Question about Canon PowerShot A510 Digital Camera
It keeps asking me to change the batteries
I have changed batteries. I have cleaned the connection terminals. I have looked at the spring to see if it is in contact with the plate and none of these solutions has changed anything. What could be wrong with the A510 that it continues to tell me to change the batteries?
  • MarlaK Aug 26, 2008
    Every time I switch to take a picture (shooting mode) I get an error change batteries. I changed the batteries a few times and I still get the error. I can use the playback mode with no issues or errors to review the pictures and videos on the card with no issues. Is this camera toast?
  • Anonymous Sep 23, 2008
    I have the same problem and do have rechargeable batteries. Doesn't seem to make any difference.
    Problem Solver:
If you haven't already, buy rechargeable batteries. I used to have the same problem. If you are using regular batteries, there juice is used up very quickly. I use Energizer rechargeable batteries and they recharge in 15 minutes. Also you'll have to buy the charger as well. I hope this helps your problem.
Posted on Aug 14, 2008
Changing battery, went to hook up neg. terminal after positive terminal and sparks flew from battery and starter engaged with key off and bike grounded. What to do?
i'd say make sure you have it connected to the right terminals, and if it is check and change the relay it might be stuck, or the spring is broken inside
Mar 06, 2011 | 1993 BMW K 1100 LT
What size does battery does it take and if i change the battery will it lock the whole car up or do I have to take it to the dealership
this vehicle takes a 65 series battery. step one is to disconnect the negative terminal. step two is to disconnect positive terminal. step three is to remove battery hold down which i believe is held down by a 8 m.m. bolt located in front of battery (side facing engine). inspect terminals for acid corrosion if needed clean before connecting to new battery. keep keys in pocket in case doors decide to lock one new battery is connected. installation is reverse of removal. if this was helpful please leave positive rating.
Nov 30, 2010 | 2004 Mercury Mountaineer
How do you change the battery?
  • Look at the battery tray. If there are signs of rust and corrosion, clean it off with plenty of clear water. Allow the tray to dry and spray it with the primer to prevent further deterioration.
  • Place the new battery in the tray and reinstall the hold down clamp.
  • If you have a top terminal battery, clean the inside of the cables with a battery brush and wire brush the battery posts. If you have a side terminal battery, clean the terminals with the wire brush.
  • Check and make sure there is no corrosion on the battery cables. Clean them as required.
  • Reattach the positive battery cable first and then the negative battery cable. Tighten the tight but on side terminal batteries do not over tighten. You can pull the side post out of the battery if you over tighten them.
  • Give the terminals a good coating of White Lithium Grease to keep them from getting corroded.
  • Start the engine and you're done. This is a quick and easy job that should take 30 to 45 minutes.
    Additional Information provided courtes
Dec 04, 2009 | Nike Lance 10//2 Chronograph Watch...
LIGHT WORK RADIO WORKS, CAR CLICKS WHEN YOU TURN THE KEY. COULD IT BE THE 4YR OLD BATTERY
if the blinkers are flashing like normal speed then most likely no. Try cleaning the battery. If still clicks you prabably have a bad starter.
Nov 09, 2009 | 2001 Ford Focus
Thunderbird 2002 jump started and ran for 30 seconds then shut off, won't re start. Car has been idle for over a year. Battery is relatively new.
clean out all of the old fuel, change plugs, check all vacuum lines, replace coolant. Change air filer and check the aire flow meter between the air filer and the throttle. before you try to start the car.
Jun 08, 2009 | 2002 Ford Thunderbird
Changed battery now no electricity
Hi I am Vortash .. this may seem like a silly question but I have to ask .. are you sure you connected the terminals the right way round ?. You would be amazed to how many people who text back and say oops no .. lol.. if you did then just check the earth strap if it was loose when you put the new battery on you may have disturbed it and it is not contacting properly .. clean and tighten ..regards Vortash ..
May 18, 2009 | 2008 Qlink Legacy 250
My problem is not fixed
reset all settigns to factory defaults.also clean dust from circuit u can do it.come on.
Jan 21, 2009 | HP 49g+ Calculator
Oil on sprark plugs
  1. Disconnect the negative battery terminal.
  2. Remove the valve cover, using the proper procedures.
  3. Remove the camshaft, shims and rockers, if equipped, using the proper procedures.
  4. Remove the spark plugs.
  5. Rotate the engine to Top Dead Center (TDC) for each cylinder's seals that are being replaced; e.g., if replacing the No. 2 cylinder valve seals, have the No. 2 cylinder at TDC. Use a coat hanger put down into the cylinder to determine when it is at TDC.
  6. Attach a fixture at the flywheel or the front of the engine to prevent the engine from rotating. Make sure the fixture damages no components.
  7. Thread an adapter into the spark plug holes that can be hooked up to a shop compressor air hose.
  8. Apply 90 psi of shop compressor air to the adapter hose. This is done to keep the valves from dropping down into the cylinder when the valve springs are removed.
CAUTIONTo avoid personal injury, wear eye and ear protection. Keep hands and clothing away from engine parts that rotate, in case the engine does rotate from the cylinder air pressure.
  1. With the cylinder under pressure, remove the valve spring retainer and the spring, using a spring compressor tool. Hitting the spring retainer with a soft hammer may help loosen the valve keepers, if the keeper will not move downward when trying to compress the spring.
  2. With the valve spring removed, remove the oil seal.
To Install:
  1. Install a new seal, using Toyota Special Service Tool (SST) 09201-41020, or equivalent.
  2. Reinstall the valve springs (See Valves).
  3. Release the air pressure and reverse the removal procedures to complete installation.
  4. Connect the negative battery terminal, start the engine and check for leaks.
0900c15280046373.jpgFig. 1 Removing the valve sealsCelica 0900c15280046378.jpgFig. 2 Intake and exhaust valve sealsCelica 0900c15280046379.jpgFig. 3 Installing the valve sealsCelicaWith Cylinder Head Off Engine
  2. Remove the cylinder head, using the proper procedures.
  3. Remove the valve and spring (See Valves).
  4. Remove the oil seal.
To Install:
  2. Reinstall the removed components to complete installation.
  3. Connect the negative battery terminal, start the engine and check for leaks.
Aug 25, 2008 | 1990 Toyota Celica
My bulova watch isn't working
Even you change a new battery with desame size and volts not working.The problem is in the terminal where going to put the battery.The terminal had a dirt or a film residue that comes out from the battery,you better clean terminal by scratching the old film,the lying down terminal is negative,,the side terminal is positive you better observed polarity if happen inter change the battery side it will not works.If not working, even you clean already terminal,short the terminal connection for 3 seconds,If you have a flourescent with a ballast,put your watch lying where there is strong vibration for five minutes, your watch works 100% txt me whatever the result so i know it's ok.
Jun 02, 2008 | Bulova Men's Watch
Canon PowerShot A510 "change the batteries"
Take a look at the following recall advisory for the A530/A540.
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=12914&keycode=2111&id=28800
Look closely at the second picture. Does the spring on your battery door stick out and overlap/touch the metal battery contact plate as shown in the second picture? If so, affix a small piece of tape to the contact plate between the plate and the spring to insulate the plate from the spring. Make sure that the spring should not be able to directly touch the plate, and is shielded by the tape.
Note that currently Canon has not included the A510 in the recall, but if you experience this problem, this fix should correct it.
Feb 17, 2008 | Canon PowerShot A510 Digital Camera
Canon PowerShot A510 Digital Camera Logo
384 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
