Back to:
Tags:
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
How do you apply attatchment for upholstery cleaner (by 2 users)
posted by megsmrt on May 18, 2008
I cant seem to get the upholstery attatchment to go on propery
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by loststables, posted on Jun 24, 2008
Hi, I have an older model steam vac, and we are trying to hook up the upholstry attachment to it. I am not sure if we have all the correct parts for it, cause its been a long time since that part was used. I need help hooking it up. Thanks
Solution #1
posted on May 26, 2008
Not Rated (0)
reddevil6
Rank:Guru Guru
Rating: 88%, 1206 votes
If can only go on one way so it will lock. If it doesn't, then something is broken either the attachment or the hose end where it hooks to.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on how do you apply attatchment for upholstery cleaner:
I don't want to Accept this solution
Can you Help with these Vacuums problems?
Hoover SteamVac Carpet/Upholstery Deep...
Im trying to steam clean rug....water is in...
i want to clean my furniture but put the hose in the...
I would like to know how to hook up attachment to cleaner...
I have dog hair and dirt jammed under a plastic cover on...
1. handle wobbles back and forth, does not snap into...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
