize the possibility of tape head damage tape on the inside of the damaged tape (that is the side facing the cassete not the outward facing side) and trim the scotch tape slightly smaller then the tape so no scotch tape is exposed - note you still run the risk of head damage but I've done it many times b4 with no problem
Oct 19, 2009 | JVC DF420 D-VHS Tape
Broken camcorder 8mm tape
Hi There, You can fix your tape yourself. 1- wind out tape from both sides of cassette. 2- cut both sides to form straight edges. 3- cut a small thin piece of clear scotch tape. 4- from cassette tape, put both sides together with recorded side facing down-- in other words you will be putting the scotch tape on the inside of the recorded tape. 4- line up the two ends and splice them together. - cut the excess scotch tape from the edges. Make sure there is no sticky stuff left there because if there is, it could rip out your video heads. The tape should only be played once and at that time, should be rerecorded to dvd or another media.
Hope this helps, mr cicmo
Jan 12, 2009 | Sony Handycam CCD-TRV68 Camcorder
Keypad not working
The keypad part number is DE34-00194B it is either a bad part or the ribbon is not plugged in
Oct 30, 2007 | Samsung MD800SC Microwave Oven
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
