ita not plugged into to tv. Just from the walltothe router. The cable is plugged into the router but the router just shows a blinking light.ita not plugged into to tv. Just from the walltothe router. The cable is plugged into the router but the router just shows a blinking light.
You can't post conmments that contain an email address.
Assuming that Windows has recognized the modem, and has loaded the correct device-drivers, Windows can use the modem.
You'll need to find an Internet Service Provider that provides "dial-up" service.
You'll need to have a land-line telephone (not a cell-phone) with your local telephone-company.
Connect a 4-wire cable (not an 8-wire Ethernet cable) from the "line" port on the modem to the telephone wall-jack.
Then, follow the instructions given you by your Internet Service Provider to configure your modem to connect to their dial-up server. Or, telphone them, and their Technical Support staff will guide you through the necessary configuration steps.
Any "modern" notebook computer will have both an Ethernet adapter and a wireless adapter built-in, especially one labelled as a "business" model.
Click Start
Click Control Panel
Click Classic View
Click System
Click Hardware
Click Device Manager
Click the '+' in front of Network Adapters
to show the installed adapters.
Take an Ethernet cable, and connect one end to the Ethernet slot in your computer, and the other end to a cable-modem or a DSL-modem, and you'll have an Internet connection, through the Internet Service Provider of your choice (Comcast, Roadrunner, Verizon, et cetera).
The ethernet card is embedded in the motherboard on this model,If you have a vacant slot on the motherboard you can install a new one there.any brand should do.
Good luck
Are you trying to connect to the wireless network on the laptop ? It is very simple. first you will need to make sure that you have all the wireless settings of the network. Click Here for more info about wireless network connections
first check with the ISP if any DNS server settings or proxy settins are required(but i think you can alternatively connect your laptops these may have ben already set on the laptops but just in case)
now if your ISP accepts you to have more than one connection from the same link then you can connect the connect the cable from the modem to the INTERNET/WAN areas and you can connect the ethernet cables in the ports marked 1,2,3,4
here check that if you are only etting the link on the computer connected to port1 and no connection on the others then make a small adjustment disconnect the cable from WAN/Internet port and connect it to the Port1 and the computers to 2,3,4
now that you are saying that u r not interested in the wifi so it is advisable that you go to the home page of the router and from there to the wireless page and disable the wireless broadcast of the router for safety purposes
this can be changed any number of times back and forth
make sure you donot have any static ip address in your network, or make sure you didnot disabled your network card, try to look in laptop network card if there is a linking light when you connect the cable? if not either cable or network card has problem.
try this and let me know what happen?
Best regards
to answer your first question, call verizon to fix the line. it is dropping. Second have verizon change a dsl and test it out.
as far as the tab on the CAT-5, the tab is to lock the cable in place, without it, it will work but you have no insurace as to the connection status. (need cable with tab).
i there ;
the solution for ur problem is :
> As ur isp is verizon so they must have provided wu wuth a username and password ...
> Open the routers page 192.168.1.1 ...
> Instead of automatic configration click on pppoe ...
> type in username and password for more help contact technical support at 1866-283-6613 . i hope this will help Linksys Tech support
