With verizon, you need to set the modem to full bridged mode so that the connection from your modem will be opened. This certain firewall is called NAT. Your modem and your router has this feature. To disable NAT on your modem, you need to set it to full bridged mode. To disable the NAT on your router, you need to open ports on your router.
forward it to the ip of your Xbox. this should set the NAT on your xbox to open, not moderate.
You need to open this port on the router for Xbox live to work
TCP: 80, 3074, 53
UDP: 88, 3074
