Question about Sony KV-9PT40 9 in. Television
Swivel top I would like to remove the under-counter top swivel section . Can you help?
  • m3reyna Oct 05, 2008
    I am unable to get the under-cabinet bracket removed from the TV itself. Any solution would be appreciated.
It was difficult! But we did find the owners manual online free. You just have to sign up at this site and then you can download it. User manual SONY KV9PT40 - User guide SONY KV9PT40 - Operating instructions SONY KV9PT40 - - Diplodocs
The long and short of it - with the swivel attached to the cabinet still, pull down from the back of the tv and toward you. W had the base off the cabinet so I put the whole thing on the floor, put my feet on the back of the swivel, pulled the tv up and away from me. It took a bit but it finally broke free.
Posted on Dec 07, 2008
AEG dishwasher integrated Model newly installed but when I lower the door to load it the dishwasher moves out from under counter and then wont close properly how do I solve this problem?
The built-in dishwashers are almost fixed by screws in top or by side. Carefully read the installation manual where it is explained in detail how to fix the dishwasher under the kitchen worktop. You also need to adjust the height by using the swivel legs that will additionally fix the dishwasher.
Dado
Jun 24, 2017 | AEG Dishwashers
How do I remove the swivel neck assembly from the vacuum case?
You will also need to remove the screws on the inside that hold the motor in place because part of the side support for the swivel is under the motor. Remember to disconnect wires coming from the swivel as well before you try to pull it out, so that you do not damage them. Hope this helps.
Jul 16, 2014 | Windsor SR12 Sensor Bagged Upright Vacuum
How do i detach hose to remove blockage?
Lift the hose out as if you were going to use the attachments. At the base of the hose there is a swivel to adjust the hose 90 degrees. Where the lower section of the hose attaches to the swivel you will see that if you give the hose about a quarter turn then lift, it should come off to check for blockage. Also check the rear suction port located near the hose swivel for blockage. It resembles a parallelogram in shape and come off with 2 visible plastic screws.
Apr 27, 2012 | Miele S7210 Bagged Upright Vacuum
We purchased a 16927 Series SSSD 5 years ago. the faucet doesn't swivel on the base, so the nut securing the faucet to the sink continues to loosen under the sink. I've tried lubrication, I've...
There is a possibility of corrosion between swivel and base. Remove faucet and take to a work table and try and twist swivel spout off. I t may be tight, but the unit is not satisfactory and may need replacement. I have repaired such faucets before and many have been cheaper to replace. There a o rings between spout and body if you get it apart check mating surfaces any erosion discard unit. If OK replace o rings and use silicon grease. No petroleum products as this will cause o rings to swell. Good Luck
Nov 16, 2017 | Plumbing
The power was not copming on becaise the little metal contact at the bae of the tower was nopt making connection to the silver power post. I removed the top and the swivel midsection to rebend the metal...
Hi the tomato m,
I work for the Ionic Pro company. Please call customer service at 800-875-8577 and they will be happy to assist you. Thank you, Mary
Dec 24, 2010 | Ionic Pro TURBO Air Purifier
Front wheel wont swivel
check for missing bearings in the swivel section
loose or worn shaft
replace the front wheel swivel unit
May 07, 2017 | Phil & Teds E3 Twin Seat Jogger
I'm trying to attach supporting brackets to the rear of an LG SL90 TV. Should I use the same holes used for the supplied table top swivel mount?
Do not use the 4 holes for the table top swivel mount.
You have to use the 4 holes in the middle section on the back of the TV. These four hole are spead futher apart and require larger and shorter screws.
Good Luck.
Jun 27, 2010 | LG Televison & Video
How do I remove the swivel base?
Steps to remove swivel stand:
  1. Carefully place the product screen side down on a cushioned surface that will protect the product and screen from damage.
  2. Remove the 2 screws that are vertically in line next to the power socket.
  3. Remove the 2 screws that are vertically in line under the RGB socket.
  4. Pull the stand out from the bottom of the TV.
  5. Reinstall the stand in reverse order.
Nov 03, 2009 | LG 42LC2D 42 in. LCD HDTV
Gateway CX2620 Swivel Screen Laptop
This is the worst solution I've ever heard. This guy is trying to steer you wrong I'm pretty sure. There is zero point in removing all the screws from under the batter/ zero point to removing the area around the power button. Absolute BS. The only part to remove is the part just above the top of the keyboard (silver strip with some black). Then by removing that you can pry the swivel black plastic cover off. Whatever you do.. do not follow Scott's writeup here. I'm telling you. It's sad it's stayed up so long.. so had to warn.
Dec 10, 2008 | Gateway Convertible CX2620 Notebook
Assemble Swivel Assembly onto Kenmore Canister vac
Got this post off this web site...I just replaced my swivel and it worked:
http://www.managemyhome.com/mmh/answers/Answers.action#l4q110567
To install a new swivel assembly, you will need 2 small, flat tip screw drivers. Unplug the vacuum. Push the screw drivers in between the hose and the collar where you see the seams in the plastic collar on the end where the hose enters the collar. This will release tabs that hold the collar to the swivel. Pry and pull the collar back over the hose and then pull the small screwdrivers out of the collar. Slide the collar back along the hose. Unplug the wiring connections from the hose. Pull the hose wires up and out of the holder on the swivel assembly. Lift the tabs on the side of the hose and pull it off of the swivel. Push the new swivel onto the hose. Align the hose wires and secure them in the holder. Plug the wires from the swivel into the hose wires (blue to blue, white to white). Secure the swivel wires into the wire holder on the swivel assembly. Push the collar back up the hose and onto the swivel with the plastic seams aligned with the tabs on each side of the hose. Snap the collar securely into place.
Nov 12, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Televison & Video Logo
171 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
