Question about Intel DG31PR Motherboard
Followup on power connectors
Thanks for your thorough reply, map9966.
I just bought this board and a compatible CPU, and I also cannot boot, though I do have fan and LED power.
My power supply does have the 2x2 connector for the CPU, but it has only a 10x2 main connector, not the 12x2. The user manual says the board's 12x2 socket is backwards-compatible, but I wonder if that's true.
I've removed everything else from the machine now, read through the manual, and triple-checked all the connections. Do you think I need to get a replacement power supply with a 12x2 connector.
  • ckweb1230 May 20, 2008
    Thanks again.
    Just to wrap things up here, an update. I did get a new ATX v2.2 power supply, but the system still would not POST. I ended up bringing the motherboard/CPU/RAM bundle back to the store where I bought it, for testing. They discovered that the BIOS needed an upgrade to work with the CPU (don't have the name and specs handy on the CPU). I let the tech take care of that, and now everything's hunky dory.
  • Boetman Feb 13, 2009
    no power to board
    President:
  • 2,351 Answers
Hi chweb1230, to answer you're question. Yes, I would suggest getting a power supply that would comply with the ATX main 24-pin power connector. The term backwards compatible references to boards that require less voltage, Ex; (A 20-pin main power board). If you intend to run serial ATA SATA drives & a PCI-E graphic card. The newer power supply will handle future upgrades. Suggest a 500 to 550W PSU should handle just about anything you add to the board.
chweb1230, when you make a post & are making reference from another post. Please copy & past that link into this post. If you are using a new user ID I can not look back & find what you are refering too.
How to vote you're expert & also how to repost more questions for same problem or to answer expert's questions for a posted question.
Enter FixYa.com site.
Sign in to your FixYa account.
Locate My Profile on our FixYa's homepage.
Under My Problem locate your problem and click on it.
Add another question to the current post....
Under the solution given by the expert, choose a color, one of the following: Vote.
"FixYa!" -The solution provides great advice on how to solve the problem (marked in blue).
"Helpful" -The solution provides helpful information that helps solve the problem (marked in green).
"Thanks for Trying" -The solution provides some help but does not solve the problem (marked in yellow).
If you need more help or have more question please do not hesitate to post further.
Enjoy!
Mike
Posted on May 19, 2008
Gigabyte MB no boot ga-ma790fx-dq6
did you replace the battery on the mainboard if its weak it will not beep
Aug 04, 2009 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Supermicro X6DAL-TG boot problem
I have 3 of these boards; however, they all have the Nocona Xeon with a Front Side Bus speed of 800MHz. The manual does not say anything about using a 533fsb. A second thought was if your power supply is an ATX with a 24 pin power connector and two +12 connectors one 8 pin and one 4 pin? The manual states all three need to be connected for the Xeon Processor.
Mar 30, 2009 | SuperMicro X6DAT-G Motherboard
Wont boot
i think the cpu may have a problem with the board or the memeory. either its bad, damaged or incompartible with your system. try out another cpu
Mar 24, 2009 | Gigabyte GA-K8VT800 Motherboard
Can not get motherboard to boot up
the things youre describing that are not controlled by the same power connectors. the 1st set that works are powered i think by the main large rectangular power connector. the stuff that's not working require more power connections. the cpu fan has a small wire that connects to a small connector on the motherboard right near the cpu. the optical drive connects to one of the the 4 pin power connectors coming from the power supply, same with the hard drive- same power connector. the front usb light is going to connect to a specific tiny 2 pin connector on the mobo, it will be labeled with tiny white letters-- try to find or download the manual. godo luck!
Jan 31, 2009 | Foxconn 848P7MB-S Motherboard
Replacing a power supply.
You need to connect both 20-pin and 4-pin connector to *********** board. Your 4-pin connector is located between your CPU and a I/O connectors.
If you did it right first time, check if you have anything shorted on your board because your old P/S could go bad for reason.
Good luck!!!
Jun 20, 2008 | EliteGroup K8M800-M2 Motherboard
No boot, no video
there is a jumper near the board cmos battery try to clear cmos by changing the jumper to the other position for some seconds (while power is off) so smos is clear.
if the problem still exist hook up the board spkr pins to the pannel at the board edge if a beep is heard upon starting the board then RAM is either not working or not positioned properly.
one more possibility :
CPU could be not working. sometimes currupted power supply could be causing this.
Nov 09, 2007 | Foxconn 661MX Motherboard
Motherboard
This could be several issues. You need to be much more specific on exactly what you done and what you installed. No video boot could be the following:
1)Memory clock speed not compatible- Say board only see clock speeds of 200,266,333mhz but you installed 400mhz CL or the bios is not set to auto mem cl speed and you need to manually change mem clock speed.
2)Your CPU, memory, or video card not fully inserted
3)Memory module of video no good if it has onboard mem cells
4)You forgot to plug in the yellow/black CPU connector on the board sending no power to the cpu
5)CPU pin bent on install or not seated correctly
I could go on and on but there are a few issues that cause no video boot so double check all you cards and connections.
Oct 16, 2007 | Biostar K8M800-M7A Motherboard
NO Power up at all except standby light
I know you say you have the cpu fan connected and assume you have the front panel power switch and restart cables etc.. connected, but have you connected the processor power supply lead from your PSU to the board as Sempron have a seperate power lead to the board to power it up, unlike the old Athlon processors. If you bought the CPU, Heatsink and fan together then it will already have thermal paste on the Heatsink, so don't apply any more. Hope this helps, as I don't wish to teach you how to suck eggs! Please rate this solution
Nov 09, 2006 | ASUS K8V-X SE Motherboard
Intel DG31PR Motherboard Logo
87 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
