Question about Philips VR550 VHS VCR
Tape ejects automatically a few seconds after i put it in
I have tried this with tab on tape and without incase its stuck on record but no luck im wondering if i can wind the mechanism in somehow. so far i get the tape to go in it will go around the pinch rollers for a few seconds and then eject it again. any help would be appreciated
  • jmeri Sep 25, 2008
    Sounds like the problem I have. Specifically, most of the times I try to ffwd, rewind, the recorder apparently tries to synchronize, fails, and kinda ejects the tape. Only the tape is not unloaded properly, seems that the recorder thinks it's not there. Been cleaning it irregularly, seems it's time to do it again...
  • abdelkrim Sep 29, 2008
    I have a problem with my vcr
    1- doesnt unload the tape
    2- doesnt play the tape once loaded
    ta
  • Philips Master
  • 5,568 Answers
Try carefully cleaning the video head drum.
If it has any deposits on the heads, it may not be getting enough signal to synchronize and if it can't do this is a limited time, it will spit it out.
To clean it, use something that leaves no residue such as pure denatured alcohol and a cloth that leaves little or no lint.
Not the 'rubbing alcohol' variety as this contains 30-40% water and that isn't a good idea.
Posted on Aug 18, 2008
VHS tape will not eject and unit shuts down
It's not loading correctly. You need to open the cover (unplug first) and get familiar with the loading mechanism. You can get the tape out by rotating the loading motor wheel.
Mar 22, 2015 | Magnavox ZV427MG9 DVD Recorder/ VCR
Blinking red light won't record
Hi, You might have a tape in the VCR that has the 'record tab' broken-out, prohibiting recording. IF you want to record, eject the tape and put a piece of scotch tape over the missing square tab on the bottom corner of the VHS tape. Good luck and let me know if that works for you.
Sep 09, 2014 | Sansui VHF6010 VHS VCR
We put a tape in vcr. we push record and the vcr ejects tape and shuts off.
Does the tape play normally? Does this happen with several tapes when you try to record? Check the record protect tab on the lower left hand side on the facing end of the tape. If this is broken or bent it will not record, you can put a piece of tape tightly across the tab as a repair
Oct 01, 2009 | Philips Televison & Video
Samsung v7000 DVD/VCR .....VCR ejects tape when record is pressed
Does this happen with other tapes? If so then the micro switch could be stuck in the open position, try to give it a clean with a blast of air duster first then check the contacts on the switch. If it is happening with just this specific tape the the record tab (although in place) may be "soft" try putting a piece of tape tightly across the tab & try to record.
Aug 13, 2009 | Samsung Televison & Video
Tapes won't go down, and then eject.
Have you tried to force eject the cassette. May be the ribon of the tape has come out. Try using another cassette.
Mar 24, 2009 | Panasonic PV-V4522 VHS VCR
Zenith xbv713 won't record on vhs tape
is the tab on the cassette in place? if it has been removed the cassette will eject automatically when pressing the record button.
Jan 05, 2009 | Zenith XBV713
VCR ejects blank tape only
It sounds like the cassette is not releasing the tape so the machine can put it around the heads. This could damage the machine. Don't use it. A two dollar tape is not worth damaging your vcr. Throw it away.
Oct 09, 2008 | GE Televison & Video
Automatic recording?
Check that the record button on the player is not pushed in. It could be the button stuck behind the casing, or the microswitch on the main circuit board stuck against the switch mech. This should be apparent, as there would be no click when you push the record button.
Also check the REC button on the remote control.
Both of these potentially could cause the symptoms you describe.
The remote control for the later VR series does not, as you say, have an eject button.There is no alternative unfortunately.
Apr 09, 2008 | Philips VR550 VHS VCR
Wont Record
Usually when a tape starts to play automatically this means that the tab on the back of tape has been removed to stop others recording over it check the tab little black tab in a recess on back edge of tape if this is missing you can put a bit of sellotape over the whole to blank it off this will tell the video tape is ok to record on.
However if the tab is still in place the try putting a small bit of tape over it also to raise the clearence slightly then put back in video and try to record if this still dont work then the mechanism that detects the tab has failed these can be replace but usuall parts are hard to come by now as they no longer make vcrs any more but let me know ok i can assist you further just check tabs in place even try raising it with a bit of card stuck over tab with tape this might make the tab switch work if it has wonr down abit let me know ok.
As you look form back of tape the tab is bottom left hand corner check its flush with the tape if not use sellotape to repair let me know the outcome ok
Feb 15, 2008 | Televison & Video
Eject light comes on after I start playing the tape
ksmitheram,
I had the same problem with my camcorder just awhile ago. This can reflect a low battery. Try plugging in the camcorder for a couple of hours without using it. Then try recording or playing back the tape with it plugged in. Unplug it and check again. If this does not work you may have to replace the tape head.
Dec 25, 2007 | Samsung SC-D363 Mini DV Digital Camcorder
Philips VR550 VHS VCR Logo
229 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
