Question about Panasonic Lumix DMC-FX30 Digital Camera
Sudden loss of use of a Lumix DMC-FX30
1. Lens doesn't retract when camera is turned off. 2. When camera is turned on, lens retracts then protrudes immediately and a message appears on the screen, saying: PLEASE TURN CAMERA OFF AND THEN ON AGAIN. 3. We've done that multiple times, with no change in the situation. 4. We've studied the User Manual and can find no way to do a full system reset on the camera. Is there one available? 5. We've tried the suggestion that was given for another Lumix model (zoom out while turning the camera on). This was of no help. 6. For now, the camera is unusable. 7. Do you have any other suggestions? Many thanks for any advice you can offer.
  • 9 more comments
  • Gumpa May 18, 2008
    Did you not read the subject of my original message?
    It is a Lumix DMC-FX30
  • Gumpa May 19, 2008
    Thank you. I will try. I hope this works.
        - Hill
  • Gumpa May 22, 2008
    Unfortunately, no joy. Replaced the battery after 48 hours and the camera remains exactly as I first described it.
    I will appreciate any additional ideas that anyone can provide.
    Thanks.
    The problem is exactly as I first posted. Our Lumix DMC FX30 is no longer usable. The lens remains in the protruded position when the camera is turned off, it retracts briefly when the camera is turned back on, then it immediately protrudes again, but the screen goes almost completely blank and the error message: "PLEASE TURN CAMERA OFF AND THEN ON AGAIN" appears. The only button that is functional while that message is on the screen is the on-off switch. Turning the camera off leaves the lens in the protruded position.
    Constructive suggestions will be most welcome. Thanks.
    Thanks. You may be right. I was hoping to solve the problem on my own (with the guidance of one of FixYa's experts. I guess I'll check to see if someone else might have an idea for me to try.
    I've not yet consulted with a camera service center. I was hoping the advice I would receive here would help me avoid having to do that.
    Please review my prior posts. I've described our camera's problem as fully as I can. Thanks.
    Thanks for trying. It doesn't work. Maybe you aren't familiar with this model. It doesn't have a power button to hold. It is a simple on-off sliding switch. Following your suggestion doesn't work with a simple switching off of the slider.
    Thanks, but that's not the issue. I assume you meant to say the lens barrel, but I had already checked that quite carefully. And, as I said in my explanation of the problem, the lens retracts perfectly well every time I first switch the camera on.
    Well, you seem pretty sure of yourself, but I don't think you are right. We take very good care of this camera and we are quite confident that it has never been dropped and that it has never been switched on when there was an obstruction that kept the lens from protruding properly. There are no marks anywhere on the camera, and the lens is fully capable of retracting and protruding fully. It just doesn't do so at the right time and the camera is rendered useless. This seems more like an electronic malfunction than a mechanical problem.
    Thanks. Your suggestion seemed sensible and I've tried it a few times, still with no luck, unfortunately.
    We're off to a local service station...
    Master:
  • 377 Answers
Check the lens retractor, if there's a dust or any particles that could cause the unit to malfuntion..
Thank you
Posted on May 22, 2008
  • 1,031 Answers
Its likely 2 b a power problem check the charging part and the electronics contact thres a partial contact,the supply is nt goin round as supposed
    Genius:
  • 3,422 Answers
HI,
All you have to do is remove the battery and the memory card again and wait for 10min.Next insert the battery and the card then gently tap it twice at the end of the camera to your palm and again hit under the bottom of camera 2 or 3 times with your palm.If this doesn't help then give it another 2 or 3 hard bangs This usually fixes the error and this is the only home remedy that can fix it.
Goodluck,
Please don't forget to rate or accept the solution
  • Priya darshan May 22, 2008
    Since you have decided to take it to the service center to fix this problem,can you please close this by accepting one of the best solution amongst us as fixya.
    If you need anymore help then let me know..
    Genius:
  • 3,587 Answers
It appears that unless you have the tools and techniques to repair this camera, by disassembly..
  • 790 Answers
try removing the batteries and press the power button for few seconds and reload the batteries!!
    Sergeant:
    Champion:
  • 304 Answers
the camera could suffering some mechanical problem on the unit.. it was better to consult or bring to any service center to check any parts that does not functioning well..
`jack
  • Elizabeth Krijt
    Elizabeth Krijt May 22, 2008
    well see if there's any dust or dirt on the lens that makes it not to retract.
    Guru:
  • 1,894 Answers
Did u consult ths with service center?
  • dewan nafees ahmed May 22, 2008
    sorry i was late
    i was about to post this.
    you have dropped ur camera sometime before this.
    u must have done it for sure i think
    bcz this problem comes usually due to dropping of camera.
    else another option is
    ur camera has turned ON once while ur camera was inside pouch or pocket.
    which has caused the obstruction of the lens retraction once.
    this has made the lens unit faulty.
    u will have to surely repair it by opening the unit.
    in my last post i asked
    did u consult ths with service center?
    why i asked this because
    u will have to go to the service center surely to replace retract unit.
    and hence i wanted to make sure that this is ur first try to solve this problem.
    thank you
    dont forget to rate the solution if u find it helpful.
    thank you
    Brigadier General:
  • 3,614 Answers
Whats the model of the camera..?
Posted on May 18, 2008
  • micromaster
    micromaster May 19, 2008
    try to remove the camera battery for 48hours, this will reset the system and the settings made. put back again the battery...
    post back how thing came up there..
    thank you
Lumix tz30 lens will not retract
the oven will not igniter it get power so it not the breakerso can anyboby tell me whats going on?
Jan 18, 2014 | Panasonic Lumix DMC-TZ30 Digital Camera -...
Lumix DMC FZ35 Lens Opens and Retracts Continually When Turning the Camera on.
it sounds like it has slipped a gear in the lens.. you could try to manually push the lens in when it comes out and that might reset it but it also might break it.. best is to send it back to panasonic.. is a easy fix
Oct 01, 2012 | Panasonic Lumix DMC FZ35 Digital Cameras
Lens will only partially come out - a few mm - when powered up. It then retracts.
The lens is retracting because there is something preventing it from fully extending. It is a safety mechanism built into all digital compact cameras to be sure the lens doesn't force itself and break. Once it encounters resistance, it will retract.
Make sure there is no debris between the lens rings and try again. If the problem doesn't go away, you will likely need to take your camera in to be repaired.
Mar 05, 2011 | Panasonic Lumix DMC-FS3 Digital Camera
Stuck lens on on lumix dmc-LX2
u could go to best buy but it might be cheaper to buy a new camera
Jan 13, 2010 | Panasonic Lumix DMC-LX2 Digital Camera
LUMIX DMC-LS80 SHOWING MESSAGE PLEASE TURN OFF CAMERA AND TURN ON
This fault is usually caused by a lens problem.
Over 95 percent of lens problems are from Knock damaged or sand/grit in mechanism. It will need to be serviced by an experienced technician.
Sep 30, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
Error message- remove lens cap and press > button
Is your lens not retracting?
I've got the same problem and with the lens not retracting - this is why i get the message.
Jul 29, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Lumix lens retracts and extends
Belikes, any external object is trapped in between your Lens Motor and Camera Body. You should consult Authorized Service Personnel to handle this trouble.
Jul 28, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera mesaage says turn camera off and on tis has no impact also the lens will not retract
hello, i did get also same message and lens did stay out. did put camera in play back mode and in menu did reset everything. now it works again. maybe i was lucky, maybe this is ,,the"solution.
Jack
Jun 18, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
Lens will not retract
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse. Good luck!
Sep 11, 2007 | Panasonic Lumix DMC-LZ2 Digital Camera
Panasonic Lumix DMC-FX30 Digital Camera Logo
194 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
