Question about HP OfficeJet 7310 All-In-One InkJet Printer
Hp director I bought a new computer about six months ago, and later noticed they had not put in the hp director I had before. How do I get it back without going through registry, etc.?
    Novelist:
  • 79 Answers
may be u have not installed the full feature software on your new computer , or if u have installed a newer version .
in case u r not able to find Hp Director on your computer , try to search for HP solution center , that is the upgraded version for hp directror .
or
u can reinstall the new software for office jet 7310 from the following link .
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-30606-1&lc=en&cc=us&dlc=en&product=391182&os=228&lang=en
Thanks
MAC
Posted on May 27, 2008
Bought my hitachi 50vs69a tv 3 years ago. put new bulb in six months ago after original shattered. New bulb is not working now. TV comes on and stays on a few seconds then power, lamp and temp light start...
Take the lamp out and examine it. Are there any blackened markes that look like arcing marks? If there are then the lamp may be faulty and that could be caused by the ballast but in my experience of working with Sany and Philips lamps, the ballast units generally fail without causing lamp problems.
I should go for a new lamp.
Hope that helps.
Nov 04, 2010 | Hitachi 50VS69 50" Projection HDTV
Hi There! I am having problem opening my hp director program
  1. Open HP Director using one of the following methods:
    • From the desktop : On your computer's desktop, look for the HP Director icon (c01425509.gif), and then double-click it.
    • From the Windows taskbar : Click Start , click All Programs , click the HP orHewlett-Packard folder, and then click HP Director .
    Although HP Director does not appear to be open , it is open and loaded into the computer's memory, but it does not open in a new window as usual.
  2. Without navigating to another open window, press Alt and Space bar at the same time. The Shortcut menu displays near the top-left corner of the computer. Figure 1: Shortcut menuc00833293.gif If the Shortcut menu does not open, repeat steps 1 and 2 until it does.
  3. Select Minimize from the Shortcut menu.HP Director displays (minimizes) as an item on the taskbar (the row of open software programs that appears at the bottom of the desktop screen). If HP Director does not minimize, click Minimize again until it does.
  4. Click the HP Director icon on the taskbar . The software opens and functions normally.
Dec 08, 2009 | Microsoft Windows XP Home Edition
Hp director does not open when i click on the icon
After installing (MS IE 7 or MS IE 8) browser on the computer that is connected to the HP product,This issue occurs on some HP products. The MS IE 7 or 8 browsers might be incompatible with HP Director
Follow these steps to use a workaround to open HP Director each time you use the software. These steps must be repeated each time you use HP Director.
1-Open HP Director using one of the following methods:
From the desktop : On your computer's desktop, look for the HP Director icon ( ), and then double-click it.
From the Windows taskbar : Click Start , click All Programs , click the HP or Hewlett-Packard folder, and then click HP Director .
2-Without navigating to another open window, press Alt and Space bar at the same time.
3-Select Minimize from the Shortcut menu.
4-Click the HP Director icon on the taskbar ( ). The software opens and functions normally. NOTE: The HP Director window and icons might appear larger than normal, but the software is functional.
5-Repeat Steps 1 through 4 every time you use HP Directo
Thanks,
Nov 30, 2009 | Computers & Internet
I cannot get my wireless to work. my computer is only six months old
try reinstalling ur wireless driver.
or if a hardware issue then claim it in warranty.
Don't forget to leave a Fixya rating
Sep 13, 2009 | HP Pavilion dv9000z Notebook
HP Director
NOT ONLY UNISTALL IT , you have to go to : START , SEARCH , then write HP psc 2210 , whatever appears DELETE them , you have to be sure that is clean and no left files of the program , then try again and INSTALL using the provided CD disk , I own the
HP 2410 , and it happen to me before . good luck , AJ
May 19, 2009 | HP PSC 2210 All-In-One InkJet Printer
Head light going dim
I had this same problem a month later i had to replace my voltage regulator
Nov 10, 2008 | 2007 Buell Lightning XB12S
2.3l ranger keeps overheating, been through two radiators already.
Hello Ranger Joe, eight months and two radiators is very uncommon. Question, Have you visually confirmed the leak in the radiators or is the leak near the hose connections? Replacing the radiator, cap, water pump, & the thermostat leaves only two others, the hoses and the engine block/heads. Far fitched will be something or somebody poking holes in the radiator.
Nov 07, 2008 | 2003 Ford Ranger Regular Cab
Yellowish spot on the lower left hand corner of tv screen
Good Day, There is a device that can be used to correct your concerns. Symptoms can be correct by EE PROM CORRECTION TOOL:
LSUQ0100. Instructions included. Try calling 1-800-458-6053. It's under $100.00 and takes about 1 hour from start to finish. Good Luck, big IRISH.
Jul 07, 2008 | Panasonic PT-52LCX65 44" HDTV
Explorer 7 Tased My Software
Have another look at HP's site, usually they have a lot of sw and documentation available for public download.
If you find and install the HP director, try firefox instead of explorer.
Dec 31, 2007 | HP OfficeJet 4215 All-In-One InkJet...
I can't get access on my PC to the HP Director.
Hi Seaner, I would suggest removing HP Director from the computer using Add/Remove programs in the control panel and then reinstalling. If that doesn't work let us know what operating system you are using, any error messages, problems, or changes that lead up to this situation. Also don't forget to rate this posting when done.
Feb 09, 2007 | HP PSC 1315 All-in-One Printer
HP OfficeJet 7310 All-In-One InkJet Printer Logo
142 people viewed this question
Ben Johnson
