Question about Panasonic KX-TG5632 Phone
No link to base kx-tg8231b - Panasonic KX-TG5632 Phone
  • 4 more comments
  • wayne99 Jun 30, 2008
    Panasonic KX-TG8231B - "No link to base" error. Any fix available or do I send it back for repair/replace?
  • dpress7413 Aug 08, 2008
    need to re-register the handset
  • spark146 Oct 14, 2008
    Exactly the same problem. Moving closer to the base does not solve the problem. The only workaround that I've found is to unplug the base, then replug; it then re-establishes connection with the handsets.
  • Esteban Estevez Dec 26, 2008
    I have the same problem. The head set do not link with the base. I tried to unplug the power, but no luck. If you have another solution, please advice.
    The manual, on page 40, says that it has to be re-register. I did it as described, but once it got registered, looses the link again. I try this many times but does the same thing. loose connection.
    Any diferent help?
  • Anonymous Mar 28, 2009
    I have same problem and it is not the battery.  The battery is fully charged and stays that way for a long time.
Panasonic KX-TG2313 - No link to Base problem... simple to fix!
Just unplug the power to the base and plug back in... should get a dial tone now!
Posted on Dec 19, 2008
  • 3 Answers
If the re-registration doesn't work, your handset is probably shot. you can buy a reconditioned one on ebay for under $30. take the battery out to find the model #.
Posted on Apr 04, 2009
TOO FAR FROM BASE
Hi! This may cure your problem!
Re-registering the handset
If “No link to base. Move closer
to base, try again.
” is displayed
even when the handset is near the base
unit, you may need to re-register the
handset to the base unit.
Important:
LMake sure the base unit is not being
used.
LHave the handset and base unit near
each other when re-registering the
handset.
LKX-TG5422 and KX-TG5423 only:
Confirm the extension number of the
handset which has lost its link to the
base by placing the handset on the base
unit or charger.
If you accidentally assign another
handset’s extension number to it, the
other extension will stop functioning.
1 Handset:
Press {MENU}.
2 Scroll to “Initial setting” by
pressing {V} or {^}, then press {>}.
3 Scroll to “Registration” by pressing
4 KX-TG5421 base unit:
Press and hold {HANDSET
LOCATOR
} until the CHARGE
indicator flashes.
KX-TG5422 base unit:
Press and hold the handset locator
button that corresponds to the handset
you want to re-register ({HANDSET
LOCATOR
1} or {HANDSET
LOCATOR
2}) until the CHARGE
indicator flashes.
Below is a link that will take you to the instruction manual for your phone.
http://www.phone-manuals.com/panasonic/KX-TG5422M.shtml
Hope this helps! Hal
Feb 27, 2009 | Panasonic KX-TG5422M Cordless Phone
Panasonic KX-TG2367 says "No link to base".
This worked for my mother's KX-TG2357:
We tried doing what it said in the manual on page 54. That didn't work! She then decided to just unplug everything. About 3-5 minutes later, plugged everything back in, and lo and behold, everything was working fine!!
Jan 28, 2009 | Panasonic KX-TG2357 Cordless Phone
No link to base
give more informations please
Jan 08, 2009 | Panasonic KX-TG8231B Phone
Phone won't work
Hi - I stumbled upon this fix after my KX-TGA8231B DECT6.0 phones lost dial tone: I simply removed the rechargeable AAA batteries from the backs of each handset and put them back in after a few moments. This restored dial tone and the ability to hear a call when the phone is answered. Good luck. ---Gerry
Nov 04, 2008 | Panasonic KX-TG8231B Phone
No dailing tone
Panasonic Phone kx-tg8231b
it rings but it i have no dial tone can not call out and when i answer it cuts the person off calling
does not show who is calling on the id does not show missed calls or messages left
Jul 06, 2008 | Lands Phones
Model#kx-tg6071b when talk button is pushed, screen shows" no link to base move closer, try again". That is what appears on both handsets.
Press MENU, scroll down to INITIAL SETTINGS (press select), scroll down to REGISTRATION (press select), then select HS REGISTRATION, and follow the instructions on the handset screen. This is for the KX-TG6071B, but is similar for most Panasonic Cordless phones. That will link the handset to the base, and YOU MUST DO IT WITH EACH HANDSET.
Jun 22, 2008 | Panasonic KX-TG2313 Cordless Phone
My KX-TG 8231B
Make sure the phone is pluggd into the wall properly. If so and no dial tone is detectable make sure you installed the batterys on the handsets correctly and that they are fully charged. If you have a friendly neighbor with a working phone line plug youre phone into their line and if it does not work and you followed my previous instructions seek a repair center in youre area that honors panasonic warranties. If the phone is pluggd in at the neighbors house and it works use it to call the phone company.
Mar 26, 2008 | Panasonic KX-TG1033S Cordless Phone
Panasonic KX-TG5632 Phone Logo
1,530 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
