Question about Philips GOGEAR SA6045 MP3 Player
It mixes up lots of stuff
If i allow my mp3 player to start up without pressing reset, it takes about 5 minutes to start up and mixes up just about everything. if i press reset, it takes about 5 seconds an everything is right. is there any way to fix this so i don't have to press reset?
  • 476 Answers
Try repairing the player using the supplied software:
Install and run the Philips Device Manager from the product CD.
Press and hold [VOL+] whilst connecting the SA6045 to the PC.
Continue to hold until the PC tells you to let go.
Follow the on-screen prompts.
This will format you player and restore the firmware.
NOTE: THIS WILL DELETE ALL FILES ON THE PLAYER.
Posted on May 19, 2008
My model is Philip SA1MXX02W/97 GoGear Mix 2 GBMP3 Player.When I on it, it shows updating 20 percent, then updating 40 percent ; hang there for few seconds and suddenly off by itself. Pls help.
It shows there is some problem with the inbuilt device firmware.The only solution is to do a reset on your device.Please follow the instructions below to reset your Philips SA1MXX02W/97.
1.Insert a pen tip or other object into the reset hole located at the bottom of the GoGear Mix. Hold until the player shuts down.
If the reset option is unsuccessful, follow the steps below to recover the GoGear Mix with the Philips Device Manager:
1.On your computer, select Start >Programs > Philips Digital Audio Player > GoGear Mix Device Manager > Philips Device Manager to launch the Philips Device Manager.
2.Turn off the GoGear Mix before you continue.
3.Press and hold the volume button + while you connect the GoGear Mix to your computer.
4.Keep holding the key until the Philips Device Manager acknowledges the GoGear Mix and enters the recovery mode.
5.On the computer, click the Repair button and follow the instructions of the Philips Device Manager to complete the recovery process.
6.When the recovery is completed, disconnect the GoGear Mix from your computer.
7.Restart the GoGear Mix.
Hope you are satisfied with my solution.Thanks for choosing Fixya.
Jun 26, 2011 | Philips SA1MXX04P/02 GoGear Mix MP3 Player
Hi, i own a sony walkman mp3 player of B series that is NWZ-B135F once i inserted my mp3 player into my friends pc later my player has stopped working (the player does'nt switch on) please help me please...
Perform the following steps to resolve the issue.
1. Confirm that the portable player is connected to a working USB port and that it is charging. If necessary, connect it to a different port. When connected properly, the battery icon will be animated or it will indicate the charge status such as FULL when charging is completed.
2. Make sure that you are pressing the POWER button to turn the player on. Previous Walkman models that did not have a power button would turn on by pressing any button. This model must have the power button pressed to turn it on.
3. Ensure that the HOLD function is not activated.
NOTE: For some models, when you use the portable player for the first time, if you have not used it for a long time, or the battery is depleted, it may take up to 5 minutes for it to be recognized or start charging. On models with a display, the display will remain blank. If it the portable player is not recognized or does not begin to charge after waiting 5 minutes, continue with this procedure to reset the unit.
4. If the portable player is still not responding, reset it by pressing the RESET button with a small pin or similar object. Reset button is located near the Strap hole.
NOTE: When the RESET button is pressed, although the unit will retain the music data and clock settings, all other stored data and settings may be deleted. If the unit starts up after the reset, access the Settings menu and initialize the unit using the Format (initialize) function.
5. If there was no change after the player was reset, connect it to the computer and reset it again, leaving it connected.
Thanks for using FixYa.
Apr 07, 2011 | Sony Audio Players & Recorders
IT AS FROZEN
Hi,Use the below instruction.
Flip the MP3 player's "Hold" switch to "Off" if the switch is on. Depending on the MP3 player you own, this switch is likely located at the side or top of the player. Once the switch is off, try to turn the player on.
Let the battery of the MP3 player die. A frozen MP3 player is technically still running, and thus the battery for that player is being drained. Wait until the battery is fully dead before moving to Step 3.
Charge the MP3 player using either a computer (that's turned on) or an electronic MP3 charger. Charging the player's battery may "jolt" the player out of its frozen state. Connect the player to the computer or charger via the player's USB cable. Charge the player for 30 minutes before attempting to turn it on.
Sync the player with the appropriate software program (for example, Windows Media Player) for the MP3 player. Connect the player to the computer as described in the previous step. Open the software program and click the "Sync" tab at the top or side of the program. If necessary, click "Start Sync" underneath the tab. The name of the player appears under the "Sync" tab if the player has synced successfully. Try turning the player on once it has synced with the program.
Press the small "Reset" button on the MP3 player. This hard reset shuts the player down completely. Use a pin, tack or thin nail to press down the very small "Reset" button on the side or back of the MP3 player to reset the player. Then, try to turn the player on.
Tips & Warnings
Take the player to an electronics store if none of the steps above unfreeze the player, as there is likely a serious problem with the MP3 player's hard drive.
Also take out the batteries, if holding the play button for like 5 minutes doesn't work.
Hope that helped.
Have a nice day..
Feb 23, 2011 | Audio Players & Recorders
Mp3 Player Froze
Follow this procedure if the portable player appears to be frozen with Every Moment Has its Music on the display.
  1. Confirm that the portable player is connected to a working USB port and that it is charging. If necessary, connect it to a different port. When connected properly, the battery icon will be animated or it will indicate the charge status such as FULLwhen charging is completed.
  3. Ensure that the HOLD function is not activated.NOTE: For some models, when you use the portable player for the first time, if you have not used it for a long time, or the battery is depleted, it may take up to 5 minutes for it to be recognized or start charging. On models with a display, the display will remain blank. If it the portable player is not recognized or does not begin to charge after waiting 5 minutes, continue with this procedure to reset the unit.
  4. If the portable player is still not responding, reset it by pressing the RESET button with a small pin or similar object.NOTE: When the RESET button is pressed, although the unit will retain the music data and clock settings, all other stored data and settings may be deleted. If the unit starts up after the reset, access the Settings menu and initialize the unit using the Format (initialize) function.
  6. Check the Sony Support Web site to see if there are any available firmware updates for your model. Updates can be found on the Sony Support Web Site in your country.
Jul 12, 2010 | Sony NWZ-E438F Digital Media Player
Dell dj mp3 player will not boot up.
It is probably defective. If you bought it new, try to return it and / or get a replacement. If you bought it used, unfortunatly thats what lots of people do with stuff that is broken.(They try to sell the broken item without telling you)
Apr 20, 2010 | Dell Pocket DJ MP3 Player
Where do i get the movies and pictures
ok heres what you do:get a cd and when rip pops up you press it and you check the songs that you want on your mix max
Jul 23, 2009 | Disney Mix Max Digital Media Player
I have a sandisk sansa m240 mp3 player i found but the screen is busted. I figured out how to do everything without the need of seeing what was on the screen, except how to record stuff.
This will probably be impossible without a screen, but here are the steps:
The Sansa Fuze has a built-in microphone allowing you to record your own voice, an
interview, or a speech.
To start voice recording, follow these steps:
1. Press the Home button to return to Main Menu.
2. Select Voice from the Main Menu.
3. Select Record Now.
4. To pause the recording, select Pause.
5. To stop the recording, select Stop.
6. Select Yes to save the recording.
7. Press the |<< button to return to the previous menu.
Dec 03, 2008 | SanDisk Sansa m240 MP3 Player
Sandisk Sansa M240 Screen Busted
Hard w/o screen, here are the steps:
Disney mix max mp3 player
I suggest you just wait for it mine can take minutes to start up but it still turns on so wait a few minutes if not working get someone to look at it
Dec 29, 2007 | Disney Mix Max Digital Media Player
My mp3 won't turn on!!
Sorry, as far as i know you can't, you nead to reset: 1. Recharge the product by connecting to the pc (pc must be running). 2. Press the reset button using a sharp tool. Wait 10 minutes then connect the player and pc. (The reset button is between the FUNC and MODE buttons.) 3. Turn the player off and press the mode button while making the player and pc connection. 4. The message ¡°USB Connected¡± displays when turning the player on. 5. Disconnect the player and pc. 6. Connect the player and pc after turning off the player. The player is charged in about 2 hours if the player is off. 7. Upgrade to the latest firmware (Ver. 1.11 or higher).
Nov 14, 2005 | Mpio FG200 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
49 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
