Question about Intel Computers & Internet
The wireless adapter on my pc is now longer working
The pc can detect the network (router) but i can no longer connect to the router. I have made no changes to the pc
Do you still have this problem? If so, please be more specific.
What do you mean, the pc can detect the network (router) but I can no longer connect to the router. ?
Posted on Jun 02, 2008
Gateway purchased new 3/2010 has been connecting flawlessly to wireless internet until a few weeks ago. Solution had been to click on Open Network and Sharing Center, click on Troubleshoot problems, click...
Are you connecting to your own wireless router? If yes, have you changed anything in its configuration, or inadvertently reset it? If you're connecting to someone else's router (neighbor, etc.) it could be that they have locked you out. Does the wireless network show as secured? This sounds more like a security issue than hardware or driver.
Jan 06, 2011 | Gateway Computers & Internet
Not detecting wireless network
Make sure the wireles button is turned on if it is a notebook.
Make sure the drivers are installed and upto date.
Make sure the router is turmed on and the wireless light should be on. (install the router if u had received any cd along with the wireless router.
if still your wireless connection is not detected simply remove all the wireless profiles on the. restart the PC and the router. once it is started the the network should be detected.
Aug 02, 2010 | Dell (430-3572) Wireless Adapter
Cannot link to wireless thompsoncontrollerinternet
it maybe a firewall blocking access or the secruity code 1) disable the firewall and see if it now connects 2) log into the router and goto the wireless section and remove the secruity now see if that will connect a useful tool to use, if you can copy onto the PC, http://www.xirrus.com/library/wifitools.php this will detect all the networks broadcasting - so you can now see if the adapter will detect your wireless network
Mar 15, 2010 | Computers & Internet
Lost wireless signal
Check the WLAN light on the Linksys Router if it's still on and make sure that the Wireless Adapter is ON on your HP computer and can detect other wireless networks, if WLAN is off try to do a power cycle and check again the lights... If lights are ok... connect your PC to the LAN port of the router and access the admin page, try changing channels and see if your wireless computer can detect it, if still not try to do a hard reset on the router
Mar 02, 2010 | Computers & Internet
My wireless adapter does not detect any reception from the router. i have another laptop at home that could easily detect reception from the router. what should i do?
since the laptop is connecting to the router and is having the internet access as well then clearly the problem is with the adapter or with the pc using the adapter.
Following steps can be considered :-
1)If the PC is using OS as windows XP then , click on start menu and then go to control panel and then open network connections from there.
2)Under network connections an option for wireless connection exist , right click on that option and then click on properties.
3)Under wireless network connection properties there are three tabs general , wireless network and advanced.
4)Left click on wireless network tab and check the box which says use windows to configure my wireless setting's and click OK at the bottom.
5)Then , Right click again on wireless network connection and then left click on view available wireless network.
6)List of available networks will be there , select the network you use and try connecting to it , if it gets connected then the internet access will be there.
Nov 15, 2009 | HP 290563-B21 Network Adapter
Can i use Bluetooth USB Adapter to connect PC to wireless router?I purchased a new PC that's connected to a wireless router for internet. I want to connect my old PC to the same wireless router. I don't...
Hi, to connect your computer to the wireless network of the router you need to have a wireless adapter. The bluetooth adapter will not work in this case as the router does not communicate with the bluetooth signals.
Purchase a wireless adapter like NETGEAR WG111
Rate it, if it helps.
Regards
Anand
Aug 03, 2009 | Computers & Internet
How does the pc wireless adapter work for laptops with embarq equipment. currently using dsl with embarq.
pc wireless adapter will work then if you have also another network like wireless router or another PC or Laptop with wireless adapter, if your going to use this wireless adapter network in pc to pc is you are going to setup by adhoc to adhoc connection, itself detect for sharing a network without any router needed, but if you do such simple network connection use wireless router, its definitely work easily. Aumatomaticall detect wireless router on your wireless adapter network.. Good luck!
Jul 18, 2009 | 2wire (1000-100016-002) Wireless Adapter
Cannot connect my wireless adapter to Belkin wireless router
hi,
ok sir i got it if the wireless network is detected then try and connect and the if it doesnt connect try and connect in safe mode with networking sometimes wireless doesnt work in safe mode,but still try that,uninstall and reinstall the wireless driver for adaptor and then open the gui page(router page with the default gateway page and then change the wireless channels and also turn off the firewall,and from the start,all programme turn on the wireless adaptor utility and then start the services of wireless zero configuration from services.msc.....then if it is connected with the ehternet cable,then what u can do is that go to the router page and then also put a check in the let the windows controll the wireless network......and it will definately work and if it doesnt work then reinstall the operating system......good luck...
if it is a little bit also helpful pls.rate this soultion for me pls.....
Feb 07, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Remote pc cannot access wireless
You can do a reset on your router. All computers must be must be getting its connection from your router. Your wired computer must be getting an ip address from the router(example is 192.168.1.x). You can then access the router page using your browser by typing the default gateway(example 192.168.x.1). This will take you to the router configuration page. You can set up the wireless network and your wireless network can now support more than 2 wireless computers.
Mar 14, 2008 | Computers & Internet
Wireless connection
If this laptop has a wireless switch, make sure it's on.
Did you get the wireless hub?
Wireless is controlled by the wireless zero service, which should turn on automatically when your adapter is detected.
You can turn it on manually in Control Panel/Admin Tools/Services
Nov 03, 2007 | Acer Aspire 3000 Notebook
Computers & Internet Logo
61 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
